Hi Tao and all.
just wondering which turbo (or CHRA) you would recommend for a 2L 4-cylinder engine with short stroke & big bore (unlike the SR20DET) for a responsive upto 300rwkw?
I have read the 581 pages (wow what a read) and given the atr28ss2 would give me what i need, would like to know how the ATR28 & ATR43 differ and which one can ideally be suited to my T3 flange.
Hi Tao and all.
anyone?
given my manifold has T3 flange it seems i'll need to go for a ATR43 based CHRA. Just not sure how it will perform on my engine.
does anyone know the difference b/w the ATR28 & ATR43 turbine ends?
You can use our Atr43g3sat model in ceramic ball bearing assembly externally gated
thanks Tao.
any guesses when i'll roughly see fullboost?
alos, what would be the next smaller CHRA i could use?
thanks Tao.
Also, would it work ok with an A/R .63 turbine housing?
Atr43g3sat would be laggy on sr20 its already quite laggy on a rb25
One size down would be the atr43ss2
No ones tryed it on a sr20 yet
Would be quite good on a t3 highmount manifold and cbb
.63 rear externally gated
Would be quite responsive but may choke the engine over 300kw
On e85 might be ok but pump 98 may get detonation early
Depends what you want the car for
Responsive street setup .63ar or all out power drag .82ar just may be more lag
.63 t3 housings make heaps on 4 cylinders(350+),much more than the little
t2 housings ever will
You havnt got no where near as much backpressure as a rb25.
You could try the 20.5g he builds. Ss2 comp.l2 turbine 8cm housing.
We have one on stock bottom end sr. Does 315rwkw atm on low 20s boost and e85.
We used a china cast mani which had no boost control.
Now gone 6boost and 45mm gate,trying to get it booked in for tuneatm and will be put "on kill" shortly....
Another guy in qld did 370rwkw on one on 27psi ish with a bit left in the tank so be interesting to see what it makes.
We fitted a small water injection nozzle pre turbo this time aswell
Have a atr45sat ss here aswell ..have joked about fitting that..lol
Cheers
Darren
Atr43g3sat is the latest model that is more responsive then the ss2.
Thats the one made 317rwkws with 20psi @ 3550rpm P98 fuel. I think the larger model referred to was the Atr45sat.
Not a Sr, for a short stroke 2L depending on CPR, can run in a .63 or .58 rear.
thanks for the response.
ultimately the car will be street driven and maybe the odd track day (for some fun) given its heritage.
given this, it will need to stay with the original A/R .63 internal gated housing - i'd also like the engine bay looking factory spec.
and i'll prefer to stay with P98.
Cheers
Darren
i'd assume the T3 .63 would flow better than the T28 .64.
the 20.5 (ss2) turbo does look tempting, but per my previous post, i'd prefer to stick with internal gate to keep the factory look.
it seems like i might need to look at the atr43ss2, possibly in CBB.
so does this ATR43G3SAT have a CBB core?
what size is the turbine wheel because i might look at having my housing machined to suit?
yep, short stroke (over-square) engine with twin cams, forgies, etc, CR will be around 8.0:1.
given it's my weekend street car, response and strong mid-range is important.
it's not a track broad minded person or dyno queen.
What engine exactly are we talking about here? It will help people here to assist you.
Not sure why he hasn't actually said engine, but I'm going to guess a YB* series Ford. Given his name, I'd say he owns an RS500.
i didnt think it would really make any difference, but correct, it's a yb cosworth engine.
CBB will give you day and night difference with transient response compared to its journal bearing brother.
I went from a SS2 journal to CBB (ceramic ball bearing) and the difference is day and night.
  • Like 1
2016 version of SS2 has many changes made to earlier models. The difference in end result would be a combination of alterations made.
Ceramic ball bearing system makes difference in throttle response and becomes very apparent when working with low CPR, None VCT engines as well as cars with Auto transmission. It is definitely recommended for that Cosworth engine.
2016 version of SS2 has many changes made to earlier models. The difference in end result would be a combination of alterations made. Ceramic ball bearing system makes difference in throttle response and becomes very apparent when working with low CPR, None VCT engines as well as cars with Auto transmission. It is definitely recommended for that Cosworth engine.
Speaking of Non VCT, low cr engines, did you ever end up doing any development with an RB20 Tao?
    • Everything I found online said never use it because it'll dramatically reduce belt lifespan.  No, but I have seen excessive v-belt tension cause the audible bearing noise from excessive radial load in things like alternators. So don't overdo it. Ideally you set it to manufacturer spec using a proper belt tension guage. I tried the "clicker" type gauges but those cheap things are trash. They read way too low even when you're careful.
    • This is kind of where I've ended up for the most part. It's easier for me, easier for shops that don't have to deal with my weird criteria/picky standards, etc.
    • Will do. Suprised if it's not the starter motor considering it's 30 years old. Will get a volt meter though. Battery is close to new.   Cheers for your help, always appreciated.
    • This almost never happens these days. No. Clean your battery terminals and make sure they are tight. Use sandpaper on a dowel if you have to, to get oxidation off the inside of the terminals, particularly on the -ve. Check the earth cable from battery post to chassis ground and engine ground. Make sure the contact surfaces are clean - including the threads on the bolts that anchor them - because that's where a lot of the contact occurs. Wire wheel on a drill is a good thing for this. Make sure the crimps on those cables are all sound. Assuming none of that causes an improvement: Check the battery voltage after it has been resting for a while. If it's at the lower end of the range, put it on charge for a while, then see if it will crank better.
    • I just checked my belt, it wasn't super loose but I could bend it past 90 degrees a small amount so I tightened it up and for the first time ever my car didn't crank first time, had to crank it again lol. Don't know if that was because I tightened the belt or if it's my starter motor going out (been having slow starts for some time). Coulda also been when I was recording I didn't crank the key properly and it didn't save the recording lol.   Is that a thing if you overtighten a belt it struggles to start?
