That above is a ATR43SSG4 core, so similar what it originally was.
The VNT system do work and I've been using them a while now for anti lag. This specific method has the potential to knock off about 500RPMs of lag without trading off power. How ever has to be very specific to the amount of back pressure the turbine housing is receiving. Little like setting up Ign timing which at specific point they will allow the engine to output its highest torque while otherwise results the opposite. Some thing worked so well on the RB25det worked horribly on the Kia's High comp G4GC motor. So getting this to work on the Rb30det it will require a new round of research and development.
Posting an result. This is from a SS2 Based High flow that we did for a Auto M35 stagea not too long ago. It made 275rwkws on 20psi with Pump 98 fuel.
Note: The WOT was engaged in a slow manner on run below, for the reliability of factory Auto.
That pic raises another question Tao , is the compressor housing on your turbo a 0.70 AR T04B one ? The larger ratio B housing is one we don't see too often though I don't know why . It would have a bit more flow capacity than the 0.60AR B housing while being more compact than the T04E or T04S ones .
0.70AR B housings have larger 2.5" (63mm) outlets like 0.70 AR S ones .
A .
And any one into Nissan patrol 4.2L Diesels ? High flowed stock turbo made 121awkws on 15psi maxing out stock fuel pump. Stock turbocharger maxed at 81awkws.
  • Like 1
My SLSS2 turned up today
Looks good sitting next to my old highflow paperweight :)attachicon.gifImageUploadedBySAU Community1399964974.687270.jpg
WTF happened to that compressor wheel? What highflow was that?
It is a Kinugawa highflow. The oil feed line let go while coming onto the highway in second at high revs.
  • Like 1
Hoookay
Some initial feedback on the TD06SL220.5G
My car is hardly sorted atm
but is as follows
Dead Standard 1JZ-GTE and Auto
ETM 6 into 1 merge collector manifold
Hypergear 50mm External gate
3" dump pipe into a 2 1/4" mid pipe into a 2 1/4" twin system (yuck!)
factory ECU
So initial drive
Builds boost at around the same RPM as the standard turbos...but feels like it needs a little more throttle to do so
Once it sees around 0.2bar and 3000ish rpm it comes on like a light switch even at under half throttle (no WOT runs re: standard ECU) running the 0.8Bar gate pressure
This combo is going to have a monster mid range once I finish the new exhaust (3.5" with a Hooker super comp aero chamber muffler) and fit the ECU and fuel system
but I feel it is not going to be linear, feels like it will always be a light switch turbo, but comes on early enough to not be a huge worry, however I will report back once its tuned and I drive it in the wet.
    • That’s a beautiful setup Tao, Have u done any development with the new Turbosmart 40mm electronic straight gate, especially in this G30 configuration?
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
