My car made 324kw with injectors maxed out had faulty coilpacks running 16psi with an ss2 on a mixture of e70.. yet to retune on full e85 with larger injectors and coils
heaps of power for such low boost? first time round I only managed about 310kW with 20 psi. Needed to push it to 24psi to make what I make now and stretch head studs LOL
12074575_958449057532359_191295407393022
Made 280rwkw on P98 with intercooler causing restriction (china 510x250x65) on 17PSI.
Waiting for ethanol content sensor and feature pack nistune to arrive and will couple with a PWR intercooler and go back for e-flex. Pretty damn fast lol. Has 3.70 gears so it's not as stupid as same power with 4.11s but has 100% traction and just hauls lol.
Specs:
- RB25DET NEO: New nissan head gasket, genuine nissan headbolts
- ATR43SS2
- Turbosmart 40mm comp gate off rear housing
- Xspurt 1000CC injectors
- Z32 AFM on factory R31 airbox with lid cut out at rear
- 3" induction pipe
-3" Dump pipe > 4" highflow cat > 3" exhaust with 2 large mufflers
- Nistune ER34 ECU
- 510x250x65 intercooler (china) with 2.5" piping
- Aeromotive 340 fuel pump
Edited by AUSBen31T
  • Like 5
Its been welded onto the standard manifold. If it makes 400 on 20 then il be over the moon but we shall see i havnt got plans to take it back for retune anytime soon unfortunately. Lifes got in the way as it does haha will update when i do though
Just got my injectors from Scotty, tune for my neo with ATR43SS2 ext gate is booked in on 30th with trent, shall post up results.
Any results yet? Keen to see how your external gate ss2 setup went
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
