The R34 test rig is in progress and will be tuned with the latest SS2 prototype this friday, hopping for 300rwkws+ with 20psi by 3500RPM.
Just saw that and my pants tightned slightly lol
  • Like 1
Hey Tao I saw the ATR45SAT results on the standard rb26. 400kw 24psi e85. Boost comes on barely behind the standard twins! Did you have adjustable cam gears at all?
I look forward to fitting that
turbo to the 2630. I'm picking up the short block in the next few weeks so I should organise the turbo + 50mm gate asap
With the new SS2, the original print is based on the 21U high flow, except I have the freedom of using larger internal gate and different types of wheels, it is very promising.
The Rb26 ATR45SAT result, is from a unopened Rb26 engine using factory cams and cam gears. It drives extremely well on road, picks up boost nice and early in low gears and respond extremely well to throttle just like stock turbos. This turbo is designed for standard RB26 engines. By adjusting cams gears, responds should be improved that could possibly match the standard T25s.
Edited by hyper-gear
  • Like 1
Right, I've got fuel pump, clutch and injectors, all I need now is the turbo.
I was originally going for 300ish rwkw so was looking at the SS2, however the car is not a daily so why not shoot for something higher? That would be the G3 I believe?
Is there a guide on what's required to fit the G3, Stao? I will be taking it to one of the local guys for fitting so want to make sure they have everything required to get it on.
Also, what's the best way to go about making said purchase?
If its for a Neo motor, I will recommend our ATR43G4SAT model. That turbo wold be good enough to hit close to 350rwkws pump internally gated. Cost same as the G3, you can find it on our site under the ATR43 page. cheers
Hey cowboy, if its not your daily. Might i reccomend instead of doing that. Why not just go for say the 21u or the op6 On full e85? Both have seen over 300 fair easy on e95 with basic bolt ons? Just a thought :)
I've put a lot of thought into E85, and really want to go down that path, but I think that'll have to come with a flex tune one day. For now I'm going to stay pump. I sized my injectors to give me the capacity to go E85 one day.
It is for a Neo.
Is it basically bolt on?
Yes, Check my last result from a month ago. made 311rwkws on 20psi with a cooler restriction with pump fuel. It can be made as a bolton turbo. Cost $1250 inc oil line.
Is this what I need to order?
OMFG, finally, it is done.
After talking about it for what seems like years I've finally put down some cash.
ATR43G4 Ordered!
Now just need to get it all fitted.
I have the following:
Walbro 460
Id1000s
Split fires
Car already has fitted:
Exhaust
Front mount
PFC
CAI
EBC2
Iridiums - will gap down to 0.8mm
Anyone see anything I've missed?
I'm shooting for 320+ on pump.
ATR43G4 Ordered!
Walbro 460
Id1000s
Split fires
Exhaust
Front mount
PFC
CAI
EBC2
ditch the iridiums and get bcpr7es plugs.
  • Like 1
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
