ATR43 SS-2 Rb25det Stagea. Externally gated from stock exhaust manifold E85 fuel. Final result of 356rwkws @ 22psi on Dyna dynamic dyno:
Further testing and evaluation on the SS2.5 Alpha turbocharger, now using an 600x300x68mm tube n fine front mount cooler. I've attached two photos, note the tubing size inside the aftermarket cooler and factory cooler.
Aftermarket cooler:
Stock cooler:
Using the new intercooler, boost tapering issue was resolved to some extend and the same turbocharger managed to pickup more power. Cooling ability however is not as good as standard, under comparison my intake temp rise by 10 degrees. I will be fitting an thicker 600x300x100mm cooler for further evaluations coming week.
Turbocharger wise, it is matching factory N1's responds but a lot more power. Pretty good to drive at this stage.
ATR43SS2.5 Alpha, externally gated on pump 98 fuel. Peek 330awkws:
Vs stock cooler using the same turbo:
In conclusion based on test result, the factory GTR intercooler is only good for up to 320rwkws on pump fuel, for upgrade, I would be recommending a good cooler that has a core size of 600x300x100mm.
Tuned by Trent Hewitson, Intercooler piping and related fabrication done by Havoc Fabrications.
  • Like 1
All three GTR coolers are different, the 33 is best for cooling efficiency but worst for outright flow
My 105mm ARC cooler ( the best in the business) is about 4-6deg hotter then the factory 34 cooler but will happierly flow 1000hp
As I mentioned to Tao yesterday, Daz has made 500kw on a stock cooler and is heading for more. Not sure yet if he plans to upgrade his cooler this time around.
Yeah Ive heard of 450kw before
It isn't stock, it's 90 mm thick.
Weird that they're all different. How does the 32 cooler go?
And for people whom are switching to the ID 1000 injectors. The resister pack made for OEM injectors has to be removed. Big thanks for M35scotty on solving this issue yesterday. I believe he has some technical details to share.
The 32 is the best for flow but worst for efficiency, it is extrude honed and doesn't have the little fine fins inside the runners
You can tell the difference between 32 and 33 by the front of the runners, the 33 has a grove that runs along the runner which the 32 doesn't
That is something very simple and well known, simple cut the resistor off and solder the seven wires together then a bit of heat shrink and electrical tape and bingo high imp injectors working
  • Like 1
One of his injectors had stopped working, after testing it I realised he hadn't cut the resistor pack off, one resistor had blown taking the power from that injector.
The resistor pack was much hotter than usual. Obviously it runs fine on the Haltech without modification, but overloads the resistors. Goes to show the Haltech runs some great output drivers.
Um, aren't the injectors on a GTR a negative trigger, so all the ecu has to do is earth them
That's the reason you remove the resistor, cause it's no longer needed and the high imp injectors will fry it
Sweet it should be better for e85 to a certain extent then as it doesn't need the efficiency that it would for 98
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
