My car made 324kw with injectors maxed out had faulty coilpacks running 16psi with an ss2 on a mixture of e70.. yet to retune on full e85 with larger injectors and coils
heaps of power for such low boost? first time round I only managed about 310kW with 20 psi. Needed to push it to 24psi to make what I make now and stretch head studs LOL
12074575_958449057532359_191295407393022
Made 280rwkw on P98 with intercooler causing restriction (china 510x250x65) on 17PSI.
Waiting for ethanol content sensor and feature pack nistune to arrive and will couple with a PWR intercooler and go back for e-flex. Pretty damn fast lol. Has 3.70 gears so it's not as stupid as same power with 4.11s but has 100% traction and just hauls lol.
Specs:
- RB25DET NEO: New nissan head gasket, genuine nissan headbolts
- ATR43SS2
- Turbosmart 40mm comp gate off rear housing
- Xspurt 1000CC injectors
- Z32 AFM on factory R31 airbox with lid cut out at rear
- 3" induction pipe
-3" Dump pipe > 4" highflow cat > 3" exhaust with 2 large mufflers
- Nistune ER34 ECU
- 510x250x65 intercooler (china) with 2.5" piping
- Aeromotive 340 fuel pump
Edited by AUSBen31T
  • Like 5
Its been welded onto the standard manifold. If it makes 400 on 20 then il be over the moon but we shall see i havnt got plans to take it back for retune anytime soon unfortunately. Lifes got in the way as it does haha will update when i do though
Just got my injectors from Scotty, tune for my neo with ATR43SS2 ext gate is booked in on 30th with trent, shall post up results.
Any results yet? Keen to see how your external gate ss2 setup went
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
