Yeah his after external gate version, going to put gate off housing, whats the price for the external gate version?
What exhaust manifold?, if a stocker vl turbo one, take it of the top of manifold...
cheers
darren
Hey hypergear. Just wondering if you have any r33 high flow turbos on the shelf for exchange. Or do you only build them once receiving them from the customer.
Thanks mate
Yes I do have one. it will cost you $150 additional. Which you get that back after I receive your stock turbo.
One more result to add. This is from Boostborthers in SA.
R34 GTT RB25DET NEO unopened engine.
- NIstune ECU
- 1000CC ID injectors
- Factory cams, cams gears, and all manifolds.
- HyperGear High flowed factory OP6 Turbocharger
- 3 inches turbo back exhaust
- Walbro 470L/H Fuel pump
- 3 inches induction pipe with POD filter
- Split fire coil packs
- 600x300x81mm Front mount intercooler
- P98 fuel, 292rwkws @ 19psi.
- Tuned by Boosted Brothers
Pretty ancient Hypergear ATR28G2 on an unopened RB25 on 17 psi, taking it back for a few more pounds soon, boost comes on pretty strong
Nistune
United e85
Walbro e85 pump
Nismo 740cc injectors
Nismo FPR
290kw
Ive read so many pages of this but cant find much info on 30dets and these turbos! - so i apologize if this has already been covered.
Im looking at either an ATR45 .82 or the ATR43G3 .82|
The car is track purposed so response is crucial
im aiming for around 330+ on pump 98 ( i figure if i want more cams and e85 will get me there )
30det is as follows
All supporting mods ie exhaust cooler fuel system etc
standard head
standard 30e so roughly 8.4~ CR
So looking at the dyno sheets for these turbos the atr43 g3 will come on 1000Rpm sooner than the ATR45 and will both make the power level i want?
add the extra cap of the 3 ltr and i should be looking at roughly 3200rpm all in with the ATR43?
25/30 neo. Standard head, standard cams, standard untouched RB30E, SS2 .82, 45mm hypergate, 6boost, Greddy plenum, working VCT.
Cam timing is retarded and only running a 7psi spring so gate opens almost instantly. Huge gains to be had playing with cam timing and running a stiffer gate spring and a bit more boost.
For rb30det use the atr43g4 rb bolt on version. Thats similar to a 3582 in .82 rear. its quite responsive with the 3l and Will make alot more then 330rwkws too.
Sorry I should mention it's already setup for highmount so rb bolt on is pointless.
Is the atr45 the same rear wheel as the atr43?
Not sure of its an error but on your site the atr43g4 boost graph is labelled as "atr45" and full boost is around 4900, not to mentioned. The sharp power curve
Also I'm not planning on going over 380 (which is what the g3 maxed out on e85) at any stage. don't think the chasis an take it
Hi Stato,
What is the difference between the .82 ATR45 or there the ATR45SS version and what other mods are done to the 33 GTST below? this is the EXACT power I want from mine. Also which profile option was this and will it bolt into the stock location without issues?
One more result to add. This is an ATR43SS2 internally gated on a R33 GTST, with usual mods. P98 fuel.
308rwkws @ 18psi
Edited by kingtube69
  • Like 1
^^^ I think i found the answer to profile option - SS2 is what I want being the .82
Please correct me if I'm wrong.. Also from my reading I'll need the spacer which apparently comes with it but need to but extended studs - Correct?
Get the ATR45SAT version. This is a newly developed turbocharger, similar response as the SS2 and alot more power. I'm currently working on a newer version of the SS2 and SS3 at moment. results will be posted shortly.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
