Ok thanks Stao.
When you say cut under battery tray it's just the 1 standard hole saw cut through the chassis across as you would in an r33 (that has the battery in boot).
How much was the PWR intercooler. Was trying to find that page when you started reviewing them etc.
Can't wait to get the new high flow
if you are using JJR's piping kit, their pipe diameter is 2.5 inches, so size of the hole is usually cut in 2.75 inches.
The PWR cooler is around $1150, size is in 600x300x81mm, you will need to order that through PWR.
FYP brah! Nice meeting you mate :)
new Mick_O 4" stainless intake, tigged up back purged porn dose pipe lol
(function(){var g=this,h=function(b,d){var a=b.split("."),c=g;a[0]in c||!c.execScript||c.execScript("var "+a[0]);for(var e;a.length&&(e=a.shift());)a.length||void 0===d?c[e]?c=c[e]:c=c[e]={}:c[e]=d};var l=function(b){var d=b.length;if(0<d){for(var a=Array(d),c=0;c<d;c++)a[c]=b[c];return a}return[]};var m=function(b){var d=window;if(d.addEventListener)d.addEventListener("load",b,!1);else if(d.attachEvent)d.attachEvent("onload",b);else{var a=d.onload;d.onload=function(){b.call(this);a&&a.call(this)}}};var n,p=function(b,d,a,c,e){this.f=b;this.h=d;this.i=a;this.c=e;this.e={height:window.innerHeight||document.documentElement.clientHeight||document.body.clientHeight,width:window.innerWidth||document.documentElement.clientWidth||document.body.clientWidth};this.g=c;this.b={};this.a=[];this.d={}},q=function(b,d){var a,c,e=d.getAttribute("pagespeed_url_hash");if(a=e&&!(e in b.d))if(0>=d.offsetWidth&&0>=d.offsetHeight)a=!1;else{c=d.getBoundingClientRect();var f=document.body;a=c.top+("pageYOffset"in window?window.pageYOffset:(document.documentElement||f.parentNode||f).scrollTop);c=c.left+("pageXOffset"in window?window.pageXOffset:(document.documentElement||f.parentNode||f).scrollLeft);f=a.toString()+","+c;b.b.hasOwnProperty(f)?a=!1:(b.b[f]=!0,a=a<=b.e.height&&c<=b.e.width)}a&&(b.a.push(e),b.d[e]=!0)};p.prototype.checkImageForCriticality=function(b){b.getBoundingClientRect&&q(this,b)};h("pagespeed.CriticalImages.checkImageForCriticality",function(b){n.checkImageForCriticality(b)});h("pagespeed.CriticalImages.checkCriticalImages",function(){r(n)});var r=function(b){b.b={};for(var d=["IMG","INPUT"],a=[],c=0;c<d.length;++c)a=a.concat(l(document.getElementsByTagName(d[c])));if(0!=a.length&&a[0].getBoundingClientRect){for(c=0;d=a[c];++c)q(b,d);a="oh="+b.i;b.c&&(a+="&n="+b.c);if(d=0!=b.a.length)for(a+="&ci="+encodeURIComponent(b.a[0]),c=1;c<b.a.length;++c){var e=","+encodeURIComponent(b.a[c]);131072>=a.length+e.length&&(a+=e)}b.g&&(e="&rd="+encodeURIComponent(JSON.stringify(s())),131072>=a.length+e.length&&(a+=e),d=!0);t=a;if(d){c=b.f;b=b.h;var f;if(window.XMLHttpRequest)f=new XMLHttpRequest;else if(window.ActiveXObject)try{f=new ActiveXObject("Msxml2.XMLHTTP")}catch(k){try{f=new ActiveXObject("Microsoft.XMLHTTP")}catch(u){}}f&&(f.open("POST",c+(-1==c.indexOf("?")?"?":"&")+"url="+encodeURIComponent(b)),f.setRequestHeader("Content-Type","application/x-www-form-urlencoded"),f.send(a))}}},s=function(){var b={},d=document.getElementsByTagName("IMG");if(0==d.length)return{};var a=d[0];if(!("naturalWidth"in a&&"naturalHeight"in a))return{};for(var c=0;a=d[c];++c){var e=a.getAttribute("pagespeed_url_hash");e&&(!(e in b)&&0<a.width&&0<a.height&&0<a.naturalWidth&&0<a.naturalHeight||e in b&&a.width>=b[e].k&&a.height>=b[e].j)&&(b[e]={rw:a.width,rh:a.height,ow:a.naturalWidth,oh:a.naturalHeight})}return b},t="";h("pagespeed.CriticalImages.getBeaconData",function(){return t});h("pagespeed.CriticalImages.Run",function(b,d,a,c,e,f){var k=new p(b,d,a,e,f);n=k;c&&m(function(){window.setTimeout(function(){r(k)},0)})});})();pagespeed.CriticalImages.Run('/ngx_pagespeed_beacon','http://www.sau.com.au/forums/index.php?app=forums&module=ajax&section=topics&do=quote&t=261613&p=7655290&md5check=8cdeeff961670f4c11858b2ef4b63011&isRte=1,6YgIICLrb3,true,false,Zv-j9HDt7C0');data:image/gif;base64,R0lGODlhCAAKAIABAAAAAP///yH5BAEAAAEALAAAAAAIAAoAAAISTIBmoLy9XDqyxktfkuo05AQFADs= 20151219_141746.jpg
data:image/gif;base64,R0lGODlhCAAKAIABAAAAAP///yH5BAEAAAEALAAAAAAIAAoAAAISTIBmoLy9XDqyxktfkuo05AQFADs= 20151219_141759.jpg
Geez. Yeah.
Ok re. PWR intercooler that's pricey.
Looking at other options as I would like to make close to the 300rwkw and would be annoyed if the return flow was a bit of a limit. I would hate to have to fit twice
I can get a HDi GT2 non return kit for about $600 that is 600x300x80 or a blitz (non return) standard edition for about $450 that Core Size - 620 x 266 x 76mm or the trusty old cooling pro.
I'm assuming that the above are all preferred compared to return flow?? But anyone got a view on the best kit for $350-$650 range?
Keen for easy fit, minimal restriction and hopefully ok cooling capability.
Thanks
Don't buy a kit? Buy a intercooler new or 2nd hand, measure out with cheap pvc piping what you need, buy stainless bends/pieces to suit, mark it all up and get a shop to weld it? Or get a mobile welder to come and do it at your place, should be max 2 hrs work
Where do you live? If close to Gold Coast I'll weld it for you
Edited by Gcjosh
Hybrid, HDi cores aren't that good, IATs gwt pretty high on a 13s squirt on the dyno. I would invest in something a little better, I'm replacing my China Racing FMIC soon.
4B4EAC2A2BE3AFA6173B7963A9C955999BD9A8.j
You tried this bar and plates style Tao, this is the 600x300x100 china cooler you usually see on big power cars....the internal passage fins are all straight aswell,like your pwr not all bent up like the ones
you posted pics off which are absolutely shithouse. Be good to see if they are any better. Used on so many 10, 9, 8 sec rb30s.
cheers
darren
Edited by jet_r31
I'm making 289 on a Blitz return too but it wouldn't make more than 18psi at best - Tao reckons its the return flow but I'm yet to test. Will eventually get a Plazmaman kit or PWR
i was making 510rwhp fine with a 7yr old china cooler from ebay , still have it on car actually.
and what were your intake temps?
a core may allow you to make the power you make on a dyno because it's placed right in front of a massive blower but on the track or real world it's a different story.
havent used an intake temp sensor since day one haha.
car goes to powerplay twice a year, plus test n tunes , has been like this for over 5yrs so the intake temps must not be 2 bad :)
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
