We didnt up the boost as the current exhaust is a restriction so more boost currently doesnt = more power. Im really just after more mid range
I wonder what a atr43 g3 sat with a .64 t3 rear would be like on a sr20 then..
Cheers
Darren
There is an custom version made for SR running in .64 rear housing. I'm in the process of engineering an ceramic ball bearing chra to suit an short T2x shaft and bearing housing, which also means all the TD06 can be converted using the same ball bearing assembly to improve throttle response. I'm considering of doing one more round of SR20det development with a stock standard motor, hunting for the right car at current stage also.
Even there is no VCT I should still can engineer an ceramic BB turbo to reach 200rwkws @ 4000RPM that makes over 340rwkws on E85 fuel. Below is result from Jason's 1JZ None VVTI engine running inside a R31 wagon. car made 340rwkws on 23psi externally gated, 200kws @ 4000RPM:
Video taken from last week Calder raceway. Chasing Manuel's yellow R33 GTST, Excellent battle footage of ATR43 G3SAT 1J VS SS2 RB. :thumbsup:
  • Like 2
Yea think i seriously goingnto consider one in the next 6 months looking for that 200 plus at 4k and 350 ish you td06 looks the goods
SS2 or the new G3SAT will do it.. I make about 240kW at 4k and near 7k it's at 370kW
  • Like 1
Aww damn, be interesting how it goes then when I bolt it up. Got it quite cheap. If it doesn't make any decent power then I'll save up again for a different turbo set up from the hyper gear range
Rear wheel looks like standard size.
Gap between wheel and iwg flap is huge
Rear wheel is defs bigger than standard wheel, look at adms15 rear wheel in his standard turbo against the post I did. Defs a difference.
I have found out who the did the hi flow and as it turns out it's been done by gcg
Let us know how you go
Got the same turbo by the looks of it
What one do you have ? U got a dyno sheet posted up ?
I thought you said you went through the dyno thread and this thread, didn't look hard enough eh? LOL :)
here:
http://www.sau.com.au/forums/topic/261613-hypergear-hiflow-service-continued/page-583#entry7731137
and
http://www.sau.com.au/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/page-54#entry7731169
Oh yez.. plus a video haha:
  • Like 3
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
