^ just rips some skids, if the car doesn't kick like a mad man when you're going sideways you know it's not a VLSD.. and before anyone goes "just shim it" man a real diff vs. a shimmed diff are light years apart :)
I've done the shimmed business, locked weldy crap, to a 1way and now a 2way.... a proper diff goes a long way!
So what are then lengths of the 1/2 injectors do they fit under the intake or still need to cut stuff, are they shorter then the xpurt 40mm ones?
Edited by boostn0199
The 1/2 length ones are the ones ARTZ used to do his top feed upgrade, from his photos he had loads of room without needing to grind down the plenum like the US kits I've seen which use full height top feeds.
I've emailed the site and waiting for a reply. I'm a little pissed off at the Five O Motorsport injectors, they've pissed me off since I've used them on my car whereas on a mate's car o had pretty good control over them.
I have never seen the Siemens copy EV14's. Good prices too, although the rail won't support the 3/4 length injectors like the Proflow/Aeroflow rails do. They look to be the same length as the 40mm Xspurts, (1/2 length.)
I would still recommend the ethanol rated injectors for anyone running e85.
Also note, don't ever buy used high flows.. I made that mistake, ended up with 1x dud and bought 2 brand new ones.... can't really blame the seller either, but hope he didn't sell me known dodgy ones because I would loose my shit if he did.
Or at least get them flow tested ;) Cheap insurance.
I did haha, backyard styles
Also swapped to my old rail, does have that rubber hose on the return.
Finish off my head install and turbo the atr28ss2 comes on fullboost about 4000rpm but has that large gtx turbo howl and mad slow vl echo dose
Book in for a tune this Thursday
My brothers s13 drives a lot nicer down low and more responsive maybe due to s15 motor and VCt but top end power is amazing
What is the spray pattern on these like? like a hose I'm guessing?
Looks like a $2 reject shop water pistol LOL, at least they're "matched" hahaha
If anyone wants a rolling review/discussion(s) about Five O Motorsport 1000cc and 1200cc Side Feed Injectors go here:
http://nissansilvia.com/forums/index.php?showtopic=2441472
Talks about 98RON and E85, SR20DET and RB25DET usage and both 1000cc and 1200cc formats.
New Result sent in. This is from our TD06 SL20.5. Final result of 358rwkws @ 19psi. On an R33 Skyline unopened engine, 40mm external gate, fuel and ecu mods, E85 Fuel.
The same car had an Kando's TD06 SL2 20G before turbo change. This is an direct comparison between the two.
Can you confirm there are no other changes between those two runs? And was the lower boost on the 20G due to not being able to flow it? It's quite a different power curve shape, good power etc however :)
Far as I know it was old turbo off, new turbo on. And every thing bolted back in place.
The 20G started to run out of puff around 5000RPMs as the boost curve started to decline. This is the latest version of of the SL20.5 also, with SS2 compressor wheel, It should crack 380rwkws towards 24psi.
Some updates. This is in reference to our CT15B 1JZ VVti high flow.
Quoted from: Eyebeclubin from JZX World:
Vehicle: JZX100 Chaser
Transmission: Manual - r154
Turbo: Hypergear CT15b High-Flow 3076r spec
Fuel: BP Ultimate 98ron
Supporting Mods:
- Power FC
- Denso 850cc Injectors
- Walbro 450lph pump e85 compatible
- HPI Dump pipe
- Tomei cams - intake 250deg, exhaust 260deg
- HKS EVC 5 Gold Edition
- Pod filter
Power & Torque Curves
Sad motor with Tomei M8280 Vs Hypergear High-Flow With happy Motor + Tomei Cams & BC Springs
Thin curve Tomei arms m8280
Thick curve Hypergear + Tomei Cams
Low Boost @ 15psi 250rhkw @ 6620rpm, 437Nm @ 3360rpm
High Boost @ 20psi 278rhkw @ 6463rpm, 510Nm @ 3495rpm
Tomeim8280VsHypergearhi-flow_zps114b65ba
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
    • @Dose Pipe Sutututu I read your replies RE: R35 GTR MAFs, any ideal spots to put on? Obviously will need the adapter plate. Will be having a cross over intercooler fitted shortly, would putting it a bit before the TB be okay?
