^ lol... maybe I'll use a 3" intake pipe and add in more bends.. that usually gets the suuuuuuuuuuuuuuuutuuututuutut going LOL.
Anyhow, some real world facts to back up the results.. errbody likes timing maps, logs and dyno print outs LOL
Power Run Log (rename it to .csv)
final pwr.txt
Timing Map & Compensation Map
the reason it's so ridiculously advanced when there's loads of boost is because the normal 98RON runs crap all timing at high boost areas so I don't blow the motor to bits when it's on 98RON and accidentally run a little too much boost.
Andddddddddd Dyno Sheet
  • Like 7
Awesome result mate
I drove it before the tune and was already like a light switch when power come on
But the ext gate noise just made it feel that bit faster
Any plans to take it to the drags ?
Looks like that exhaust aint too bad as power isnt noseing off and boost is rock solid
500hp stock bottom end
It's so quiet now man, we could have a full conversation when it's on noise... I didn't even need earmuffs in the dyno room!
Of course man, I'll take it to the drags one night for shits and giggles, I'll give you a heads up too!
Well the entire system is 3.5" till the rear muffler at 3.25"... the front section of the cat back was chopped off and replaced with a 3.5" Hurricane round muffler.
Exhaust system wise, I think it's flowing just right.. I have the option of dropping the gate plumbing back into the system.. but with the power achieved and the boost response I doubt that there's much back pressure.
Some updates on the ATR45SAT CBB Turbocharger. made 336rwkws @ 22psi on Pump 98 fuel, internally gated bolton.
Sorry not the prettiest looking. I just can't get same power out of fancy looking bits.
This turbo is big for a 3 inches turbo back system on an R34 GTT. I can't get much more power then the G3 SAT with exhaust connected. Result above was obtained from front pipe dropped before the cat. it would be a very nice turbo to run on an external gate off an factory exhaust manifold.
Thanks for the plot. Looks pretty accurate.
Here is another piece of data from last week's dyno run. It is an direct comparison of latest SAT CBB turbo assembly vs Plan bearing assembly In RB25det. Same car with same turbo, the only thing that has been changed is bush bearing to ball bearing. The differences made in response was 300RPM and Car's reaching peeking higher boost on lower gears. The CBB result was trailed back in 2012 using a much smaller shaft wheel assembly while its end result is not as tangible, the effect appears to be more tangible depending on the size of the wheel assembly or the total rotational mass.
Interesting - Would it be possible to get mine redone with the different bearing for better response? If so how much would it be?
Re-highflowed one of blown Ebay's Highflowed OP6 turbocharger with one of our G3SAT Ceramic Ball bearing CHRA, Did a actuation test using their billet casing actatuors supplied. Appears some "pretty looking" parts does not work as well as how they they looked.
That billet 38mm internal gate is part of our G3 high flow profile, not what originally came with the turbo.
Photo one shown full actuator travel using ebay's actuator.
Photo two shown full actuator travel using one of our standard 14psi actuator.
Stao, are you still of the view that the 21u highflow would be too responsive with the ball bearing cartridge and create surge or have you tried it.
Still looking for the most responsive turbo for r34gtt and was looking at the 21u high flow with high flow actuator
The 21U is already super responsive in bush, there is no reasons to make it ball bearings as I've already trailed and compared. for R34GTT the best result I've trailed was G3 high flow using CBB cartridge with high pressure actuator.
S15 SR20, 250,000km old with full service history from older age owners, aust delivered.
Standard motor
headstuds and mls head gasket
BC 264 vtc delete and valve springs, rocker stoppers
6 boost, 45mmex gate
1000cc inj
walbro 460l
E85 plus pre turbo water injection
Hypergear Td06 20.5G 8cm T3 rear
19psi 314rwkw
23psi 366rwkw....power is still climbing..its just hitting the rev limiter
Tried to turn it up at end of night...made 386rwkw...at 28.7psi...lol...at only 5800rpm....then started misfiring.
Plugs where done and it was getting late in the night so we stopped for now..nice little turbo
We used a china cast t3 mani before and 38mm ex gate...went from 314rwkw at 23psi to 314rwkw at 19psi from just those changes to 6boost and 45mm..and spooled 300rpm quicker
To give you a idea how dyno reads, the best 0p6 hypergears hiflow skyline on 98oct has done 290rwkw at 19psi on this dyno, best skyline auto has done 260rwkw on 18psi on 98 oct
Now its onto getting the atr45.5 test car up and running.
cheers
Jase and Darren
Edited by jet_r31
  • Like 1
Pretty sure efihardware and kudos do plugs here in Australia. Before that I purchased my VCT plug from wiring specialities in the US. Was only $6-7 I think.
  • Like 1
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
