that kia must be a laugh to drive....throw some m/ts on the front and go down the princes highway on a friday night...
cheers
darren
About 1 launch and youd snap something lol
Thought there might be some more interest in this thread,
I'm selling an SS1 I recently purchased for my RB20. Need the cash unfortunately.
http://www.skylinesaustralia.com/forums/topic/441479-sa-hypergear-ss1-turbo-brand-new/
Here my dyno results from my ss1.5 on my sr20det non VCt 180sx
266rwkw ss1.5 .86ar
250rwkw ss1.5 .64ar
251rwkw atr28g2 .64ar
Power vs boost
Power vs torque
Tuner said there was 5-10kw more in it if I replaced my dw300 fuel pump for a walbro 460lph pump as fuel pressure was dropping 10psi under load when tested but not worth the money and extra to tune right now as turbo is at it's max and injectors will be too as I'm on e85
The .86ar did gain 16rwkw but at 250rpm lag penalty and 5psi more down low and 2-3psi more up top
So it did make the engine happier as he could add in lots more timing and more boost
where as before I was capped to 20psi with .64ar or he had to remove lots of timing with more boost to the point power went down with more boost
Any dyno reading from that tune? The SS2 on Jared's car is the Black edition, with the latest compressor and larger turbine. It should be making power easier then the previous version.
A result sent in from an SS1PU customer. This is the latest version also that has a different compressor that is engineered to hold boost better and more top end.
It is running on E85 maxing out fuel pump. Peek of 301rwkws @ 17psi. With plenty of mid range.
From customer's feed back letter:
R34 GTT (Stock Motor)
Supporting Mods
Blitz FMIC Return Flow
1000cc Injectors
Standard Airbox (Panel Filter)
3inch Bellmouth Full Exhaust
Z32 AFM
Walbro 255 Fuel Pump
SS1PU (latest model)
Scotty's Alloy Intake
CALTEX E-Flex
301.8 Rwkw (18psi peak, drops off to 17psi holds well)
Is this internal or external gate. Far out there are so many options haha, and I have the exact same mods and I'm getting it done at pulse racing... May save me some time
Drives a lot nicer now it's tuned to the .86rear
Part throttle still has power but haven't done a lot of driving yet as I just got it tuned
But I was surprised it didn't lose much response going from the .64 to .86 200rpm if they where both on 20psi was expecting it to be worse and laggier about 500rpm but engine is a lot happier
Should have waited alil longer as the atr28ss2 would have been a lot better everywhere and make more power down low and up top
This is an internally gated bolton upgrade turbo that sits on factory manifold, dump, and water lines. It is an very responsive turbo for around the 260rwkws mark on P98 fuel. Alternatively you can run the new SS2 which would be good enough for 300rwkws on pump 98 fuel.
I'm missing something - I think his is on E85 and it maxed out making just over 260rwkw? Or you mean 300kw @ hubs?
    • Getting Dangerously close to being ready to go back in the car. Rockers in with clearance castings now (and a quick check with the USA for the torque settings for the larger custom bolts) Covers and ported FAST Manifold sitting on there. Not fully tightened down as there's some clearancing required for the water pump with the earlier LS1 water pump styles. Example of the clearancing needing to be done: The body has to be ground a little but I'm struggling finding an actual piece of it. The later variant of water pump resolves the issue as the manifold was designed around it. It only came on the VZ LS1 in Australia, it got a different pulley for Gen4 motors. (it also costs $450... vs... $0).
    • https://files.fm/f/5atwkuvcjd
    • Doing some height adjustment on front suspension on a v35 and noticed this. The passenger side looks correct. So wondering what's happened to the drivers side?
    • Oh...I have the electric mirrors as well iirc ...they're in the same state as just about every other R31 door mirrors, with the 3 plastic screw towers broken/cracked in the plastic molding. All the interior is 'dry', so the mirror switches etc likely all work fine. Some pics below of the trimmer pieces ~ looks to me like previous owner, painted chrome finished trims with black paint ...ergo, the chrome underneath is likely a-ok... ...starts to look yukky posting stuff like this, how much did it cost in fuel on your last sortie up this way?...me just thinking aloud, borrow someone else's 4cyl to cut costs, come do your own pick'n'pull like before to save me some bother...hehe.. but whatever, I'll just earmark bits I know you want, because the way this is all panning out, I'll be able to retire the R31 from daily duty at long last, replacing it with a Subaru wagon I'm lining up in the wings...ergo, my attitude towards the donor pinny shell is starting to wane a bit, and I'm more than happy to help you out there... Like you say though, no rush...and I'll guarantee we won't be moving too far from this locale at any rate 😎
    • Cool, I’m just down Sydney today. Not much time to get online.
