What's the deal with people taking blurry cropped photos!?!
Was there only one shot left on the film?
The conspiracy theorist in me says that if the photo was clear it would show 12.8 !
Either way 120mph is a great result especially for that turbo.
Not sure what it might be in this case. Same customer posted up a bluer photo of his quarter result on facebook. I will update an more accurate result once I get a responds.
The new wheel combination seems to be working nicely inside 1JZGTE VVTi CT15B housings as well.
Latest result:
Toyota Soarer
1JZGTE VVTi Manual
Car has 650 cc injectors
PFC ECU
Front mount cooler
3 inches turbo back exhaust
Aftermarket exhaust manifold
3 inches metal induction pipe with pod filter.
Most power made was 312rwkws @ 23psi, Left on 293rwkws @ 20psi. Car makes 200rwkws by 4000RPMs with excellent on road driving ability.
Got my new apexi intake today measured 3.5inches
That and a new walbro 450lph pump to replace my old dw300 will hopefully see my ss1.5 sr20 at 280kw
As we tested fuel pressure and it was dropping 6-10 psi up top on the dyno as I'm running a extra bar of fuel pressure over std and my fuel pump can't keep up
Afr were going from 12 to 12.5 as fuel pressure dropped so may gain 5-10kw if we can keep afr constant and Tao tested the 2.5inch intake vs 3inch was 13kw
Will get it retuned in a few months after I buy a new fuel pump
I'm on nismo 740cc side feed injectors and trying to squeeze the most out of then as I'm on e85
43psi base + 14.7psi ontop of base and 25psi boost that's 83psi fuel pressure so flow from the dw300 will drop drastically
Yeah is still slighty down on power to Tao but new intake and pump should put it closer to Tao results
Also most dynos vary abit but a true indication of the power will be down the quarter mile which I'll be testing soon
So far at 250kw trapped 120mph
260kw trapped 122mph
I'm going to test it as is now and after I put on the new intake and pump
Some results sent in from B-Rice:
This is standard 21U high flow on E85 managing 292rwkws on E85 fuel and factory actuator:
Clutch is slipping little up top, and I believe an high pressure actuator should be able to hold boost straight with a gain of another 30kws.
A result sent in from an SS1PU customer. This is the latest version also that has a different compressor that is engineered to hold boost better and more top end.
It is running on E85 maxing out fuel pump. Peek of 301rwkws @ 17psi. With plenty of mid range.
From customer's feed back letter:
R34 GTT (Stock Motor)
Supporting Mods
Blitz FMIC Return Flow
1000cc Injectors
Standard Airbox (Panel Filter)
3inch Bellmouth Full Exhaust
Z32 AFM
Walbro 255 Fuel Pump
SS1PU (latest model)
Scotty's Alloy Intake
CALTEX E-Flex
301.8 Rwkw (18psi peak, drops off to 17psi holds well)
I did a rough overlay of these results with B-rice's
It looks to me like the highflow r34 turbo is one of the top performers in the 300rwkw E85 range
Unless im a total twat and have farked this up haha
Actually, I think it was a R33 21U high flowed turbo. The updated high flow probably works out to be similar to a SS1PU.
There are two profiles for the OP6, we can still use the old configuration which keeps it responsive and maxing out towards 260rwkws while the later configurations would be maxing towards 300rwkws with more lag.
I'm working on a new version of high flow for Rb20det motors. The expected out come will be very similar to a 2530. Will update photos as its been completed.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
