few bits to check on:
3inches or bigger Metal induction pipe with Pod filter.
Check pressure drop across intercooler
3inches or larger turbo back exhaust, all flanges has to be in 3inches, Cat has to be in 100 cell, no cat gives the best result.
Tension up the actuator rod.
Further update. This is the ATR45 SAT version for RB26, I've trailed the ball bearing version, and it have made a very slight increase in response. I'm hitting the MAP limit for the Haltech ecu, will be installing an 3 bars maps sensor shortly.
Result against Standard Bush bearing model:
Also running against my factory twins:
Any decent tuner would have dropped the exhaust after the dump...
its the first port of call after an unexpected result.
Edited by Missileman
He sure did drop the exhaust.
The catco 3" metal high flow cat was brand new and installed by dvs. Hence why he dropped the muffler only. Jjr dump front pipe also 3" bell mouth brand new installed by him.
Unigroup reckons even new cats can cause restrictions.
We will see tomorrow
I'll keep you all updated
Edited by Therealsandybang
That's what I said. But I have to go through the detective work with the tuners which is a costly and painful process
Although they are both great to deal with.
I seem to remember 2 threads where there was a low power output, one was the GTX3067 thread and other Hanaldo's thread, correct me if im wrong but I think both had return flow intercoolers and JJR dump pipes..
Edited by AngryRB
  • Like 1
Some intercoolers restricts, and I've found that with my stock GTR cooler as well. I've posted few examples here, Do a log with boost sourced before the cooler and see if that matches the reading on the sheet.
GTX3067 results were with return flow cooler, but dump is custom 3". That was thought to be an issue, but changed with zero difference.
I'm interested to see results of this investigation here.
Also how good does the adaptronic go compared to the likes of Vi-Pec/Link/Haltech ect in plug/play versions ofc. What can you do the Adaptronic for $$$'s wise with the sensors ill need and everything to just plug it in and set it up to go haha
I personally have not used Vi-Pec but I can comment on the Haltech & Adaptronic.
Haltech is more refined, has enough drivers to run full sequential injection & ignition where as the adaptronic is semi-sequential due to the lack of output, but Adaptronic has native serial input for most widebands and also direct flex sensor connection where as Haltech you will need to use an analog 0-5v input and if you want more inputs you'll need a pricy IO expansion box where as the adaptronic just pull off the cover and hook up additional sensors. Also adaptronic has a built-in 4 bar (43.5 max factoring in 1 bar atmospheric pressure) map sensor where as a Haltech has a 3bar (29psi max factoring in 1 bar atmospheric pressure).
If it boils down to features and price, Adatropnic hands down. If it boils down to software refinement and out of the box driveability from day one I would go Haltech.
You dont need a Dyno to check for an intercooler restriction, its cheaper to but another boost gauge or just move the boost gauge pickup to ore intercooler and see what pressure reads.
Gentlemen,
Did decat test. Ran 235kw at 13psi with no det on Unigroup dyno which apparently reads a bit lower (that's another argument).
Still losing boost from 17-->13psi.
Tao recommended pre loading actuator. Checked bov for leaks and did a run with it blocked off. Bov is fine.
They don't seem to think it's cooler yet.
Still some sort of restriction which is opening gate and preventing boost from being held.
Pull the circlip off the wastegate pin and check that there is about 5mm (half a hole) of preload.
Start checking hose clamps and silicone joiners.
I use a JJR return flow cooler and dump pipe, they are not the cause of your problems unless installed incorrectly.
  • Like 1
Hoping mine doesn't get same issues with the .63 rear, however should be easier to hold 20psi externally gated yeah?
My cooler is 510x250x70 , tube and fin, which is worrying me a bit, however can't go any wider due to auto spoiler motors for the flip down lip on the 31. Could go to a 510x300x100 probably max.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
