if you hold down the mode button on mode 1 2 3 & 4 is the gain 20 all the way through them? you can set it differently for each mode by holding down the mode button for three seconds then adjusting with the select button.
Yes, Gain is 20 all the way through channels 1 to 4.
If you are using a Mac solenoid for boost control. I'm not if this EBC allow different gain settings at different RPMS which some ECU support. You can can use perhaps 50% gain down low and 100% gain after 5000. But either way the SS2 should have a slight creeping behavior working with a EBC, I think the drop could be related to insufficient supply of air or discharge of hot air inside the exhaust. See if boost level changes after 5000RPMs without air box lid and mesh filter first, then try a hollow cat ( I can lend u one if you need ).
This is a newer high flow profile available for Rb20det owners. It is very specifically aimed at response. The profile configuration works out very close to a 2871 in 52T. Maximum power wise would be expected around the 230rwkws mark depending on supporting mods and amount of boost given.
Just to correct some mis-information i gave...the gain is the same all the way through because you can't set it individually for each mode. each setup is different but i've found a gain of 30 and setting of 60 to work well to 1.18bar or if i want a different response i set gain to 7 and setting to 71 which gives me 1.18-1.2 bar.
Thanks man. Yes I thought it might be the case that there's only one global gain setting. So mine is currently at setting 55 and gain 20 and peaks at around 1.35 bar.
I feel that the tuner has a good job given the constraints of the EBC. The next thing I'll investigate is the possible restriction in the exhaust (cat) or intake (airbox, IC).
Best to upgrade induction and exhaust first then play with the EBC as the end result will vary.
I'm posting up an promotion on our new ATR43SS-2 internally gated bolton turbochargers so more people can enjoy our latest development. The Retail price on this item is currently $1450, you can have own them now for $999 including braided oil feeding line. The Special offer is for 20 units only. That is currently the best performing RB25det bolton turbocharger.
Product details and Dyno results are:
http://www.hypergearturbos.com/index.php?route=product/product&path=72&product_id=81
  • Like 3
This is the larger version of the 2nd generation SS2. It is 1.5mm bigger on compressor side and 3mms larger on turbine side. More power. :woot:
On the less complicated to build turbochargers. Since we have found good uses of a CNC machine that we can rent, we will be making TD06L2 based turbochargers are a very cheap price. that will be the SLSS2 and Sl20.5G turbochargers. Will update new pricing and details shortly.
I thought you had your own CNC machine? I thought that was how you make the billet compressors?
For the quantity that I'm currently doing its not worth to own. Also its only worth while using CNC making a number of identical housings at once, which in my case its different combinations for different customers. So most of the housings are still hand made on lathe on milling machine.
The SS wheels are originally just a machined version of the cast wheel, trailed and modified through time by my self. The CNC programming was done by an engineer that I hire, I also hire and work with many other engineers for different purposes on the development and manufacturing of a turbocharger.
Other thing worth mention is the CNC machine that does the profiling and machining of the comp and turbine housings are not the 5 axis machine that does the billet wheels. Those are CNC lathe and mills. One does all the machining of the horizontal profile and groves, and the other one does all the drilling and tapping of the holes. In which the Greedy comp and turbine housings that are made to run on C clip and V clamps are cheaper and quicker to produce as all aspects of machinery was done on one horizontal CNC lathe.
Can't machine a cast wheel, material is too soft. it starts as a copy of the cast wheel, which is a Billet comp wheel that is identical to a normal cast wheel, I then took it for a dyno run for a base output.
From there I modify the wheel blade shapes, tips, height, hub sizes and etc then evaluate each and single modification done to see what sort of differences it has made compare to base output on a dyno. Drawing of the better performing wheel where sent to produce in a batch. Like I've mentioned, my Skyline have done 1807 dyno runs since the start of this project, and probably made this thread containing more dyno readings then the dynosheet section plus a lot more that wasn't posted.
    • Yeah, the latter. No diff should have a centre replaced without checking clearances because its unlikely to be the same as whatever came out. Not that that stops most people just checking a new centre in
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
