Hypergear Turbochargers and High flow Services Development thread
hey, I have 34 gtt 25neo!! Chasing around 350rwkw with a good response, which turbo you would recommend?
So far I got
Fmic
3inch tbe
Nistune with flex tune 98/85
Hpx afm in a 3inch pipe
Walbro 460
1000cc injectors
Avcr boost controller
Cheers
350rwkws on E85 fuel you can use our new ATR43G3SAT model. You will need a very big exhaust and a very free flow cooler to run ATR45SAT, that can get close to 350rwkws on P98 fuel.
Hey Tao. Have you posted P98 power figures of your new 21U turbo? If not could you please?
I'd imagine the OP housing would make minimal gains over the 21U?
What size is your exhaust and what mufflers etc?
Our high flowed T517Z. 507awkws @ 22psi E85 fuel internally gated, on a built RB26dett by Forged Performance in SA. Looking at stiffer actuators and run up to 30psi. Hopefully be seeing 600awkws.
  • Like 1
The best I've got was 287rwkws P98 fuel on 21psi. R34 GTT Neo engine. with Exhaust Tee and PWR cooler:
How is the exhaust T going after all this time? I was a bit skeptical of the spring loosening up over time and when the exhaust gets hot.
^ you're better off using an external gate with a weak spring to emulate what Tao is doing with that flapper. A few guys have done that (not here) but Google!
I wouldn't be doing the mod ;) just curious as to how it's held up over time as it's different than the ex and int types.
I know a few people who have tried this with external and internal gate mechanisms, but they have all had problems.
Well, the exhaust Tee is bleeding with not as compressed air as what it is inside the exhaust manifold. So it needs to be alot bigger. There are many ways of doing it, the most popular I've seen was that window switch motor controlled valve on ebay. That doesn't work very well as the motor gets overheated by exhaust gas.
Alternatively you can use an actuator to control the valve, which is very reliable, or just some good high tensile springs. Its a simple device, but that definitely shown an improvement.
Hey Tao, What would you recomend for a VH45DE engine? pref in single config. Street driven so reasonable response around 400rwkw minimum range?
For this engine you can run one of our ATR45 in a 1.06 rear housing externally gated. On E85 fuel that will be plenty for 400rwkws
Also vid sent in from Jason using one of our prototype ATR43 in his 1JZ, the goal was a responsive 300rwkws on Pump fuel with out VVTI. It is not an easy task as I originally predicted, project is still on going.
Vid shown 320rwkws on E85 fuel @ 22psi
Ok and what suporting mods are required i have fmi 3"dump exhust can this turbo b utilised without a tune can you set boost to afr's ratio
Wut?
Not tune, set boost to afr? What you mean man?
    • This is a simple swap when you reuse the RB20 loom and auxiliaries. I run a standalone, but if I remember right, using the RB25 ecu you only have 2 injectors to inverse.  There are many DIY's on this subject online, including this forum.
    • Surprisingly the D6000 is only $1999, I'm waiting for the BF/CM sales, and hoping to get one cheaper. D4000 is well priced, still outperforms the 13" SVS PB-3000 and is like 1/2 the price at $1699 RRP. I do watch a fair amount of movies, and listen to EDM, jazz, symphonies, etc. so the lower notes from a subwoofer are always appreciated. The front 8" stage, just doesn't provide you with lively feeling, even though they are pretty bassy for a pair of large bookshelves. Then again, these days it's just playing Wiggles, Blippi and Ms Rachel, another reason the 3m wide cabinet exists, to hide all the audio gear behind it. They used to sit on a nice pair of stands, but as you know, they make good baby traps too.
    • Granted, which is a solid reason why I don't have one. My floorstanders are only -2 dB at 22 Hz.  So they're still working down to <20 Hz. Which is no doubt part of the reason why my receiver shits the bed! That Tonewinner would be about double the cost though, so it's not apples and apples. There aren't many AU$1300 subs (that you can buy prebuilt, I'm ignoring what can be achieved by DIYing) that compete.
    • -6dB at 22Hz isn't that great, watch the data from the D6000 from REW
    • I'll just leave this here. https://www.adelaidespeakers.com/subwoofers.html TL loading, big power. They sound awesome. This is what I would buy if I was going to try to take the bass away from my floorstanders. Just go with the 12".
