We didnt up the boost as the current exhaust is a restriction so more boost currently doesnt = more power. Im really just after more mid range
I wonder what a atr43 g3 sat with a .64 t3 rear would be like on a sr20 then..
Cheers
Darren
There is an custom version made for SR running in .64 rear housing. I'm in the process of engineering an ceramic ball bearing chra to suit an short T2x shaft and bearing housing, which also means all the TD06 can be converted using the same ball bearing assembly to improve throttle response. I'm considering of doing one more round of SR20det development with a stock standard motor, hunting for the right car at current stage also.
Even there is no VCT I should still can engineer an ceramic BB turbo to reach 200rwkws @ 4000RPM that makes over 340rwkws on E85 fuel. Below is result from Jason's 1JZ None VVTI engine running inside a R31 wagon. car made 340rwkws on 23psi externally gated, 200kws @ 4000RPM:
Video taken from last week Calder raceway. Chasing Manuel's yellow R33 GTST, Excellent battle footage of ATR43 G3SAT 1J VS SS2 RB. :thumbsup:
  • Like 2
Yea think i seriously goingnto consider one in the next 6 months looking for that 200 plus at 4k and 350 ish you td06 looks the goods
SS2 or the new G3SAT will do it.. I make about 240kW at 4k and near 7k it's at 370kW
  • Like 1
Aww damn, be interesting how it goes then when I bolt it up. Got it quite cheap. If it doesn't make any decent power then I'll save up again for a different turbo set up from the hyper gear range
Rear wheel looks like standard size.
Gap between wheel and iwg flap is huge
Rear wheel is defs bigger than standard wheel, look at adms15 rear wheel in his standard turbo against the post I did. Defs a difference.
I have found out who the did the hi flow and as it turns out it's been done by gcg
Let us know how you go
Got the same turbo by the looks of it
What one do you have ? U got a dyno sheet posted up ?
I thought you said you went through the dyno thread and this thread, didn't look hard enough eh? LOL :)
here:
http://www.sau.com.au/forums/topic/261613-hypergear-hiflow-service-continued/page-583#entry7731137
and
http://www.sau.com.au/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/page-54#entry7731169
Oh yez.. plus a video haha:
  • Like 3
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
