It goes to the back of the intake manifold. But it's a push-on fitting on the manifold so I just used standard rubber hose to behind the head, then an AN-AN adapter with a push in fitting on one side and braided line on the other. Makes it a bit more expensive but it's all straight fittings so it's not too bad. I wouldn't do it any other way, hard lines and banjo fittings are the worst.
So with a high flow 21U I wouldn't have to bend the stock water lines like I did when I fitted the SS1PU?
Just trying to work out my options for my R34
I have an SS1PU to transplant into the r34 but I don't want to go through the issues I had with the oil drain and the water lines.
Using R34 OP6 rear housing for high flowing can probably archeive towards 280rwkws . How ever not sure what the lag would be like.
I guess I'll try my luck again and if I can't work it out then ill pay someone to do it.
R33 gtst - mod list
Hybrid fmic
Hks super dragger 3.5"
Splitfires
Nismo 740cc inj
Stock cat (made into decat)
3" stainless intake
Z32 AFM
3A racing pod filter
Apexi evc
Plugs are bcpr6es gapped at 0.8
Tune in progess 2 hrs to go.
  • Like 1
Winner!!
Thats a good graph. Almost half your RPM range is on power, and peak torque would be pre 4k :)
Anyone building a sub 300kw RB25 would be silly to buy anything else.
My mates, mate(lol, i know), bought one of these new hi-flows of stao a few weeks ago for his manual rs4's stagea
apparently he rates it highly already with just a decent nistune base map in it on low boost so far, think they are doing
ponnies in it next and then getting tune sorted
My mate drove it and raved about its response , Bang for buck it sounds like a real winner...
cheers
darren
+1 for hypergear. My turbo was apparently some odd bod creation with an R32 rear and R34 front. Had it hi-flowed with 12 psi actuator, gained up to 60 rwkw and 100 nm, with hardly any "real" change in response (stock made 10psi at 2800 rpm, now just under 16 psi at 3500rpm)
Sheets here:
http://www.skylinesaustralia.com/forums/topic/249186-nat-power-results-na-t-turbo-conversions-only/?view=findpost&p=7103500
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
    • FYP. Sadly. Even bolt cutters wouldn't take 2 sec. But in the days of 18v angle grinders, nothing is safe.
    • One piece driveshaft I would recommend a dual CV setup otherwise stick to OEM. I have heard most one piece driveshafts cause excess vibration otherwise. The transmission grind I'm quite familiar with. You can try shockproof gear oil, otherwise you need a new transmission. The shifter is extremely simple on these cars. If you want pull apart the assembly and replace the plastic bushing but I doubt that fixes anything. The tail light issue is very common, unfortunately new tail lights are long discontinued. The trunk antenna going up always is because your radio doesn't have a true power antenna control, just remote amp power signal. There is a blank switch plate that you can pop out and install a switch for this or alternatively source a head unit that has proper antenna control. Throttle body sticking you have to disambiguate by disconnecting the cable and seeing if the linkages are the problem or something else. There is a procedure to adjust them, refreshing them is also somewhat involved if that's the issue. I have dealt with many of these issues. Old cars really are fractals of problems. The more you fix the more you discover there is to fix.
    • Welp, you've got a long list of experiences right there. I'd say you're on the right path.
    • That's correct, suits my requirements a bit better. Sure there are also numpties there, however it's generally a different vibe and more my kind of vibe.
