Sorry I can't remember exactly. That should be the SAT model. Externally gated?
Internal.
I thought you were going to send me the SAT version but don't actually know the difference.
Please email me a photo of the rear turbine and comp of the turbo. I don't remember building internally gated SAT versions for any one. if it is the SAT model, it might be running 22psi minimum boost, but I can make changes to it if not yet installed.
Interesting re. The intercooler studies.
I'm considering a r34 blitz return flow on an r34gtt to be used in conjunction with a high flow to make around 250rwkw. Are these worth it? or will the generate alot more lag/loss of response? Would prefer not to cut a hole..
Consider PWR 600x300x81mm FMIC instead. The Blitz return flow did not work for me.
If you really have to use the Blitz return flow and make power. get our ATR45-SRFC special application turbo. I can pump get that to make close to 300rwkws on that cooler kit.
Out of curiosity which Blitz return flow are you using as there were two sizes of the long lower pipe . Mine I believe is the earlier version with the larger diameter lower one . It may not make much difference but occasionally things like this can .
A .
Well after 3 years I've finally got interested again at fixing the issues with my ss2 setup.
Since last time it's got a new exhaust, cams both dialled which resulted in them getting advanced and water meth kit finished off. Unfortunately similar results to last time :( anymore than 18 psi it started missing and seemed like a failed coil pack as changing plugs didn't help. I got into some testing and noticed my speed signal is erratic with about a 10:1 noise. At 800rpm it fluctuates 80, 300rpm changes while cruising at 3k on highway and map tracer is constantly bouncing left right.
I'll get a new Cas and double check for intake leaks etc then try again for a better result. It's currently running about 11 degrees at peak torque and increases to 15 post-24655-14385209287334_thumb.jpg
Just got this today.
Haven't got digital copy of this yet, only photo
Ive finally got my 25 back in the 31 with the atr43ss2, going to be getting a flex tune done shortly so will update what it does.
Tao what turbo do you have for a SOHC rb30? Mates after something quite large. Does the ATR45 come in a trim suitable for a 3litre?
If you using a 0p6/vl turbo/ 300zx etc etc .63 rear, id be getting a atr45 SAT for a Rb30..as the .63s with 3582/atr45 rear turbine wheels choke the f**k out of them..to much backpressure
Rb30 sohc motors like .82 housings with those atr45/3582 turbines..
cheers
darren
Edited by jet_r31
For externally gated if he still wants that dump pipe to be made it will still be $1250, How ever if he's happy to make his own dump pipe it will cost $950
Hey hypergear. Just wondering if you have any r33 high flow turbos on the shelf for exchange. Or do you only build them once receiving them from the customer.
Thanks mate
Edited by RIPS_R33
The one in photo above is .82 internally gated.
Very good ! You will also need a small/medium camshaft (220-230 @.50 duration, upper 400 thou lift, 115-117 lsa ) depending on car use and trans and a set of valve springs
on a on a sohc rb30 to make power with that turbo..
cheers
darren
Edited by jet_r31
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
