  On 28/06/2014 at 11:48 AM, iruvyouskyrine said:
Also is this still correct? As i am going highmount i need to get a new oil feed line made.
so a -4 AN oil feed hose with no restrictor in it will be fine for the SS2?
Yep thats what you need
Excellent cheers mani!
Also, any more video of your car man? I'm addicted to how well that thing destroys tyres haha
I can swap your current dump assembly with a Blanking plate for external gating. Just unbolt it and send it in when ready.
The oil line if its for a high mount you will need it to be in a meter long, the length will be a dash 4, no restrictors.
Not sure how everyone has good results with Five O 1200cc sidefeeds. I barely can get the car to idle unless it rich as shit.
(this is on 98RON, hoping on E85 it idles better as it requires more fuel)
On the upside, I've got plenty of fuel now. Gave it a few good hits at 1.4bar, and car pulls pretty hard. Hiring a dyno probably in a fortnight, let's see what she pumps out.
If in doubt about the flow matching, just run the next size up drill bit through them mate. Sheelberight. :P
gahhh... you bastard LOL...
tempted to convert to top feed (yes yes, I should have listened).. however on a SR20DET they work well, this is probably due to head design.. RB seems to have more material in the middle of each intake ports hence a fire hydrant fuel injector doesn't "dribble" down properly.
Thanks stao
Drove my brothers s13 with the atr28ss2 on actuator pressure 15-16 psi and goes good but he has a s15 motor and VCt still not tuned yet soon
Might get mine tuned before him
Start to strip the head tomorrow
  On 30/06/2014 at 4:50 AM, Ben C34 said:
So old tech injectors still suck? ;)
hahahhaa... I bought some replacements (actually bought 2, 1x spare)
  On 30/06/2014 at 4:54 AM, hy_rpm said:
Stao upgrade me to a atr28ss2 as part of a evaluation test can wait to put it on
Was perfect timing as I needed to replace the headgasket on my sr20det
attachicon.gifImageUploadedBySAU Community1404103991.742113.jpgattachicon.gifImageUploadedBySAU Community1404104013.390620.jpg
man.. that looks sexy :)
haha cheers mate, heres another one from a couple of months ago https://www.youtube.com/watch?v=AOdfjhrf9nU
  On 30/06/2014 at 5:15 AM, hy_rpm said:
Thanks stao
No worries. Personal opinion that is one of the best turbochargers I've trailed so far on the S14. Had another customer with a 180sx reported 280rwkws on P98 fuel with full boost by 4300RPMs. Will post result once its emailed through.
Some footages from John Reco. That is the World time attach, fastest lap of 1.05 sec.
Running 700cc injectors, PFC, Our high flowed 21U R33 turbo internally gated, E85 fuel, Tuned by Chequrered tuning, Making 310rwkws @ 20psi.
is it only the 1200s that you find idle problems with? cause Ive got the 1000s in mine and even before a tune from just me setting the corrections it idled perfect like stock injectors but Im also on e85 so that might be helping things.
I've installed a similar set, however 1000cc on a SR20DET and it idled and drove well without missing - although on the rich side.
With the same set, but in 1200cc on a RB25DET they're horrible!
I would imagine on E85 it would be better as you require more fuel on idle.
Probably time to man up and go to united next weekend lol
The 1200cc on E85 worked fine on my car, apart from one seized up.
Alternatively check out Deschwerks 1000ccs. I've used three sets of their injectors and sold many with the KIA kits to China, no issues so far.
Like I've been told previously by Unigroup on s14/s15 sr20det engines the highflows have a chance of working as it hits the head ports and sort of atomizes the fuel where as on a s13 sr20det it's aimed right at the intake valves and spray like a garden hose on jet mode
May be similar on a rb25 depending on where the injectors aim
Have you ever ran them on 98 though?
E85 "should" mask up the garden hose effect as up to 30% more fuel is required to idle, not to mention more timing too.
I had similar AFR issues on my mate's S15. After visiting united and me tweaking his tune the injectors do exactly what I tell them to do (massive thread on nissansilvia.com) however without the misfire and stumbling on idle and light cruise.
On a RB25DET though they're a croc of shit with 98RON - I can lean them out but the car misses like a 2 stroke mower. Had to pump so much latency into the settings the car now just idles about 12.5 but at least it's not stumbling around.
I read up on NASIOC and guys have the same issue with these injectors on their EJs, they just can't seem to have any control with normal pump fuel and however success rate increases with E85.
So time for E85 and bye bye whatever economy I had lol
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
