It goes to the back of the intake manifold. But it's a push-on fitting on the manifold so I just used standard rubber hose to behind the head, then an AN-AN adapter with a push in fitting on one side and braided line on the other. Makes it a bit more expensive but it's all straight fittings so it's not too bad. I wouldn't do it any other way, hard lines and banjo fittings are the worst.
So with a high flow 21U I wouldn't have to bend the stock water lines like I did when I fitted the SS1PU?
Just trying to work out my options for my R34
I have an SS1PU to transplant into the r34 but I don't want to go through the issues I had with the oil drain and the water lines.
Using R34 OP6 rear housing for high flowing can probably archeive towards 280rwkws . How ever not sure what the lag would be like.
I guess I'll try my luck again and if I can't work it out then ill pay someone to do it.
R33 gtst - mod list
Hybrid fmic
Hks super dragger 3.5"
Splitfires
Nismo 740cc inj
Stock cat (made into decat)
3" stainless intake
Z32 AFM
3A racing pod filter
Apexi evc
Plugs are bcpr6es gapped at 0.8
Tune in progess 2 hrs to go.
  • Like 1
Winner!!
Thats a good graph. Almost half your RPM range is on power, and peak torque would be pre 4k :)
Anyone building a sub 300kw RB25 would be silly to buy anything else.
My mates, mate(lol, i know), bought one of these new hi-flows of stao a few weeks ago for his manual rs4's stagea
apparently he rates it highly already with just a decent nistune base map in it on low boost so far, think they are doing
ponnies in it next and then getting tune sorted
My mate drove it and raved about its response , Bang for buck it sounds like a real winner...
cheers
darren
+1 for hypergear. My turbo was apparently some odd bod creation with an R32 rear and R34 front. Had it hi-flowed with 12 psi actuator, gained up to 60 rwkw and 100 nm, with hardly any "real" change in response (stock made 10psi at 2800 rpm, now just under 16 psi at 3500rpm)
Sheets here:
http://www.skylinesaustralia.com/forums/topic/249186-nat-power-results-na-t-turbo-conversions-only/?view=findpost&p=7103500
    • They work on really anything track related now. They do my mates r35 gtr and it's a weapon of a car.
    • I use the penrite 600f in my cars and have had no issues even at Townsville v8s when I drove that but I bled fluid end of day for just in case. Good value and a about 38-40 on sale. Use castrol srf on the supercars and no need to Bleed brakes over a race weekend. Do the 1000km with no issues. Over 120 a bottle I seen at repco. A quality brake pad is always a good starting point the ebc stuff I've seen let go after 2 sessions with heavier cars. I'd be going to a decent track pad and maybe those porsche air guides on the control arm to help with some air over the rotor. Helps on 86/brz with stock callipers.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
