Funny my new gtr 33 just did 270rwkws with front drive shaft taken out. Fully stock with 3inches turbo bacm exhust. Not sure if the last version of gtr33 had some tricks into its sleeves.
Nah that's about right
I seen a r32 gtr with just catback dynoed at Unigroup back awhile ago made 250rwkw on rwd dyno std computer
And I was struggling to make 230rwkw on my sr20 cams turbo injector afm tune
6cylinders especially gtr make power very easy
Sounds off, doubt its a stock ECU tbh. Seem more than a few of them struggle to hit 260 tuned on standard turbos.
12% I think is the agreed difference between awkw and rwkw for the GTRs.
270/1.12 = 241 awkw which sounds about right if it's missing the boost restrictor?
Most R33/4 owners wouldn't bother on a RWD dyno due to having to remove the front shaft. Whereas on the R32 its as simple as pulling a fuse, or flicking a switch if you've got it hooked up that way
Edited by Blackkers
But a highest reading out of a stock GTR on this dyno was 207rwkws on factory tune. My boost curve appears to be laggier also, but not as laggy as the N-1. Pretty much spot on with -9s. But every thing is stock. Its the only Navy Blue GTR Trent's ever seen either. I always gets stooged with cars that makes stupid power.
This is power vs a normal GTR33 on stock ecu:
Boost vs Stock R33 GTR:
And AFR
Timing, ignition, fuel, AFR, Pretty much every thing is spot on. Std GTR 33 tuned with PFC was getting 245rwkws on 14psi. While this is fully standard with a cat back exhaust. It felt very different to drive compare to other GTR 33s I've looked recently, I was expecting around 180rwkws not 270rwkws.
So well this is my base line for this GTR.
+1 for the 'not actually stock turbos'
Given -7's and -9's and -5's look identical from the outside to stock turbos, I'm going to say they aren't
...they are also what Hypergear are up against in terms of 'bolt on 100% legal high flow-looking' turbo options, curious to see if Stao can get turbos to respond that well and make 375rwkw on E85 and look entirely standard which is what a -9 will do
Or more than 500+rwkw which is what gtx2863 fronts will do in standard housings :P
The previous owner is a farmer, he knew nothing about cars, it was sitting in his garage for a long time. He said he only driven it to his mechanic for a oil change every 4 month, and clocked 4000KMs for the past 5 years. He's wife made him to sale it.
I'm more interested in the Rb26dett power and response thread. I will be starting with a single setup once the manifold is ready. Too much hassle getting E85 when needed, This car will be running on P98 fuel.
Update compared to my previous result with the following changes:
1. Rebuilt actuator arm by Stao with more preload (around 3mm) - this is a Z shaped one as opposed to the original straight rod
2. Rebuilt & tucked in exhaust system:
  • JJR bellmouth - bottom half has been recut/customised to run as close to the floor as possible
  • Venom 5" cat - bought without flanges, which were welded on at the exhaust shop for best alignment
  • HKS Super Drager cat back (R33 coupe model) - mid muffler replaced and moved further back for better clearance, most of the piping redone in 3"...
3. Retune at Chasers
Result: 275rwkw @ ~20psi, BP 98 Octane (red line)
Without airbox lid, snorkel and filter: 285rwkw (top blue line)
It also has better response than before so the actuator and exhaust mods have helped.
The intake is restricting it a bit and I reckon that the Trust turnflow might be at its limits, too.
Thanks heaps Stao and others for your help on this!!
Great drifting :thumbsup:
Result sent in, This is our ATR45 turbo on an Ford XR6 BA. Final result of 400rwkws on P98 fuel internally gated bolton at 19psi of boost.
  • Like 1
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
