Nice! How hard were you pushing the last one?
My ss2 only got tuned to 18psi due to faults/leaks etc that I've mostly fixed. pulled some timing and got it up to 25 last week, almost ready for retune
Pushed the shit out of it, tried screwing 26psi through it but didn't make a single kW more. Turbo rear was glowing as bright as the sun haha. It did make more mid range torque but pointless as it bled down to 22psi up top.
Ended up only making 327kW pulled out some timing and it mad 325kW (mainline). Results did vary from another dyno I which read 340kW (dyno dynamic).
I think Tao uses a different rear housing now, because he warned me my turbo won't line up to my dump pipe now.
E85, but at the time I was tuning it was showing E72 (I run flex, car many runs 98RON).. I doubt a 10% different in ethanol would make that much of a difference in power.
they say it's on par, you would net the same results with E85 vs WMI 50/50 mix...
that was according to Yauvz's engineering mate (which is also on this forum)..
Yes it is more responsive. and can be built in to an OP6 rear housing.
Is it possible to get similar response out of an OP6 housing? Or is the 21U more suited?
10psi by 3250RPM and full boost by 3500RPM looks pretty nice (from the 21U). The biggest issue with all the OP6 high flow charts I've seen is boost comes on at 4000RPM which is far too late in a street car...
Specifically my question is can the OP6 housing produce "enough" power while retaining factory-like response. The standard OP6 boost response on my GTT is fine. A high flow coming in at 4000RPM would not be.
By "enough" power I mean a nice fat curve across the rev band. I care more about the total area under the curve than the peak value.
I'm sure a BW EFR turbo could be at full boost by 3500 their only a bit more than a hiflow.
unfortunately cost as much as our GTS-t rust buckets.
They have some with compressor covers that have a 90 deg bend cast into them too.
So $3K for the best turbo on the planet and $800 for a hiflow.
Edited by Missileman
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
