ATR43 SS-2 Rb25det Stagea. Externally gated from stock exhaust manifold E85 fuel. Final result of 356rwkws @ 22psi on Dyna dynamic dyno:
Further testing and evaluation on the SS2.5 Alpha turbocharger, now using an 600x300x68mm tube n fine front mount cooler. I've attached two photos, note the tubing size inside the aftermarket cooler and factory cooler.
Aftermarket cooler:
Stock cooler:
Using the new intercooler, boost tapering issue was resolved to some extend and the same turbocharger managed to pickup more power. Cooling ability however is not as good as standard, under comparison my intake temp rise by 10 degrees. I will be fitting an thicker 600x300x100mm cooler for further evaluations coming week.
Turbocharger wise, it is matching factory N1's responds but a lot more power. Pretty good to drive at this stage.
ATR43SS2.5 Alpha, externally gated on pump 98 fuel. Peek 330awkws:
Vs stock cooler using the same turbo:
In conclusion based on test result, the factory GTR intercooler is only good for up to 320rwkws on pump fuel, for upgrade, I would be recommending a good cooler that has a core size of 600x300x100mm.
Tuned by Trent Hewitson, Intercooler piping and related fabrication done by Havoc Fabrications.
  • Like 1
All three GTR coolers are different, the 33 is best for cooling efficiency but worst for outright flow
My 105mm ARC cooler ( the best in the business) is about 4-6deg hotter then the factory 34 cooler but will happierly flow 1000hp
As I mentioned to Tao yesterday, Daz has made 500kw on a stock cooler and is heading for more. Not sure yet if he plans to upgrade his cooler this time around.
Yeah Ive heard of 450kw before
It isn't stock, it's 90 mm thick.
Weird that they're all different. How does the 32 cooler go?
And for people whom are switching to the ID 1000 injectors. The resister pack made for OEM injectors has to be removed. Big thanks for M35scotty on solving this issue yesterday. I believe he has some technical details to share.
The 32 is the best for flow but worst for efficiency, it is extrude honed and doesn't have the little fine fins inside the runners
You can tell the difference between 32 and 33 by the front of the runners, the 33 has a grove that runs along the runner which the 32 doesn't
That is something very simple and well known, simple cut the resistor off and solder the seven wires together then a bit of heat shrink and electrical tape and bingo high imp injectors working
  • Like 1
One of his injectors had stopped working, after testing it I realised he hadn't cut the resistor pack off, one resistor had blown taking the power from that injector.
The resistor pack was much hotter than usual. Obviously it runs fine on the Haltech without modification, but overloads the resistors. Goes to show the Haltech runs some great output drivers.
Um, aren't the injectors on a GTR a negative trigger, so all the ecu has to do is earth them
That's the reason you remove the resistor, cause it's no longer needed and the high imp injectors will fry it
Sweet it should be better for e85 to a certain extent then as it doesn't need the efficiency that it would for 98
    • Welcome back, glad to hear life's wheel is turning in the right direction
    • Awesome pics Rezz, thanks for sharing them Another stop for my "need to do in Japan" list
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
