Hopefully this time the highflow lives up to it's expectations as I don't really want to pay more money to be disapointed again. Stao I will send you an email so this can be arranged in the new year :)
I can guarantee you won't be disappointed. Can't be bothered scrolling back to find out, but please make sure you have a tuneable ECU also.
  • Like 1
For 260rwkws, sell your OP6 and buy and send in a blown R33 turbo. Once that is high flowed, it will be making around 260rwkws with factory responds.
Got the GTR pulling 404akws today using a high flowed blown kando T67 (from Peter). And did back to back test with few different coolers, will upload results shortly.
  • Like 1
Wouldn't the r34 turbo be better for highflowing or does the lager rear create a lot of lag? My car has the below mods so the only piece to the puzzle missing is the turbo.
Apexi Pod
Nistune
Npc Heavy Duty Organic Clutch
Apexi AVCR boost controller
Full 3.5inch zorst
Nismo Fuel Pump
Z32 AFM
Siemens 550cc injectors
Yellow Jacket Coil Packs
HDI Front Mount
So as you can see my car is capable of making some decent power just need the right turbo to do so.
Edited by DoseVader
it is wonderful that you came to this realisation yourself.
incidentally plenty of info from a search.
you are in fact all set for a sweet setup after highflowing your R34 'OP6' turbo
enjoy
enjoy
Can't be any more laggy then my current highflow setup, full boost at 5,000rpm thats living barry
Then you'd find the r34 hypergear highflow a blessing
I still need to sort my Pfc boost control setting out properly to get the boost right in the upper mid range, but it pulls nicely from 3500 rpm onwards, got 276 rwkw, power delivery is very linear and easy to drive
Good part about the highflow is it essentially bolts on, so installation is easier if you're doing it yourself.
Anyone feel free to correct me if I'm wrong but I thought the ss1PU is designed to be able to pull the same max power as the OP6 highflow with even better response?
Yes SS1PU is made to do the same sort of power as the OP6 high flow but with stock alike response, thats a very good option as well.
As mentioned earlier I've upgraded the intercooler on the R33 GTR from 600x300x68mm to 600x300x100mm. Using the same ATR43SS25 Alpha turbocharger, it managed to hold more boost on less boost controller duty, 10 degrees less in air temp, picked up more mid to top range, and the penalty in response is 100RPM.
By now, I have a good platform for turbocharger related evaluation and testing.
Also for few customers reports boost tappering issues on their RBs. Check your pressure drop across your intercooler. Some of you might be surprised of how much boost it actually restricts.
Below is a dyno log on a ATR45 using a return flow cooler, with customer defending for his 20 Cents junk.
Green is before cooler, and Red/pink is after cooler.
I found this issue with people using Blitz front mount and return flows also. If this is a scenario on your setup, get a tube n fin, 600x300x100mm cooler, we can supply that for under $200, and that has been tested and works.
+1, get the high flow - meets all your requirements and lighter on the pocket. I got the SS2 because I wanted a dyno queen LOL
Tell the truth Johnny you just wanted GAAAAAAAATTTEEEE! :D
Intercooler restriction. that car made identical amount of power using OP6 high flow, SS2 and now a G4 (3582 equivalent). They all can only be boosted to 16psi with actuator disconnected. Similar behavior to when I was using stock GTR33 cooler, this one is alot worse.
This is result from the Peter's dead T67 earlier, It is now rebuilt and high flowed running our ATR43G4 CHRA assembly, pulled 404awkws E85, fuel pump leaned out. Its now tested and ready for pickup. This assembly is good enough to pull around 430awkws with a new pump. I don't think I will be chasing for more power at this stage, But will be working to get better response.
Video added:
Told ya so Mark lol ;)
Hehe, that you did Mick. Been plenty of decent results with Blitz coolers before though (at around 250-260rwkW Mark), which was why I was wondering if the pressure drop is more noticeable at higher boost.
Anyways, thanks for posting those results Stao.
ATR43SS2.5 Alpha final run on E85, GTR-R33. made 367awkws on 20psi.
I've included dyno videos of the same turbocharger running both P98 and E85 fuel:
Fine, I'm not going to lie. I wanted gate LOL
Fek all those Honda homo vtecs, I has gate... Don't be mad :D
Exactly what I thought when I bought my blitz return flow, time for a new cooler it seems..
What cooler was it Tao?
Edited by owen1r
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
