Here is what happened. A mate of a customer shown interest of buying the test car, welling to pay my asking price but requested for a compression test at a known workshop that few of my customers went and have sent me a number of jobs in the past. (Not chequrered tuning or any one from the SE).
The car was perfect, drove in to the work shop. They did a comp test, all came up to 170 psi. After the plugs were put in, crank and straight way there was a knocking sound in the engine. The mechanic "one of my customer" also found a missing coil pack bolt that I know it was not missing from start. I'm 90% sure some that was dropped into a spark plug hole, but the shop owner tries to convince me its a knocking sound from end bearings. LoL. With oil pressure gauge alive and sender gage disengaged, it obviously makes no sense. I'm f*ken pissed off at this point but did not wish to turn at all those familiar faces. So that was the end of it.
I'm leaning towards of doing some work on Rb20dets. After all that's the only engine that I've missed out and the project will be very challenging.
90% of people drop rb20's in the bin. So I wouldn't bother.
What I'm interested in is RB25Neo, not DET the NA ones.
Higher compression, better response, on E85 with mild boost.
Mention is to Trent, see what he says ?
couldn't you just put a bore scope in the cylinders and see the marks it would have made as well as throw the compression tester back on there and show that its no longer the 170 across the cylinders to prove they f**ked it and 'you broke it you bought it'.
also why didn't you do the compression test yourself in your shop?
The buyer only trust that particular workshop, no one expected this issue. The car drove perfectly to the point when it was powered up again after the comp test.
The comp tester shown very little change after, its a metal "bashing around" sound from the upper half of engine. Work shop had a broken scope that can't be used. Owner offered $3.5G to rebuild that engine, to me the rest of the car's too rough to have that sort of money spent on. Buyer how ever was happy to take the way it is with $4G discount, his offer was accepted, and I'm over with it.
I'll be looking at few more skylines this week, and hopefully be back on projects shortly.
I guess the point of bring that up is my RB25det NEO did not broke because it had excess boost at it. The failure was totally none performance related. They are excellent engines.
Don't bother with rb20s.
If you're going to draw a line under RB25 turbos, which probably isn't the worst idea, I'd concentrate on XR6 turbs or perhaps something for our retarded VG cousins.... sorry Fairlady and M35 owners.....even the designation VG sounds a little retarded....
Stao, how many rb20 hiflows and atr43ss1.5 do sell a year? I bought one of your hiflow second hand and it is a bit laggy, but if you go ahead and develop something really fast spooling for an rb20 I would be interested.
That or a direct fit rb26 solution. The only options people have are -9,-7 and -5 reallly.
-9 resonse with -7 power would kill the market with direct fit.
  • Like 1
Wow thats totally bs stao.. i belive youv been in the business long enough to know what your talking about.. but there are plenty of people out there that arent as genuine unfortunately. On a side note im with most of the gang here i wouldnt bother with the rb20.. maybe rb30 turbos? Or some more rb26 bolt ons.. either way im happy
Name and shame that workshop. What a dog move.
yeahhh nah for the sake of the forum that can't be done. legal bills etc etc
anyway I vote twin-cam RB30's next! (please, i'm building one)
  • Like 1
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
