Hypergear Turbochargers and High flow Services Development thread
Yeah that's not a bad idea, but removing the charcoal cannister and placing it there looks more tidy as well as defective lol.
On a side note, my dodgy install new studs and torque down the head band-aid solution worked.
Was at Wakefield all day today pumping 1.5 bar through the motor and no signs of pressure building up in the cooling system.. yay for 19 year old head gasket and motor haha
sprayed more things black lol....
I might delete the charcoal canister and move the catch can there.. too much shit going across the engine bay at the moment :(
12108237_1139761716052956_84809291911063
lol with a fuel pressure gauge and external gate on show you're fooling no-one about it being 'stock, officer' :P
good result on the no-head-off head stud job then, might have to look at that further myself.
Hey guys, I'm still tossing up between turbos for my build.
To be honest I just want the most responsive and snappy 300rwkw on E85 for the street.
I found a build thread where someone had made some very nice results on the highflow 21U turbo used on a R34.
There are a few options for me but I'm unsure.
SS1PU (I had one of these in my R33 for a few years and loved it, Stao has altered the build of these over the years and they seem to have gotten even better)
R34 Highflow (currently have the turbo so it would be cheap and easy to sort, but I'm unsure if it's going to be nice and responsive)
R33 Highflow (more responsive than the R34 highflow and I'm not sure where this sits between a SS1PU and the SS2 in terms of response and feel for street)
SS2 (stao said this is strong and powerful delivery)
I've looked at a fair few dyno sheets but still can't wrap my head around it all, can anyone lend some input
The SS2 should easily get 300 on e85, like very easily. I'm running 260kW on 18psi very safe tune. It has a bit of lag, but not much, full boost is about 3500 and it just picks up crazy ! I've heard the SS1 is a more responsive version, but makes less power. 300 would be pushing it with the stock turbos, but that's just my opinion.
Pretty much everything I listed there will net 300rwkw on E85, but which is going to be the most snappy and responsive.
Stao mentioned that the R33 turbo on a R34 would want to ping.
not on E85, I've found it just loses power rather than knock like 98RON, it might knock but not audible like 98RON (from my self tuning experience)
Interested to hear the answers to this.
Stay told me the same thing but I'm keen for ultimate response on the r34.
Someone on here got close to 300rwkw on an r34 with the 21u highflow, e85 and blitz return flow.
I'm wondering whether the e85 combats the pinging stao mentioned.
I don't want Lag so very keen to try and make the 21u work on the r34.
About to get some ID1000 to allow running of e85
I knew someone who made 310kw on 19-20 psi on e85 with the u21 highflow.. tbh it didn't feel very quick but the dyno sheet it had a very v8 looking power curve made full boost at like 3700 or something.. blitz front mount, xspurt 1000cc, pfc and hks exshaust
engineering a new ss2 at moment. should easily take over 300rwkws on pump. will up result shortly. ss1pu makes similar power then 21u but makes alot more torque. there is also a new turbine wheel on thd ss1pu this year, should up hp by 15kws with no lose in response.
  • Like 1
    • So.... when I'm finally getting around to having my power steering leak sorted, now it looks like I've got the same issue most A/T Skylines are having. My A/T light will randomly come on and I'm stuck in 3rd gear until I turn the car off and on again. Only 3 weeks ago I did a complete transmission service: Oil flush + new gasket + new filter. This came out of nowhere!! It wasn't like the car was driven hard. I drove about 3 mins down the road to get fuel and boom!!!  Anyway, I have a few questions and hope you fine people can help me out here. All questions are in red. 1. The solenoids: I was looking at the parts catalogue in Amayama and I could only find the Solenoids as an assembly. https://www.amayama.com/en/part/nissan/319404ax05 I read in another thread that Solenoid A = 31940-4AX02 & Solenoid B = 31940-4AX05 but the Amayama product has only the code of B. Is this the right part? Can anyone who has done the Solenoid changes or seen them confirm if this is the complete set of A & B?   2. Gasket and Filter: I'm not going to try change the solenoids myself because it seems difficult to do in a home garage with just 2 jack stands. I plan to take it to a shop and get it changed. I was also going to buy the transmission sump gasket at the same time so I don't reuse the same gasket. Should I just use the existing gasket as it has only been on the car since OCT 19th? (~3 weeks) Should I be buying a brand-new gasket and a filter? Does this job involve taking the filter out?   Thanks in advance to everyone. It's hard to find a video of someone doing a solenoid change on a R34 so any help you can give answering my remaining questions would make me less stressed.
    • Yea - From what I have seen from the video, the car idles like any R34 lol 50PSI of fuel pressure is hardly super abnormal, the regulator is working because the pressure remains static when the throttle gets revved, i.e pressure remains the same when manifold vaccuum changes. Bigger pumps on stock rails always bumped the pressure in the rail without using an aftermarket regulator to change that. Do you know what your IAC is actually doing? Has there been any data showing the stepper motor % etc? There's no way your idle is actually moving around the way the cluster(s) are indicating. You would hear the difference with the engine RPM flying to 3k and 1k in mere seconds. I'd be checking the wiring to the tacho. What the tacho is telling you and what the engine/ecu is telling you are different things. I assume your ECU doesn't display the spike. So whatever is telling the tacho to be at X rpm is doing something weird. When the going gets insane, you're on the wrong path. You've ruled out plenty of things that are working correctly/aren't the issue. Your idle isn't doing what the tacho is indicating. You have two seperate issues, I don't think they are linked, and the idle seems reasonably okay unless it's stalling which.. well, it hasn't. Troubleshoot the stall if it occurs by figuring out what your IAC is doing vs what it is being told to do.
    • So awesome! I love the RB with the exhaust on display.
    • NO HITS PRICE DROP   ENGINE - $8.5k ONO TRANSMISSION - $1.8k ONO
    • If it has had a code in the recent past, the code should still be there waiting to be read.
