I'll try one when I get rid of my rb20
Just got back from the gold coast where I drove a stock HCR32 kouki in Dark Blue Pearl with the dark chrome grill garnish, very pretty car.
hey, I have 34 gtt 25neo!! Chasing around 350rwkw with a good response, which turbo you would recommend?
So far I got
Fmic
3inch tbe
Nistune with flex tune 98/85
Hpx afm in a 3inch pipe
Walbro 460
1000cc injectors
Avcr boost controller
Cheers
350rwkws on E85 fuel you can use our new ATR43G3SAT model. You will need a very big exhaust and a very free flow cooler to run ATR45SAT, that can get close to 350rwkws on P98 fuel.
Hey Tao. Have you posted P98 power figures of your new 21U turbo? If not could you please?
I'd imagine the OP housing would make minimal gains over the 21U?
What size is your exhaust and what mufflers etc?
Our high flowed T517Z. 507awkws @ 22psi E85 fuel internally gated, on a built RB26dett by Forged Performance in SA. Looking at stiffer actuators and run up to 30psi. Hopefully be seeing 600awkws.
  • Like 1
The best I've got was 287rwkws P98 fuel on 21psi. R34 GTT Neo engine. with Exhaust Tee and PWR cooler:
How is the exhaust T going after all this time? I was a bit skeptical of the spring loosening up over time and when the exhaust gets hot.
^ you're better off using an external gate with a weak spring to emulate what Tao is doing with that flapper. A few guys have done that (not here) but Google!
I wouldn't be doing the mod ;) just curious as to how it's held up over time as it's different than the ex and int types.
I know a few people who have tried this with external and internal gate mechanisms, but they have all had problems.
Well, the exhaust Tee is bleeding with not as compressed air as what it is inside the exhaust manifold. So it needs to be alot bigger. There are many ways of doing it, the most popular I've seen was that window switch motor controlled valve on ebay. That doesn't work very well as the motor gets overheated by exhaust gas.
Alternatively you can use an actuator to control the valve, which is very reliable, or just some good high tensile springs. Its a simple device, but that definitely shown an improvement.
Hey Tao, What would you recomend for a VH45DE engine? pref in single config. Street driven so reasonable response around 400rwkw minimum range?
For this engine you can run one of our ATR45 in a 1.06 rear housing externally gated. On E85 fuel that will be plenty for 400rwkws
Also vid sent in from Jason using one of our prototype ATR43 in his 1JZ, the goal was a responsive 300rwkws on Pump fuel with out VVTI. It is not an easy task as I originally predicted, project is still on going.
Vid shown 320rwkws on E85 fuel @ 22psi
Yes. Rebuild Using using a bush bearing core will cost u 700 or a Garrett bb core for 1050. Will require braided oil line and mico filter removed for either cores
Ok and what suporting mods are required i have fmi 3"dump exhust can this turbo b utilised without a tune can you set boost to afr's ratio
Wut?
Not tune, set boost to afr? What you mean man?
    • As an ex-skyline owner Going off how these things are now "modern classics", I would keep the twins and just "refresh" bits that are required for reliable power and have a car you can take out for a cruise whenever you get the itch As a idiot who cannot leave things alone Going deep into the "rabbit hole" is a easy thing to do, as previously mentioned, once you start it becomes a slippery slope, wirh lots of supporting mods, and possibly rebuilds, and unless you have a bottomless pit of funds, the car can spend most of its life sitting in the garage,  broken, waiting for parts, or building more funds For a classic like a R32 GTR Basically, a reliable OEM+ refresh, that isn't a broken garage queen, is alot better than a car that you build, then break, then fix, then break again And it isn't just the engine you need to worry about, these beasties are getting on in age, and all parts are getting, and have got, expensive, the days of picking up cheap replacement engines and other driveline parts are well and truly over The funds not spent on going a single with quality parts, and with all the other other bits required to make it happen, could be spent on refreshing alot of other parts A wise man once said "If you cannot afford 2 GTR's, you cannot afford 1", I also believe he said this about 20 years ago when you could pick up a clean R32 GTR up for around $20k My advice for a R32 GTR (the one and only true Godzilla in my mind) is to think holistically about the whole car, the body, the power train, the suspension, the brakes, and the driveline SAU is a wealth of knowledge with decades of Skyline experience,  from stock, to OEM+, to modified to varying degrees, to full on or weekend or dedicated racecars, as well as full on money pits that rarely leave their garage Treat the old girl nice and give her what she deserves, you are a lucky man to own such a classic car
    • For that price you could buy the hypergear turbo (big fan as I run one) and the Haltech ECU..
    • +1 for the Elite 2500. Get some new knock sensors while you are at it (pretty cheap), look up the TAARKS Nissan knock sensor kit. You may also want to get new coils (R35gtr) while your at it (assuming your on stock ones), as they are a liability. Mine started right up and idled fine on the base map. Also go MAP over MAF, as said above, Haltech make this super simple right out the box. Another fanboy of DBW here, Outsider Garage from your neck of the woods make some nice conversion gear for the R33 (that’s where I got some of my gear from).
    • Nvm ignore this I read it wrong
