The R34 test rig is in progress and will be tuned with the latest SS2 prototype this friday, hopping for 300rwkws+ with 20psi by 3500RPM.
Just saw that and my pants tightned slightly lol
  • Like 1
Hey Tao I saw the ATR45SAT results on the standard rb26. 400kw 24psi e85. Boost comes on barely behind the standard twins! Did you have adjustable cam gears at all?
I look forward to fitting that
turbo to the 2630. I'm picking up the short block in the next few weeks so I should organise the turbo + 50mm gate asap
With the new SS2, the original print is based on the 21U high flow, except I have the freedom of using larger internal gate and different types of wheels, it is very promising.
The Rb26 ATR45SAT result, is from a unopened Rb26 engine using factory cams and cam gears. It drives extremely well on road, picks up boost nice and early in low gears and respond extremely well to throttle just like stock turbos. This turbo is designed for standard RB26 engines. By adjusting cams gears, responds should be improved that could possibly match the standard T25s.
Edited by hyper-gear
  • Like 1
Right, I've got fuel pump, clutch and injectors, all I need now is the turbo.
I was originally going for 300ish rwkw so was looking at the SS2, however the car is not a daily so why not shoot for something higher? That would be the G3 I believe?
Is there a guide on what's required to fit the G3, Stao? I will be taking it to one of the local guys for fitting so want to make sure they have everything required to get it on.
Also, what's the best way to go about making said purchase?
If its for a Neo motor, I will recommend our ATR43G4SAT model. That turbo wold be good enough to hit close to 350rwkws pump internally gated. Cost same as the G3, you can find it on our site under the ATR43 page. cheers
Hey cowboy, if its not your daily. Might i reccomend instead of doing that. Why not just go for say the 21u or the op6 On full e85? Both have seen over 300 fair easy on e95 with basic bolt ons? Just a thought :)
I've put a lot of thought into E85, and really want to go down that path, but I think that'll have to come with a flex tune one day. For now I'm going to stay pump. I sized my injectors to give me the capacity to go E85 one day.
It is for a Neo.
Is it basically bolt on?
Yes, Check my last result from a month ago. made 311rwkws on 20psi with a cooler restriction with pump fuel. It can be made as a bolton turbo. Cost $1250 inc oil line.
Is this what I need to order?
OMFG, finally, it is done.
After talking about it for what seems like years I've finally put down some cash.
ATR43G4 Ordered!
Now just need to get it all fitted.
I have the following:
Walbro 460
Id1000s
Split fires
Car already has fitted:
Exhaust
Front mount
PFC
CAI
EBC2
Iridiums - will gap down to 0.8mm
Anyone see anything I've missed?
I'm shooting for 320+ on pump.
ATR43G4 Ordered!
Walbro 460
Id1000s
Split fires
Exhaust
Front mount
PFC
CAI
EBC2
ditch the iridiums and get bcpr7es plugs.
  • Like 1
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
