Some updates. This is in relation to the ATR43G3 turbocharger. This prototype runs our latest rear wheel, how ever I will be installing it into a smaller rear hopping for more power while retaining the same drive ability.
Test car is currently on E85, the goal would be 350rwkws+ on 20psi with full boost reached by or before 4000RPMs. In which should achieve 300rwkws at 20psi on pump 98 fuel.
Results for above:
I usually make a base model and tune it against its older version. If it is a success then integrate the SS compressor for better response. So both models gets upgraded.
Sorry I didn't get any names in the package, I assume you are the guy from WA correct? if so then yes it has been received. just more power in this upgrade?
Crap i forgot to stick that on the box >.<
Sorry.
Yeh, newer profile like the ss2.
Then if you can send it off to scotty for External goodness
Also PM me the money you need.
Edited by jay-rod
im trying to find some ss2 graphs...
What power would be expected from a ss2 running e85
6boost mani
External waste gate
power fc
z32afm
no exhaust
1000cc injectors
plazmaman plenum
front mount
Excellent, i didn't think it would become that much of a restriction. Good news!
Also, sorry for such a noobish question, but what size is the rear housing on the SS2? .82?
I said external gate in the first post!
God damn i am getting ridiculously keen for this! RB25/30 NEO + 6Boost + TiAL + ID1000 + E85
My poor bank balance :(
  • Like 1
rajab damn i am getting ridiculously keen for this! RB25/30 NEO + 6Boost + TiAL + ID1000 + E85
you did so!
fuark I am blind.. been at work too long today
No the SS3 is about 300rpms laggier then SS2.
The power / response trade is: 1KW:10RPMs.
Take the SS Alpha trailed for example:
SS2 makes 383rwkws 20psi by 3500RPMs
SS3 makes 407rwkws 20psi by 3800RPMs
    • I would not replace the gauges. A well setup tune should never require any of that. I'm of the opinion that if you can't safely hand over a car to your parents to drive it's not fit for purpose and more engineering work should be done. Honestly I'm not a fan of external boost controller boxes either but if you have to you can shove the controller into the glovebox or something once it's set up. Tee it off the OEM MAP sensor. Also you probably want to put a two pin plug on the new solenoid, bolting it to the OEM location works. Just separate the wastegate line and compressor outlet so it will work on a 3 port solenoid, kevboost was walked through how to do this on an RB26, same idea just different locations on an RB25. You may have to remove the restrictor in the OEM hoses if they're still in there.
    • Yep, it's why in Australia we never brought in the 1 child policy like China.  China can't afford to use the shit they make in their own country as it's too much to risk having only one child...  Or maybe that's how they test their shit before they send it to Australia - they use the second kid that families had when they weren't supposed to as the tester?  They weren't supposed to exist in the first place so no loss if they succumb to a work place incident?  🤣
    • It's also the reason neither Duncan or I can own a car rotisserie
    • this is the reason we have more than one child right?
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
