Speaking of injectors don't buy deatschwerks , they pop and misfire like crazy at low duty cycles, great power with no det, decent economy (14-16L/100km with 260kw) but yeah pop pop pop at idle and cruise.
Did you mean decent economy as in good economy?
I was getting 14L/100km or less around with Nismo 555's and about the same power level and the thing was running rich. I had a massive buildup of carbon in my dump pipe when I pulled it off and the thing used to shoot flames all that time
The deatschwerks were one of my backup options if I ever needed to upgrade from my new 740's so interested to hear some more feedback.
you got a plenum already so get some top feeds Cal..a full set will be much less than sidefeeds so spend 100$ on a rail...or you can just use a NEO rail which ahs the reg built in....@ 300kws on a highway run I get as good as 10L/100km on ethanol with 750cc xspurts... ;)...
cold starts still use alot of juice though and kill around town economy but thats ethanol..still gets around 15L/100 though...my petrol tune uses much less
Which Deatschwerks are you using, the older high flows or the current generation ones ( like these http://www.deatschwerks.com/products/fuel-injectors/sport-compact/nissan/skyline/neo-rb25det/1998-02-neo-rb25det )? I have a set of 800cc high flows with SS2 and a similar power level. The only popping I'm getting is occasionally when lifting off rapidly on high boost. They seem to idle fine.
The new generation ones, I got the R33 replacements, what ECU are you using? I'm using nistune however Jaustech here in Adelaide are also having the same problems as me on another set of 740cc's running E85.
Edited by Rolls
I looked at going top feed. The injectors are alot cheaper but the initial setup costs more then a new set of sidefeeds. When I got screwed over with being Nismo 740's off someone on here, So I cut my loses and bought some new 740's
Maybe next time lol but I'll probably go side feed again :P
I managed 9.9L/100km with my car once. But only once lol. Was a big achievment
not just cheaper ..better...
Sorry I'm currently in China working into the KIA project as well as some of VW turbo systems. I will be back in two weeks.
Workshop is running as usual, if you can't find me over the phone please email or PM your inquiry though I usually reply within 24 hours. Thanks.
The 1200cc injectors worked fine on my R33 so if any one's looking for a set of high capacity cheap dropins, they are fine.
Edited by hyper-gear
For anyone interested these are my recent results of before and after on my rb25 with a hypergear tr43i. Red line was previous results and blue line is new, changes were brae hi mount manifold , convert turbo to external gate with hypergears 50mm wastegate.
Car made more power, more torque and better response. Also feedback for the fiveomotorsport 1000cc injectors they were perfect so another positive result for them.
Thats a neat gain from the manifold and gate.
Is the TR43i an older HG turbo?
Yeah its hes really early model turbos from about 4 years ago before the atr series.
Dyno reading from another customer's R33 Rb25det GTST, Appears to be using the current profiled high flowed 21U Stock turbocharger. 271rwkws on pump 98 fuel and supporting mods.
I think the RPM scale is wrong:
Yeah maybe. They couldnt get an RPM signal from my car for some reason when they dynoed it (ages ago) so maybe it just defaulted to roller speed. Funny that it looks exactly half what the engine speed should be though
makes it look impressive anyway, full boost at just over 2000rpm lol
    • They work on really anything track related now. They do my mates r35 gtr and it's a weapon of a car.
    • I use the penrite 600f in my cars and have had no issues even at Townsville v8s when I drove that but I bled fluid end of day for just in case. Good value and a about 38-40 on sale. Use castrol srf on the supercars and no need to Bleed brakes over a race weekend. Do the 1000km with no issues. Over 120 a bottle I seen at repco. A quality brake pad is always a good starting point the ebc stuff I've seen let go after 2 sessions with heavier cars. I'd be going to a decent track pad and maybe those porsche air guides on the control arm to help with some air over the rotor. Helps on 86/brz with stock callipers.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
