What brand of mufflers were they, Johnny?
X Force lol.. and the rear is Fujitsubo, will piss the lot off after the new turbo setup
Thanks all (Stao included) It goes for a retune early next year for e85 so I'll get it looked at then. What are the options for a more free flow exhaust? Would decat see some gains? Does anyone know how PWR compares to Plazmaman?
big dump down pipe ano no cat is best... easily gain 10kW with no cat
Hi stao.
Are you saying the new prototype 21u high flow is making 287rwkw with the return flow inter cooler on pump 98? If so that is good to here.
When will it be available??
Thanks
No, I've made 290rwkws on an ATR45SAT SRFC model, that was engineered to max out my Blitz cooler kit. That one is available.
21U high flow was using an PWR cooler, you will likely be seeing that making 250rwkws region on a return flow kit.
Mad, I'm glad you and I both reproduced the same results. Anyway to get a bit less lag Stao?
It looks like you are reaching 20psi by 120KM/H which is 4280RPM. This is a fairly large size turbo, can use BB CHRA which will get 100 RPM better in response, and having a 600x300x100mm FMIC can pickup some response also. Its making 20psi at 4000RPM on my R34. I'm working on a different turbine wheel at moment. I see if I can pickup the same amount of power with better response.
Thanks Stao, I'd love to see your results.
Have you come across the A/c drain hitting the dump pipe in any of your tests? Mine melted (completely missed it when fitting the turbo) so I chopped it but I'm worried the a/c drain will drip on the dump pipe now and crack it or atleast cause a lot of steam.
Took a short video about our Internal wastegate assembly operation that is currently fitted to all ATR43xx turbochargers as well as some of the high flows:
I've read quite a bit about the Blitz Return flow coolers and how the kits pose restrictions - from your investigations it seemed as if the conclusion was the cooler core was the issue with such a large pressure drop? I like the idea of the return flow piping utilising standard pipes in bay, if a 600x300x76 decent cooler such as plazmaman or pwr were to be used with custom piping similar to that of the blitz kits (potentially even the same size piping), is it safe to say this would be similar to say the set up you currently have in your 34?
I'm considering using the blitz kit for now until a turbo upgrade (down the track) then swapping out for a better cooler and having the blitz piping altered to suit. I eventually want a tad over 300rwkw on 98 but just want a nice easy cooler for the mean time.
Thanks for reading.
Along same vein but back to the 21u high flow on the r34. With return flow max around 250rwkw with the return flow. However, running e85 would that net you around 270rwkw due to the advantages re. Timing and knock resistance compared with p98?
Toshi seemed to think e85 isn't great in a car that is driven once a week (lose octane over the time and could get knock), but others on here seem to think it's ok.
Any thoughts? Would like ultimate response
The VP racing fuels E85 additive is claimed to do similar and also provide lube to the engine.
I'm considering welding my internal gate shut on my ATR45 in the coming months when I got for an E85 tune, going external gate etc to see if the boost control improves (I would assume flow improves as well with a screamer) - Any thoughts on this?
Just use Lucas Ethanol Stabiliser, pretty cheap and drop in 30mL at a time into your full tank... prior to my flex setup, I just did that and the car gets driven at most once a week, usually every fortnight.
Fuel filter after 2000km looked pretty ok, no extra deposits or anything but did have some brown gunk in it as usual.
As for running an external, make sure you vent it from the manifold to relieve back pressure.. running the gate of the turbo "may" be a good idea however the factory manifold is pretty restrictive as I've found out on the dyno.
The manifold and gate were glowing bright red and when I added in more timing the car wouldn't make any more power...
I'm in the process or moving the gate onto the manifold from the turbo housing.. hopefully should see less back pressure and allow me to dial in more timing.
FWIW I put in an additional 6 degrees of timing and it only netted 327kW, I pulled back 3 degrees and it made 325kW @1.6bar boost.
I have seen 430+ a few times on the factory manifold with the gate off the housing. Welding it off the manifold could work well if you can get in and die grind it afterwards. I doubt you will see much in the way of gains between them.
No need for stabilizer with pump e85, I have been on Caltex/United e85 for 6 odd years without running a stabilizer and never cleaned my filters or injectors.
Watch your timing, I much prefer more boost and less timing as you previously mentioned Johnny.
You need to put a 600x300x100mm cooler on. Or adding the gate makes very little differences in power. Then add E85. This turbo maxed at 420rwkws on Hovac's C34 Stagea.
This is an Duel ball bearing ATR43G3 SAT, Not the prettiest looking. But managed 317rwkws @ 21psi, full boost hit at 3550RPM. This is the most responsive turbocharger that I've ever built so far.
Final result was 317rwkws @ 21psi P98 fuel.
Almost reaching 20psi by 3500RPM, Currently at 3550RPM.
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
