What's different about the new SS2? Will it be keeping the same response? Mine is a late 2012 unit and I'm wondering whether it's time to send it to you for a refresh.
Also I'm running mine external gated (45mm hypergate) with a 25/30 neo setup. Made 265kw on 10psi and 292kw on 13.5psi.
Going for retune on Tuesday and upped gate spring to 14psi and will be running more boost now. Will post back with results ;)
^ oneday il be calling on you for guidance on how to build a 2530 neo, if wer following trend it should make more power with no loss in response.. i think thats what hes done across his range of turbos lately
engineering a new ss2 at moment. should easily take over 300rwkws on pump. will up result shortly. ss1pu makes similar power then 21u but makes alot more torque. there is also a new turbine wheel on thd ss1pu this year, should up hp by 15kws with no lose in response.
Still very much enjoying my 2013 SS2. If I ever decide to upgrade I'd definitely look into this low mount (or the ATR45SAT if it fits :) ), together with an external gate off the stock manifold.
I reckon the NEO might need some forgies at that point though...
Stao is it possible to modify a JJR bellmouth to work without an IWG or is it best to replace the dump/front when going ext gate?
Neo on forgies oh that would be alot of fun.
When i swapped over to external gate i had my bolton and acuator asembly sent back to stao and he sent the vband housing and then you just need to put a vband on your dump and get the gate housing made on the mani.. definitely worth doing!
  • Like 1
Nice!! So the exact same turbo but with ext gate? Would you have a dyno sheet before and after by any chance?
I have an ATR45SAT sitting at home now waiting to go in. I'll probably install it in the next week or so then it gets tuned around this time next month so I can tell you how it goes. Supposed to fit on the low mount stock manifold also.
Watch this space and I'll update you when It's done
  • Like 1
SS1PU will work fine it doesn't work with a small exhaust housing like the 21U units. So it will be fine.
The new SS2 uses a different exhaust side, on dyno, compare to the previous model, its been able to take more boost with more timing. I'll still still be aiming at 20psi by 3800RPM in 4th. For predicted end result it will be some where close to 340rwkws internally gated on pump 98 fuel and close to 400rwkws on E85 externally gated.
With the capacity of most common 3 inches diameter exhausts, I will be making some small bits and accessories to come around it.
With the capacity of most common intercooler and a 3 inches diameter exhaust, but I will be making some small bits and accessories to come around it.
Do you have a picture of the exhaust housing?
hory shet... makes me want to take out my SS2 and throw it in the bin and get the new version haha..
I'm pumping 24 psi into mine and the exhaust housing glows nice and red to only makeep 340kW. And by that time, my intake air temp is over 60 degrees lol
  • Like 1
ss1pu is for 1450 same as ss2. for a r34 because of the cams and higher engine comp, down low torque doesnt change alot between the two. I will be running an ss2 instead.
    • Yeah, the latter. No diff should have a centre replaced without checking clearances because its unlikely to be the same as whatever came out. Not that that stops most people just checking a new centre in
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
