Nice! How hard were you pushing the last one?
My ss2 only got tuned to 18psi due to faults/leaks etc that I've mostly fixed. pulled some timing and got it up to 25 last week, almost ready for retune
Pushed the shit out of it, tried screwing 26psi through it but didn't make a single kW more. Turbo rear was glowing as bright as the sun haha. It did make more mid range torque but pointless as it bled down to 22psi up top.
Ended up only making 327kW pulled out some timing and it mad 325kW (mainline). Results did vary from another dyno I which read 340kW (dyno dynamic).
I think Tao uses a different rear housing now, because he warned me my turbo won't line up to my dump pipe now.
E85, but at the time I was tuning it was showing E72 (I run flex, car many runs 98RON).. I doubt a 10% different in ethanol would make that much of a difference in power.
they say it's on par, you would net the same results with E85 vs WMI 50/50 mix...
that was according to Yauvz's engineering mate (which is also on this forum)..
  On 14/03/2016 at 11:38 AM, hypergear said:
Yes it is more responsive. and can be built in to an OP6 rear housing.
Is it possible to get similar response out of an OP6 housing? Or is the 21U more suited?
10psi by 3250RPM and full boost by 3500RPM looks pretty nice (from the 21U). The biggest issue with all the OP6 high flow charts I've seen is boost comes on at 4000RPM which is far too late in a street car...
Specifically my question is can the OP6 housing produce "enough" power while retaining factory-like response. The standard OP6 boost response on my GTT is fine. A high flow coming in at 4000RPM would not be.
By "enough" power I mean a nice fat curve across the rev band. I care more about the total area under the curve than the peak value.
  On 18/03/2016 at 5:51 AM, Missileman said:
I'm sure a BW EFR turbo could be at full boost by 3500 their only a bit more than a hiflow.
unfortunately cost as much as our GTS-t rust buckets.
They have some with compressor covers that have a 90 deg bend cast into them too.
So $3K for the best turbo on the planet and $800 for a hiflow.
Edited by Missileman
    • Hey guys,  Way back when (about 15yrs plus), I picked up a beautiful set of Tein 'Super Racing Spec Circuit Master RE' coilovers from Russman. I have legit never fitted them to my car, as it was garaged indefinitely while i bought a house Yada Yada. They look brand new! Anyway its time to pick up where I left off, and have started doing some khanacross and am booked in for a hill climb next month. The car has some hard af Nismo shocks in ATM, which has me wanting to upgrade again, and now I am left wondering if it's worth having these teins rebuilt? I think they where an ok shock back then, but how do they compare to what's on the market now?  Shockworks/mca are 2800+, and I am sure they are great. But if I can have these rebuilt and be better than, say, a set of bc's for around the cost of bc's, I would be happy with the performance v cost trade off.  If they are considered outdated and rubbish these days, so be it, I'll put them on the shelf and be happy to look at the pretty green colour while I save for the SW/MCA option. Grateful for your thoughts on the matter, and suggestions on who could do the rebuild if it's a worthwhile pursuit.  cheers, Rowdy.
    • I can't speak for the US, but for Canada as I mentioned above, all fuel gases contain ethanol. We have regulations for E5/E10/E15. Each province handles it differently but basically any fuel gases sold must be E10 and slowly increasing to E15 by a certain year.
    • Hey guys, Purchased and drove up new wheels from Vic last weekend. Car never been registered in Aus before. Only thing was aware of was pod filter which reverted back to stock. Went to get blue slip in western sydney. Everything with car fine (compliance etc) and knocked back for coilovers. Was told illegal and need engineering cert. Called the certifier they recommended and was told at min $1000 to certify them. I was then told HP can STILL defect you even with them certified. All this was news to me. Is this just a case of deal with pay the $1000 and run the risk? Kind of nuts given the amount of people running with coils I know of. No one I know has OEMs to use to pass, either.
    • Welcome mate. Best Stagea is best Stagea. How is it driving a correct hand drive vehicle driving on the right? The Japanese do the opposite here and they've made parking boom gate ticket things on both sides to cater for LHD and RHD cars, as there's so many of them (mostly German but there are quite a few American cars too).
    • So of these and these, which ones have ethanol in them?
