Not sure if trolling :huh: Either way, pretty sure we had a yarn on this very topic almost a year ago you were talking camshaft design, I remember wondering if you were really listening to my side of the conversation or not. Perhaps I have my answer to that? :whistling:
Production line style tuning can work it lots of cases, especially if applied to identical setups but I tend to be a bit more fussy/cautious about it and prefer to not tell people or apply rules blindly to every setup everywhere without some forethought or testing to ensure things are definitely going to turn out the way intended - but that is just me. The car would at the very least need to be retuned to suit a drastic change like this, imho.
No I'm serious, the "guy" I recommended these settings to was Hypergear who has a stock engine with stock cams as far as I have read
This why I said try these settings because I have tried and tested all different setting with stock RB26 engines and these are good for response with mid-top end on a stock production engine and this was intended as a good starting point to try
I didn't recommend these to some random dude on a forum but to Hypergear and will add Blackers to this, I assumed Hypergear who build turbos for a living and does everything on a dyno and Blackers who if I'm right is affiliated with MoTec somehow would automaticly understand that these need to be set from a corrected 0deg and should be done then tested on a dyno, are you saying that was wrong on my behalf and that I should have spelled that out to them ?
We probably did have this discussion but as you said it was about cam designing and not stock cams, the fact I don't remember could be a couple of reasons, 1 it was about a year ago and I have a lot going on and don't remember every conversation I have on a forum or 2, I thought about what you said and dismissed it as wrong and moved on
As for these settings they where given to enhance a stock engine not a highly modified highly strung race weapon with custom cams and will work with any stock camed RB26 head regardless of the bottom end providing the base cam timing is +/- 2 deg from 0
and again I have been reminded I should bother trying to help anyone cause clearly I have no idea and the results I have gotten from my cars was just a fluke and the 32 I managed to do before ever stepping foot into SAU so I'm still not sure how that could have happened or even been possible
This is the last post I will post in this thread in regards to this matter if you want to continue this take it to PM
keep calm and boost on! :) on a side note and hopefully dragging it back to hypergear thread.... i'll be recieving my atr43ss2 in the next week or two and getting the fabrication work done towards the end of October, Then it'll be on the dyno to see what my old donk will do. A question for those who have done it. would there be any 'noticable' benefit to using adjustable cam gears on stock cams for an RB25det.
You can fit a adjustable exhaust cam gear for very slight gains. As for the intake you cant because of the vct.
The stock vct gear is adjustable, but from the back. You have to take it off to adjust it.
I made a thing so it can be adjusted from the front, then found out it had already been made by others years ago and isn't much use anyway.
Edited by Ben C34
John Richo's Phillip Island footage. 1.447 run:
Car is currently using one of our current 21U high flows making a super responsive 320rwkws on E85 fuel.
  • Like 1
recieved my ATR43ss2 today, can't wait to get it fabricated up. One question, the CHRA has four waterfeed/returns. 2 have bolts in them and the other 2 plastic bungs...how should i hook these up properly?
oil feed from block
oil return to sump
water in
water out
just follow the stock lines easy, I hope you've asked for Tao's optional oil feed line.. makes fitting much easier.
I also bought the Kando dim sim yum cha braided water line set off eBay - makes fitting much easier than using the stock lines.
yeah i've taken the plugs off...one is shallow which i think is return and one is deep which i think is feed. I'm guessing this is so the turbo can be mounted on either side of the engine e.g for exhaust on other side of engine like toyota.
The SLSS2 is an externally gated Vband version of the ATR43-SS2. They are the same turbo just different housings for different applications.
  • Like 1
With the plug supplied, plug up two of the holes and connect waters to any of the two that are open. Alternatively you can remove the plug and run it oil cooled only. The thread fitting on them is M14x1.5
  • Like 1
Spent some time this weekend evaluating the SS Alpha turbos on the GTR. First thing to notice is the Rb26dett engine do require an large exhaust side to run, It chocked the engine after 5000RPM using the combination of the SS2 turbine wheel in .82 housing.
it was replaced it with an large 76mm turbine that I've made for high flows, that worked pretty sweet. The engine bay was noticeably cooler also.
Looking abit more serious now :rolleyes: .
Because the effect of quart throttle, the car has an throw-out effect on throttle movement, this makes an laggy turbo feels not as obvious. The VNT system have made an noticeable torque increase down low, especially on partial throttle opening. This is a bigger turbo compare to the Sl20.5, but definitely feels more responsive to drive. Be interested to see what the dyno says in about a week, I'm currently waiting for some coil packs to turn up from Japan.
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
