DoseVader Posted February 6, 2015 Share Posted February 6, 2015 Hey Stao, Finally got around to fitting a 21U highflow i bought off you half a year ago as the gt2871rs finally died from track abuse lol. Couldn't be happier with performance. Similar (and i think slightly better) response than a gt2871rs but much stronger mid and top end when on hi boost. Final figures were 21psi for 305rwkw track friendly tune, wastegate pressure gave 270rwkw which was around 18-19psi. Tuner mentioned he was very surprised by the turbo and impressed with the smoothness/power delivery. I'd offer dyno printout but we tuned it on crap road tires and high boost just ended up wheelspinning on the dyno haha, causing a really jagged powerline. Will also mention power comes on much more progressive than my old turbo, so much so that even at high boost, my car grips 2nd with no fuss and this is all on a circuit setup so camber, toe, stiffer springs/dampers etc. Thank you This makes me really keen to install my 21u highflow I just got Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/529/#findComment-7474197 Share on other sites More sharing options...
jet_r31 Posted February 7, 2015 Share Posted February 7, 2015 whats your brief with the xr6 turbos Stao? response monsters or are you going to make some mid frame t3 flanged 67 ish mm inducer t04z sized turbos aswell? cheers darren Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/529/#findComment-7474807 Share on other sites More sharing options...
hypergear Posted February 7, 2015 Author Share Posted February 7, 2015 Thanks for the feedbacks guys. I should have enough time in finishing off the GTR before the car gets sold. With the XR6, I'm looking particularly into manual FG turbos and good ones are quite pricey. I've done few big custom built turbos for BAs and even with 1.26 rear running a 120mm compressor they spooled up like high flows on R33s. Most people are more concert about bending con-rods and snapping drive trans instead. I will be into making GT45 equivalent CHRAs and see how they work inside stock FG housings. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/529/#findComment-7474858 Share on other sites More sharing options...
jet_r31 Posted February 7, 2015 Share Posted February 7, 2015 (edited) so you going to try fit a 79mm ish inducer and 80mm turbine into the t3 1.06 housing and .70 t04s comp cover(or factory .60?) i really have no idea, but i would have thought the money /market share would be in GTX3582 to 64-67mm inducer to4z sized bolt on stuff? Thats high 9 sec stuff already in a big falcon if you did that, you would also cater to the Rb30 sohc and 3.0l skyline crowd with just a exhaust housing change and kill 2birds with one stone cheers darren Edited February 7, 2015 by jet_r31 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/529/#findComment-7474890 Share on other sites More sharing options...
hypergear Posted February 9, 2015 Author Share Posted February 9, 2015 Testing and evaluated our latest turbocharger for the GTR33. This is a Special Application Turbocharger engineered to be externally gated working with Rb25det an Rb26det engines. This is the most responsive single turbocharger that ever made 411rwkws on Trent's dyno out of a standard Rb26dett engine. Peek 411rwkws @ 26psi E85 fuel We took a few runs to setup the EBC and this is power and boost graphs from 20psi to 25psi. Vs an other RB26dett with similar mods using a GT3582 in .82 rear: This used to be the former most responsive single for a RB26det. This car is running HKS270 Dur cams, with Active VCT inlet cam. It is using an Garrett GTX3582R. ATR45 SAT managed to beat it in both peek power and responds using factory cams and cam gear. However even I've had more boost down low, the VCT head always had the advantage of drawing more air. Dark blue and Red are running similar boost levels. Against my TD06SL2-20.5G in 10cm Turbine: Light blue: ATR45 SAT, Dark Blue: TD06SL2-20.5 in 10cm Turbine. In theory, fitting this turbocharger on a Rb25det, it should produce the identical responds as a TD06SL2-20G in 10cm turbine, while maxing out over 400rwkws. I'm pretty happy with its overall outcome. I will be doing further evaluations with few more wheels that I've made, hopping to reach better power and responds. 1 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/529/#findComment-7476406 Share on other sites More sharing options...
petero'nell Posted February 9, 2015 Share Posted February 9, 2015 Got results of it on a RB25det motor? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/529/#findComment-7476518 Share on other sites More sharing options...
Artic Choc Posted February 9, 2015 Share Posted February 9, 2015 Wow looks like a great turbo stao, good results, might be interested in one when i go top mount Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/529/#findComment-7476605 Share on other sites More sharing options...
dori34 Posted February 14, 2015 Share Posted February 14, 2015 can anyone confirm if the 21U R33 hiflow can reuse OEM intake or do I require a 3" intake? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/529/#findComment-7479661 Share on other sites More sharing options...
Badgaz Posted February 14, 2015 Share Posted February 14, 2015 You could use it but it will probably collapse under high boost pressure. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/529/#findComment-7479683 Share on other sites More sharing options...
dori34 Posted February 14, 2015 Share Posted February 14, 2015 what about a silicon intake pipe with the spring inside or is metal intake pipe the way to go ? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/529/#findComment-7479738 Share on other sites More sharing options...
dontyellpl0x Posted February 14, 2015 Share Posted February 14, 2015 Scotty's 3" intake is a work of art Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/529/#findComment-7479750 Share on other sites More sharing options...
Mick_o Posted February 14, 2015 Share Posted February 14, 2015 Not trying to knock your result Stao but i noticed you only ran the 35R up to 25psi? A 35R will keep making power past 25psi no worries. So not an entirely true statement about making more power than the 35R Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/529/#findComment-7479754 Share on other sites More sharing options...
Badgaz Posted February 14, 2015 Share Posted February 14, 2015 what about a silicon intake pipe with the spring inside or is metal intake pipe the way to go ? Metal intake is the way to go. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/529/#findComment-7479757 Share on other sites More sharing options...
Super Drager Posted February 14, 2015 Share Posted February 14, 2015 (edited) Stao are you able to highflow GT2860-5 turbos to GTX2867 or equivalent? I bought a parts car that was making 360rwkw on 98RON with the 2860's but i'm hoping to go a bit further than that. Edited February 14, 2015 by Super Drager Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/529/#findComment-7479801 Share on other sites More sharing options...
hypergear Posted February 14, 2015 Author Share Posted February 14, 2015 Not trying to knock your result Stao but i noticed you only ran the 35R up to 25psi? A 35R will keep making power past 25psi no worries. So not an entirely true statement about making more power than the 35R I've posted results on different boost levels, so its not necessarily of making more power but much better response and drive ability. When I trailed GT35 with my forged RB25det it stopped making power at 431rwkws at 29psi, This particular turbo will be making the same amount of power except I don't think this engine will take that boost. Goal is responsive 400awkws, this is the best one so far and I'm trailing an updated prototype next week hopping to hit 20psi and 200awkws by 4000rpm. Yes I can high flow GTR turbos with -5 equivalent using our ATR28G1 CHRA or SS15 which probably works out similar to a GTX2867. They are very laggy on RB26 engine tho. For the amount of money I recommending of getting a proper high mount setup and use the new SAT version of ATR45SS. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/529/#findComment-7479819 Share on other sites More sharing options...
Super Drager Posted February 14, 2015 Share Posted February 14, 2015 I've posted results on different boost levels, so its not necessarily of making more power but much better response and drive ability. When I trailed GT35 with my forged RB25det it stopped making power at 431rwkws at 29psi, This particular turbo will be making the same amount of power except I don't think this engine will take that boost. Goal is responsive 400awkws, this is the best one so far and I'm trailing an updated prototype next week hopping to hit 20psi and 200awkws by 4000rpm. Yes I can high flow GTR turbos with -5 equivalent using our ATR28G1 CHRA or SS15 which probably works out similar to a GTX2867. They are very laggy on RB26 engine tho. For the amount of money I recommending of getting a proper high mount setup and use the new SAT version of ATR45SS. No i meant putting a GTX2867 core into GT2860-5 housings, on a VG30DETT engine though. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/529/#findComment-7479828 Share on other sites More sharing options...
hypergear Posted February 14, 2015 Author Share Posted February 14, 2015 Yes I can machine the housings to suit. It will cost you $100 per housing to machine. I'm pretty sure their turbine wheels are the same. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/529/#findComment-7479923 Share on other sites More sharing options...
Super Drager Posted February 14, 2015 Share Posted February 14, 2015 Just had a quick look and yes the turbine end looks to be the same, do you think these kinugawa GTX comp wheels would be any good?http://www.ebay.com.au/itm/Billet-Turbo-Compressor-Wheel-Garrett-GTX2867R-49-7-67-4-Trim-55-11-0-/271774042157?pt=LH_DefaultDomain_15&hash=item3f46fec82dIf its possible to machine the housings, fit and balance the comp wheel then i'd be happy. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/529/#findComment-7479948 Share on other sites More sharing options...
AUSBen31T Posted February 14, 2015 Share Posted February 14, 2015 (edited) Picked up this bad boy today after reading all 530 pages of this thread Going onto an RB25det NEO in my R31 Ti - Sard 650cc injectors (pretty rubbish) - 2.5" cooler piping from turbo to t/b, 510x250x65 intercooler tube and fin (may be a restriction) - 3" dump pipe, highflow 4" bodied metal cat, 3" exhaust with 2 straight through mufflers - Aeromotive 340 stealth pump - Nistune ER34 board - Hypergear ATR43SS2 with op6 rear end to suit - IWG welded up - Turbosmart 40mm comp gate welded onto housing - Screamer slash cut at passanger foot well - 3" metal intake - Z32 AFM - Stock R31 airbox with highflow 'drift' filter and rear of lid chopped out (loses ALOT of power with unmodified lid, tbh most likely going to fabricate a custom airbox with panel filter.) Hoping for 300 on P98 but will be more than satisfied with 280ish. Going to trial nistunes feature pack flex fuel most likely as well and bang some ID1000s or similar in for when i want more power. However on a R31 live rear axle with a poo rebuilt LSD that works when it feels like. will be a bit death lol. Photo of the bay with the current GCG highflow that is going into my mates 31 Edited February 14, 2015 by AUSBen31T Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/529/#findComment-7479959 Share on other sites More sharing options...
Marcus89 Posted February 14, 2015 Share Posted February 14, 2015 this makes me think you spent waaaay too much on a 31. Either way it's going to be a monster Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/529/#findComment-7479963 Share on other sites More sharing options...
