Yes it is. The recommendation would be working with our high pressure actuator, that will cost you $990 inc oil line. That way the waste gate bunk can travel all the way to a full 90 leaving gate port wide open. Gives abit more top end .
In terms of the housings I can swap it over for you as I have a spare.
How well does the 43SAT go with the journal bearing instead of ballbearing? I want to buy one but not sure that I can quite afford the ballbearing option...or should I just save a little longer and hold out for the ballbearing option?
The sr20vet is running around 20psi keeping it safe on tracks.
Yes definitely recommended bb for the new sat turbos, does make a notice able difference to throttle response.
How much boost to make 330rwkw on the SR20VET stao?..im guessing not a lot..and theres a lot more left in it
FWD/AWD is totally different beast to RWD.
The different orientation engines don't make comparable power. Plus driveshafts/diffs/gearbox are holding that particular car back from more power.
Yep i know this..
I also could work out pretty easy its not on kill..that turbo is a 61mm ish comp with a 64mm rear..it would want to have plenty left ex gated..
Cheers
Darren
ATR43SS2 making 294rwkws @ 20psi P98 fuel:
Hypergear turbo z32 afm 770cc inj power fc ecu and boost t running 20psi
Been working on few new prototypes G3SAT turbos running Hybrid ball bearing combinations lately. I think I'm hitting a wall of getting any better then 20psi @ 3550RPM without comp surge. The drive ability is great however. I might be giving it to Mr Richo and see if that improves his track times.
  • Like 2
dirty plug, but if anyone wants a stock RB20DET/25DET manifold with already 55mm extended studs fitted of which 38mm is exposed at a minimum.
http://www.sau.com.au/forums/topic/463178-fs-syd-rb20det-rb25det-stock-manifold-with-extended-studs-for-hektics/
Good for Hypergear turbo upgrades :)
Some more testing and evaluation results. This is our last BB ATR43G3SAT prototype turbocharger on R34 with P98 fuel internally gated. Note the linearness in power and torque curve to 5000RPM. Turbo made 308rwkws @ 20psi.
Yes. I'm considering that. Seen few in the past few month but prefer some thing in better conditions. But need to sell at least one of my test cars first, running out of parking spaces.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
