Funny my new gtr 33 just did 270rwkws with front drive shaft taken out. Fully stock with 3inches turbo bacm exhust. Not sure if the last version of gtr33 had some tricks into its sleeves.
Nah that's about right
I seen a r32 gtr with just catback dynoed at Unigroup back awhile ago made 250rwkw on rwd dyno std computer
And I was struggling to make 230rwkw on my sr20 cams turbo injector afm tune
6cylinders especially gtr make power very easy
Sounds off, doubt its a stock ECU tbh. Seem more than a few of them struggle to hit 260 tuned on standard turbos.
12% I think is the agreed difference between awkw and rwkw for the GTRs.
270/1.12 = 241 awkw which sounds about right if it's missing the boost restrictor?
Most R33/4 owners wouldn't bother on a RWD dyno due to having to remove the front shaft. Whereas on the R32 its as simple as pulling a fuse, or flicking a switch if you've got it hooked up that way
Edited by Blackkers
But a highest reading out of a stock GTR on this dyno was 207rwkws on factory tune. My boost curve appears to be laggier also, but not as laggy as the N-1. Pretty much spot on with -9s. But every thing is stock. Its the only Navy Blue GTR Trent's ever seen either. I always gets stooged with cars that makes stupid power.
This is power vs a normal GTR33 on stock ecu:
Boost vs Stock R33 GTR:
And AFR
Timing, ignition, fuel, AFR, Pretty much every thing is spot on. Std GTR 33 tuned with PFC was getting 245rwkws on 14psi. While this is fully standard with a cat back exhaust. It felt very different to drive compare to other GTR 33s I've looked recently, I was expecting around 180rwkws not 270rwkws.
So well this is my base line for this GTR.
+1 for the 'not actually stock turbos'
Given -7's and -9's and -5's look identical from the outside to stock turbos, I'm going to say they aren't
...they are also what Hypergear are up against in terms of 'bolt on 100% legal high flow-looking' turbo options, curious to see if Stao can get turbos to respond that well and make 375rwkw on E85 and look entirely standard which is what a -9 will do
Or more than 500+rwkw which is what gtx2863 fronts will do in standard housings :P
The previous owner is a farmer, he knew nothing about cars, it was sitting in his garage for a long time. He said he only driven it to his mechanic for a oil change every 4 month, and clocked 4000KMs for the past 5 years. He's wife made him to sale it.
I'm more interested in the Rb26dett power and response thread. I will be starting with a single setup once the manifold is ready. Too much hassle getting E85 when needed, This car will be running on P98 fuel.
Update compared to my previous result with the following changes:
1. Rebuilt actuator arm by Stao with more preload (around 3mm) - this is a Z shaped one as opposed to the original straight rod
2. Rebuilt & tucked in exhaust system:
  • JJR bellmouth - bottom half has been recut/customised to run as close to the floor as possible
  • Venom 5" cat - bought without flanges, which were welded on at the exhaust shop for best alignment
  • HKS Super Drager cat back (R33 coupe model) - mid muffler replaced and moved further back for better clearance, most of the piping redone in 3"...
3. Retune at Chasers
Result: 275rwkw @ ~20psi, BP 98 Octane (red line)
Without airbox lid, snorkel and filter: 285rwkw (top blue line)
It also has better response than before so the actuator and exhaust mods have helped.
The intake is restricting it a bit and I reckon that the Trust turnflow might be at its limits, too.
Thanks heaps Stao and others for your help on this!!
Great drifting :thumbsup:
Result sent in, This is our ATR45 turbo on an Ford XR6 BA. Final result of 400rwkws on P98 fuel internally gated bolton at 19psi of boost.
  • Like 1
    • They're supposed to not be compatible.
    • Evening fam, Pretty much what the title asks, I have looked all over and can’t find a proper answer expect one post from almost a decade ago which is vague. ive seen photos and they look pretty much identical, would an r33 GTR N1 reo work on an r32? reason I ask is they are cheaper to buy… $700 compared to 1k+ for an r32 n1 reo
    • Couldn't help myself, had to start putting it together.... It really is a solid bit of kit.  Probably stronger than i would have made it myself to be fair! 🤣🤣 Sweating like a pig after that.  Bloody hot and muggy day today, time for a swim now!
    • Yeah was thinking that. I've had the car go lower idle possibly around 650rpm every once in a long time after pouring fuel and would sound quite rough like a misfire, almost like it's shit fuel or something but who knows.
    • @Wazmond you are correct, my bad, was not my intent    https://www.facebook.com/share/15ZMn5oXtc/ Updated Event (so its not private and can be shared easier)  Attempting to coordinate a big push of Stagea's to this years GTR Festival. Great event last year and hoping for the same this year.    I've emailed them to ask to set a location aside for the Stageas for the show and shine - they are happy to do so if we can get them numbers, I'm happy to keep track of that. Entering as Nismo category.    I'll be road tripping up from Melbourne, would be cool to convey if people are interested, maybe there is SAU convoys from each capital? If you have ideas about that let me know.    https://gtrfestival.com.au
