Johnilicte: I'm doing a little bit of Noob tuning at moment following course from HPA. Would you be able to share some experiences in tuning Nissan VTC system in areas of ignition, fuel and dis/engagement? I'm using adaptronic ecu. Thanks.
of course, e-mail me all your questions and I shall answer ..
Long story short with VTC enabled you produce more torque due to higher cylinder pressure thus the motor can only take less timing, as soon as it disengages torque will drop off - reducing cylinder pressure allowing you to ramp up timing again. From my limited tuning experience, motors with a shorter stroke will prefer a mild ignition ramp after peak torque, where as a longer stroke motor i.e. SR OR 4G likes loads of timing hammered into it after peak torque.
Best way to determine where to disengage VTC... setup a mild timing map with VTC on a few thousand RPM past peak torque ~6500rpm (of course monitoring knock) do a dyno run, then set the VTC point around 4500rpm do another run..
Overlay the two torque curves and you will see your optimum VTC disengagement point.
Of course after you do that, you can start ramping more timing after VTC disengagement and tune for power up top.
That's a quick run down of it.
Just a note, I've never worked with variable cam timing and variable lift.. RBs and SRs use a fixed on and off point which makes tuning easy for an amateur like me.
In terms of injection, VE is closely related to torque.. more torque higher VE so it's natural you see your VE decline as your torque drops off.. this is the beauty of VE tuning.. makes tuning easier
Thought i would post up my results of Stao's fantastic handywork. My car has sat in my garage for 1.5 years, and finally got round to fixing it.
Unopened RB25
Pretty much the usual stuff.
740cc injectors
PFC
Greddy rad and cooler.
Scotty Intake
Just a typical hiflow which i bought 15 months ago. I was told it would see 230kw on 98 and roughly 260 on e85.
Anyway today i picked my car up and got this:post-75784-0-29419900-1405668770_thumb.jpg
All on BP98. Might be interesting if i put it on the juice.
Highest run was 265.
Unopened RB25
740cc injectors
PFC
Scotty Intake
Anyway today i picked my car up and got this:attachicon.gifIMG_0171.JPG
is it an R33 highflow? the new ones can make around 270 rwkw around 20-22psi on 98 so your result is very good for around the 17psi mark. Personally I wouldn't push it to 20psi on a stock motor on 98 but it's possible.
The old highflows maxed out around 230 I think.
on e85 the new highflow makes around 320rwkw around 22psi
Been running 20psi on a hypergear turbo as a daily for 2 years now :)
Boost doesn't kill engines it's detonation that kills engines.
  • Like 1
Dont mean to interupt but what do you mean new hi flows?
@Johnilicite: Thanks for the info. Using the adaptronic ECU in the VVT tab. This is for the Kia sportage. would you know what those sittings are corresponding for? Thanks.
And Grimsy. Thanks for submitting the dyno result. This is using the current profile, the very distinct difference between the two, is the current model has no issues holding boost and much happier taking on timing. Great work.
My brother got his s13 road tuned today with atr28ss2 and s15 VCt motor only on 20psi due to running pump 98
Goes good but definately doesn't feel as fast as my 180sx but power feels very linear and comes on instantly
Not like mine as it hit 3500-4000rpm there's a big surge in power and throws you back or tyres fry
We will soon see the difference as were going to the drags soon
Thanks for the feed back.
Everyone getting in on those HPA courses atm!
cheers
darren
I do highly recommend people go on the HPA site and at least acknowledge the content in EFI fundamentals and road tuning before even think of modifying any cars.
It would contain a good entry level information for a brief understanding of what the tuner does, what a good tune is, and how power and torque is generated in relation with supporting mods installed.
#@hypergear - with constant variable timing this is where it gets really fun/confusing as the cam timing varies over RPM & LOAD, i.e. MAP
Ignoring the duty cycle settings (determines how much duty is required to shift the cam actuator) & and the controller gains (closed loop calculations P = proportion gain at present correction, I = Integral gain past correction, D = derivative gain future correction)
VVT1 = Intake Cam
VVT2 = Exhaust Cam
VVT1 = uses Fuel 2 table to set the angle, which is depending on RPM & MAP - this makes it 3 dimensional, that being (RPM, MAP and angle of advance/retard).. so as MAP increases and/or RPM increases the timing changes. If you click Target Angles it will take you directly to Fuel 2 table.. please note the values showing in there are not fuel correction values.
VVT2 = uses just a standard RPM table, there's only 2 dimensions in there.. that being the RPM and the angle of advance/retard of the cam
Unfortunately I've never tuned cars with varying cam timing so I can't input too much here.. I've always worked with Nissan's dinosaur on/off timing (which makes tuning much easier too) :)
But I can imagine as RPM increases you would want the advance on the intake to decay i.e. retard, however at the same time you want to advance the exhaust cam as RPM increases to promote more air being "pumped".
http://www.learntotune.com/
for anyone interested..
cheers
darren
Yep, did that! :D Going for a 1 on 1 course at Unigroup Engineering once i register my 300ZX :D
Anyone used Siemens Deka V injectors? they come in "short" length, i.e. 48mm end to end OR 35mm O-ring to O-ring?
They seem to be pretty good based on these tests:
http://racetronix.com/product/Injectors/FI114700_Brochure.pdf
I've been trying to redo my injector needs by finding a cheaper alternative (yes I'm being cheap, but I can't envisage spending $1.2k+ on stuff when the motor cost the same price)
Posting some updates:
Been dummying some direct bolt for Holden VL Turbos. This particular one is made based on our ATR43G3 turbocharger. Factory 2.5 inches cast dump is not replaced with a full 3 inches dump including a much larger 38mm internal gate. Expected to support 260~280rwkws on a RB30ET with supporting mods on P98 fuel. Bigger profiled turbochargers can also be be built based on the same turbine housing configuration. That includes our ATR43SS2 (500HP), SS3(530HP), SS4(550HP) and G4(600HP) models.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
    • Yeah just run one of those posts to the Link like GTSBoy said. From google it looks like a "mishimoto boost controller" is a manual boost controller. Since you already have the link just buy any MAC valve and plumb it in where the mishimoto is now. Wires to the solenoid should come from the Link's / standard loom boost control wiring (I guess you have an r32, not sure if it is gtst or gtr, if it is GTR where is a 2 pin connector near the engine bay fuse box/injector resistor for that purpose, assuming the standard boost controller is gone)
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
