Funny my new gtr 33 just did 270rwkws with front drive shaft taken out. Fully stock with 3inches turbo bacm exhust. Not sure if the last version of gtr33 had some tricks into its sleeves.
Nah that's about right
I seen a r32 gtr with just catback dynoed at Unigroup back awhile ago made 250rwkw on rwd dyno std computer
And I was struggling to make 230rwkw on my sr20 cams turbo injector afm tune
6cylinders especially gtr make power very easy
Sounds off, doubt its a stock ECU tbh. Seem more than a few of them struggle to hit 260 tuned on standard turbos.
12% I think is the agreed difference between awkw and rwkw for the GTRs.
270/1.12 = 241 awkw which sounds about right if it's missing the boost restrictor?
Most R33/4 owners wouldn't bother on a RWD dyno due to having to remove the front shaft. Whereas on the R32 its as simple as pulling a fuse, or flicking a switch if you've got it hooked up that way
Edited by Blackkers
But a highest reading out of a stock GTR on this dyno was 207rwkws on factory tune. My boost curve appears to be laggier also, but not as laggy as the N-1. Pretty much spot on with -9s. But every thing is stock. Its the only Navy Blue GTR Trent's ever seen either. I always gets stooged with cars that makes stupid power.
This is power vs a normal GTR33 on stock ecu:
Boost vs Stock R33 GTR:
And AFR
Timing, ignition, fuel, AFR, Pretty much every thing is spot on. Std GTR 33 tuned with PFC was getting 245rwkws on 14psi. While this is fully standard with a cat back exhaust. It felt very different to drive compare to other GTR 33s I've looked recently, I was expecting around 180rwkws not 270rwkws.
So well this is my base line for this GTR.
+1 for the 'not actually stock turbos'
Given -7's and -9's and -5's look identical from the outside to stock turbos, I'm going to say they aren't
...they are also what Hypergear are up against in terms of 'bolt on 100% legal high flow-looking' turbo options, curious to see if Stao can get turbos to respond that well and make 375rwkw on E85 and look entirely standard which is what a -9 will do
Or more than 500+rwkw which is what gtx2863 fronts will do in standard housings :P
The previous owner is a farmer, he knew nothing about cars, it was sitting in his garage for a long time. He said he only driven it to his mechanic for a oil change every 4 month, and clocked 4000KMs for the past 5 years. He's wife made him to sale it.
I'm more interested in the Rb26dett power and response thread. I will be starting with a single setup once the manifold is ready. Too much hassle getting E85 when needed, This car will be running on P98 fuel.
Update compared to my previous result with the following changes:
1. Rebuilt actuator arm by Stao with more preload (around 3mm) - this is a Z shaped one as opposed to the original straight rod
2. Rebuilt & tucked in exhaust system:
  • JJR bellmouth - bottom half has been recut/customised to run as close to the floor as possible
  • Venom 5" cat - bought without flanges, which were welded on at the exhaust shop for best alignment
  • HKS Super Drager cat back (R33 coupe model) - mid muffler replaced and moved further back for better clearance, most of the piping redone in 3"...
3. Retune at Chasers
Result: 275rwkw @ ~20psi, BP 98 Octane (red line)
Without airbox lid, snorkel and filter: 285rwkw (top blue line)
It also has better response than before so the actuator and exhaust mods have helped.
The intake is restricting it a bit and I reckon that the Trust turnflow might be at its limits, too.
Thanks heaps Stao and others for your help on this!!
Great drifting :thumbsup:
Result sent in, This is our ATR45 turbo on an Ford XR6 BA. Final result of 400rwkws on P98 fuel internally gated bolton at 19psi of boost.
  • Like 1
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
    • Emissions, fuel consumption, heat, noise, etc. most likely.
    • For me at least the reason why it bothers me is because it's indicative of a deeper problem. And that will nag at me forever. Especially because I have tailpipe emissions testing + evap leak testing every 2 years.
    • WELP. I went to the track, and I suppose it went okay because any time you can drive home is okay. You may notice the car is not on the circuit in this picture. It was about 35C day out in Benalla which means the track was approximately the surface of the sun, probably. Good things, car did not overheat but it _was_ warmer than when I had done track days in similar heat before, I think, I'm not sure - I can't quite remember. Coolant got to ~105 via the ECU after 20-30 minutes of belting it in said heat. Oil got up to 145C in one instance which is pretty crazy due to oil cooler. Pressures were fine. I seem to remember this not getting quite so high before the vents. More HMMMM'ing to be done. On the subject of HMMM'ing, can anyone identify the sounds in the video below, you will know which ones I mean: https://www.youtube.com/watch?v=uj3BkI2cbTc I included some 'normal' sound as a reference for the first minute or so. The microphone in this instance was where the license plate is. It stopped working later in the day which is why my "best example of a lap video (not produced)" had internal audio - Isn't hearable from inside the car. I don't mean the chirping of the un-bedded/badly bedded track brakes which you can only hear while braking... Thoughts, brains trust?
