We only do engineering related work, when collecting the turbo I can direct you to a good mechanic whom might be close to your area.
All good, I'll get my local guy to do it.
I've decided to go the ss2.
How much for an ss2 with everything required to bolt it up and what pressure is the wastegate actuator set to stock?
The turbo fits stock manifold, dump, water lines and oil drain. You will need a proper metal induction pipe to be made and a 2.5inches silicon hose in 90 degrees. You can pm m35scotty for the induction pipe. Manifold spacer is required and supplied, 4 longer manifold studs are required.
The actuator is set to around 17psi, final boost level depends on how free flow every else are.
I need lower boost than that, ie ~12psi. That's what my car is currently running so need to get it around there so it's somewhat driveable. Is that possible?
Probably best to control boost with foot. if the initial boost level it set too low, the turbo will not be able to hold boost up top.
Do you have a ~10psi actuator you could supply fitted to it with the 17psi one that I can change to later?
The car won't see much use until I get some injectors and a tune but I do want to be able to drive it in the mean time if necessary and trying to limit the boost with the throttle is just not practical. It's not my daily so it's not likely I'll need it but if I do then it'll be a 400km day in traffic so boost needs to be kept under control properly.
Edited by Cowboy1600
If i set the internal gate at 10psi. When supporting mods are available, this turbo will not hold any boost that is beyond 16psi. Itnwill not make the target power. I can make a flow restrictor that sits on front of the turbo instead.
Its the size of the gate of the gate. The actuator tension has some effect in mid range but not enough control in upper rev when back pressure increases.
Hey stao, have fitted up the SS2 you supplied to my brothers R33 , runs at 0.8bar, even at this pressure it pulls pretty hard, I would compare it to be very similar to the GT3076 and GTX3076 I had on my car,
although his car seems to be one of those cars that just hauls.. lol
Edited by AngryRB
  • Like 1
The gtr is for sale, from experience it will take a while that leaves me with plenty of time. Im going back to rb25det and looking to start a new venture modifying x6 turbos
  • Like 2
The xr6 turbo venture will be interesting, where are you going to post results to that?
will suit performance rb30 stuff better than some stuff you sell atm which is rb25 based and chokes on rb30s
cheers
darren
Hey Stao,
Finally got around to fitting a 21U highflow i bought off you half a year ago as the gt2871rs finally died from track abuse lol.
Couldn't be happier with performance. Similar (and i think slightly better) response than a gt2871rs but much stronger mid and top end when on hi boost.
Final figures were 21psi for 305rwkw track friendly tune, wastegate pressure gave 270rwkw which was around 18-19psi.
Tuner mentioned he was very surprised by the turbo and impressed with the smoothness/power delivery.
I'd offer dyno printout but we tuned it on crap road tires and high boost just ended up wheelspinning on the dyno haha, causing a really jagged powerline.
Will also mention power comes on much more progressive than my old turbo, so much so that even at high boost, my car grips 2nd with no fuss and this is all on a circuit setup so camber, toe, stiffer springs/dampers etc.
Thank you :)
Edited by Touge Kyousou
  • Like 1
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
