I've built a a pair for Chequrered tuning's LS1 V8, that is mainly getting the advantage of running extra timing for the high comp V8. I'm awaiting on the manifold for my GTR, So I don't currently have a result for this particular turbocharger. Are you looking for some thing that suits a Rb20det?
How ever I have do have an result using the exact same compressor and turbine, except been in a VNT housing. You can reference to the ATR43SS4-Alpha model. That would give you an approximate peek power and boost to power ratio.
While I'm in here, I have twin GT-RSs on my RB2630 and the rear wheels are choking it up top, is there an option to fit a bigger turbine wheel ?
Just a quick update. I'm in the process of making a 55mm exhaust wheel for SR20det motor. That is a mm a side bigger then your GTRs turbine all around. I will doing some evaluations ready, they should be the solution for your current issue on the Rb2630 and pickup more mid / top rang torque also.
Haha oops, for some reason I thought they where 11 blade, was thinking of something else :/
How long till you start doing these and what would be a guesstimate of cost to rebuild two turbos with these wheels ?
Grinding shaft at moment, probably two weeks away. If you wish to send me the compressor wheel I can definitely build them with the new exhaust wheel.
Some updates. Those are videos sent in by John Reco, fastest lap SAU VIC track day last week. Fastest lap:
Hypergear 21U highflow turbo on standard manifold
Havoc custom pipework and exhaust
Chequred Tuning 300kw responsive tune E85
Motul Fluids 8100 15w50, Comp Gear Oil & RBF600
Tyrepower Frankston wheel alignment
4.3 Diff gears
285/30 R18 Yokohama Neova AD08R
  • Like 1
Should be able to customize turbine housings. Depending on what sort of car it is for.
Further development into the ATR28SS Alpha Series based my S14 with a SR20det motor using BC S2 cams.
This is a base line for CBB SS2 Alpha version, Vnt is not current engaged. Final result of 302rwkws on 24psi P98 fuel.
SS2 Alpha Base line compare to Standard SS2:
Makes the same amount of power, but is slightly more responsive.
Base line Vs Garrett GT2871R in .64 rear:
Its currently making 190rwkws and 21psi @ 4000RPM. It drives pretty good the way it is. The goal would be matching the GT2871 curve without losing any top end.
So I am helping someone make their RB25 Skyline go a bit quicker, so after much discussion the choice to go with an ATR43-SS2 was made - as soon as we nut out how to best pay across international borders we may have the first Hypergear turbo on NZ soil that I am aware of. Looking forward to checking one of these things out in person after all the discussion, and will be nice to have first hand experience of the SS2 :)
If I'm allowed I'll post results after we are done with it - will be internally gated, stock manifolds all around, BP98 on a stock internal RB25.
  • Like 1
Firstly sorry for being lazy. But what is the best direct bolt in turbo for an R33 gts on E85 shooting for around 400rwhp with as much response as poss. Or is it worth going external gate and or big dump?
Depending on how lenient the dyno is he will be getting about 340-370 hp around there, varies alot with dyno's.
Thats at 16-20 psi
I'll be tuning the internally gated one on BP98 with a Dynapack hub dyno, probably not as tough an audience as you guys are overall used to - though similar to some. Will probably go for around 18psi, but will see how knock limited it is and decide whether to go higher from there.
SS1PU Internal Gate will do it, I personally prefer to run an external gate because you can sneak in more timing
Thanks
Is the ATR43ss2 a lot bigger or ok for what I'm looking at? Don't mind going external gate, prob off exhaust housing.
This is for a track car.
    • Welcome back, glad to hear life's wheel is turning in the right direction
    • Awesome pics Rezz, thanks for sharing them Another stop for my "need to do in Japan" list
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
