I'm considering on going back to pump 98 with e10 united p100 from eflex
It should reach my power goal and is more readily available
I was thinking of getting it tuned on p100 and just use regular 98 daily driving to work but just wind back 5psi boost and plus I don't drive it hard daily and if I want to go to the track or thrash it I will fill it up with p100 and put it on high boost
Is there no eflex pumps near your area or more for the fact you can travel to different places?
Maybe a full flex tune so that you can run the 98 when you want and put some caltex in it when you go to the track?
Never mind chatting about other turbos here. It encourages me of engineering better turbos.
Here are the result for the SS1.5 from today, from my Sr20det S14 with No VCT controller.
Maxed out at 270rwkws, 20psi by 3850RPMs. Pump 98 fuel
VS the Garrett 3071 and SS1 in .86 rear housing:
Pink light blue: GT3071
Red: ATR28SS1 in .86 Rear.
Thick blue: ATR28SS1.5 in .64 rear
I would say this turbocharger is probably good for 260rwkws internally gated. We added heaps more boost in last run how ever it didn't hold and only picked up 10kws.
Yeah there's only basically one caltex near me that I use eflex from that's on the way to work
So it's not very convinient as you always need to carry jerrycans on long drives and it's my daily and only car
Flex fuel is not a option as it will be very expensive for the tune ecu and sensor and my injectors are already very close to limits even on 4 bar fuel pressure so won't see much power over pump with e85 as I'll be capped with the amount of fuel and not turbo but I'll let my tuner decide
Hey stao was the turbo you used ext gated ?
Edited by hy_rpm
Hey Stao that ss1.5 looks very promising on the SR. Its fair to say that it would be a more responsive turbo than the ss1pu.
Just out of curiosity would it be possible to upgrade the ss1pu to the ss1.5?
Cheers
  On 04/02/2014 at 10:15 PM, discopotato03 said:
Stao I'm curious to hear what you think of compressor housing size and power levels , where you think the cut off points are for the 0.60 T04B , the 0.50 and 0.60 T04Es . The T04S is usually as big as most go and I'm curious to hear how much difference you think there is between it and the 0.60 T04E .
Also can you supply a T3 spacer plate in 15 to 20mm because I can't easily get one , GCG advertise a 20mm one but they don't have them and don't know when ...
I have their longer studs and I want the thicker spacer to cover any future updates , do once do right .
It's no secret that I don't like the S covers mainly because they look bigger even if it's not much over the T04E port shrouded one . I just can't get my head around using a supposedly 700 hp comp housing on a 4-500 hp compressor .
There are a few less common compressor housings floating around like the 0.70 AR T04B and there may even be a T04S 0.60 AR . I remember Brett telling me years back about a 2" outlet comp housing they used as an upgrade to the XR6Ts T04E one so there must be a few odd ones out there .
Thanks Stao , cheers Adrian .
There are couple of things to consider, One of them is the bell clearance. Since I machine all housings from raw castings, the physical size don't make that much of a difference, while Garrett housings are all fixed. If a larger wheel needs to be use in a small .60 T04B type of housings then I would be leaving the bell clearance higher to compensate flow. By lowering the clearance, discharge velocity is higher, which encourages better response and sharper throttle response, higher discharging temp is encouraged and flow restriction is created. In this case larger compressor housing is used in compensation for heat. Finding the perfect bell clearance in reference to individual wheels and housings, a dyno is very useful in doing that, which has been used often.
Larger compressor housings in general would have more materials, which smaller comp housings might machining through fitting certain wheels. It also allow anti surge ports to be added if required.
Yes I can supply 20mm spacers, it will cost you $40 each delivered. To purchase please message through your details.
The SS1.5 trailed is in a .64 rear housing. VNT turbine is working in progress at current stage.
Getting better response on the SR, it is more of a case of when the .64 rear end getting maxed out. SS1PU is still the largest wheel used, SS1.5 would definitely be more responsive, in theory it should not be making more power.
Hi again Stao , so much I'd like to talk about but yeah concerned about clouding your thread .
Firstly I'll pm you about that 20mm T3 spacer and the other thing I need is a GT30IW turbine housing dump flange with the first or bell mouthed tubular section welded to it .
I really wish someone made front/dump pipes for GT30/35R IWs on std manifolds for R33s because so many people have gone that way and it makes the conversion quick if you have everything else . Anyway if you can make the first bit that could save me some down time .
Compressor housings , I think Garrett has a size problem between the T04B and T04E because the B probably runs out of flow and the E is physically significantly larger . The ported shroud on the HKS style Garrett T04E is huge for what it has to do at 4" 100mm . You may have noticed that some of these housings on GT Pro S turbo have the cast sections machined off and they make their own turned section and bolt it on the front . Think they are 80 or 90mm inlets and that makes plumbing easier .
What I'm leading into with this is the FP HTA GT30 upgrades ie 71/73/76 wheels in T04S housings with machined snouts . Now I know there isn't a lot of information out about their HTA3071Rs and 73Rs and like Lithium I'm very interested to hear how they perform on RB25 roadies .
Cost aside I keep thinking surely they could get away with slightly more modestly sized comp housings than the T04S 70 AR at their power levels .
To my eyes compact things are easier things to work with and less obvious to hostile eyes . Ease and stealth are good IMO .
Last OT bit , punters make respectable power with XR6 turbos and they don't have big comp housings on them for a 4L engine . Low hot side restriction and modest boost levels I suppose .
PMing , cheers A .
Dare I say Stao could make you a .82 housing with a 6 bolt RB flange on the back of it, IWG or EWG.
  On 05/02/2014 at 1:43 AM, Manuel Kasko said:
Hey Stao,
Was there boost controller issues on the 21U highflow on 17psi?
I'm going to be going E85 on my R34 in the near future with the same high-flow and will only be looking for a high boost setting of around 18psi
PMing , cheers A .
That is a compact paragraph of questions, I will be answering them in reference to my experiences in Q&A form:
Depending on the size of the wheel that is installed. Ie. machining a .60 T04B to suit a 82mm comp wheel, it will break through. Performance wise as explained earlier, I give high bell clearance on small housings with large wheels, and low for large housings with small wheels. The end results are usually very close.
Use large housing with low bell clearance to satisfy compressor wheel flow, that maintains discharging velocity as to if it is in a smaller comp housing.
Larger compressor housings has more materials working with bigger comp wheels. Shifting compressed air, discharging volume are pretty close assuming the housing has enough materials to suit the wheel. However discharging temperature is higher out of smaller comp housings. I'm not a fan of the anti-surge slots. How ever surging is a problem for larger engines. I only use them if I suspect/predict surging issues. With the machined removable shrouds, I believe those can be replaced by solid sleeves or add in larger shrouds rectifying surge problems.
I didn't find much affects in using different comp housings on same compressor wheel, assume they are machined accordingly. Ie stock T04b comp housing (r33 comp housing) makes 376rwkws with G3 comp wheel, .large T04S .70 comp housing also made 376rwkws with G3 comp wheel with exact same response.
About the new ATR43SS1PU, It has been trailed today internally gated on E85, one of the goals in this upgrade was steady boost which the previous SS1PU had a boost tapering behavior. I'm pretty happy with today's outcome.
Power made maximum of 325rwkws on 22psi of boost. Boost holding flat with a 18psi RB bolton IWG assembly.
Compare to the boost behavior on previous SS1PU turbocharger based on Brae side mount:
Blue / Orange: Current ATR43SS1PU
Red / Green: Retired version of ATR43SS1PU
It appears that what I have done to the factory exhaust manifold (by drilling out the bottle neck) have let down a little in response. So it now have the same response pattern as an aftermarket exhaust manifold.
Rest: Retired ATR43SS1PU on Stock manifold with heaps of actuator preload.
Add:
By the way today's dyno run marked the 1800th times of dyno runs from my R33, since the start of the ATR43 project.
220kw by 4000 is a great achievement imo, good turbo there Stao.
As for 1800 runs... I thought I was doing well with 100 odd. Goes to show the reliability of the RB25 under continuous high load conditions.
Yes the SR's on the dyno 4 times and starting to make a rattle noise in the head. Tolling it back to forced motor worx for check up on Tuesday.
The RB, did it 1800 times no problems. I think most of its KMs on the clock are Dyno KMs.
imagine a buyer comes up and saying "Its a high Ks car."
I will be like: "no no its all dyno Ks"
I think Peter might have posted result below some where. I got a proper copy from Trent yesterday, It is a Rb25det Neo, with the ATR43SS2 turbocharger on pump 98.
I think the timing chain tensioner in mine is loose, sounds like as if the Chain is rubbing against some thing. Its going back to the engine builder for a proper check up.
Common for them rub on the top guide
Some people remove it
I just space it up with washers and use a s15 chain tensioner as it has finer adjustment otherwise you have to replace the timing chain and guides as it has stretched or the guides are worn and you have to remove the cover to do so which means engine out head off and int sump off
