Naa the G3SAT killed it in both power and response. I'm not been able to make anything thats more responsive at its HP.
And some video footages from this week:
HyperGears ATR45SAT Ceramic ball bearing turbocharger powered Team Lori Blue Bird. Sandown race track 1.24 run before WTAC. Car is a 4WD, has SR20VET engine, Built gear box, Fuel and injector mores, manifold and external gate. Tuned at Springymotors made 340awkws E85 fuel. Car driven by John Reco
The latest Upgrade in Rb25det Bolton turbo upgrade.
Had my R34 on dyno today testing the latest ATR45SAT ceramic ball bearing turbo. Amazingly it made the same power with 250RPM better in response. Plus most importantly, this turbocharger is happy to run a minimum boost level of 20psi, which the older model can run no less then 22psi. P98 fuel
Now hitting 20psi @ 3650RPM vs Older version of 14psi @ 3650RPM. Car made a peek of 331rwkws and average of 325rwkws @ 22psi with 3 inches turbo back exhaust + Tee connected, It is a blast to drive.
Recap, Car has:
R34 GTT RB25DET NEO unopened engine.
- Adaptronic� ECU
- 1000CC ID injectors
- Factory cams, cams gears, and all manifolds.
- HyperGear ATR45SAT (Pro-B 150816) Ceramic Ball bearing Internal gated RB25 bolton Turbocharger
- JJR 3 inches turbo back exhaust, 2 inches Tee from front pipe.
- Walbro 470L/H Fuel pump
- 4 inches induction pipe
- Split fire coil packs
- PWR 600x300x81mm intercooler
-Tuned by Chequered Tuning Melbourne (Highly recommended)\
Dyno reading shown:
Red - ATR45SAT (Rv-2 150816) Current
Grey - ATR45SAT (Rv-1 180316)
Video shown the highest powered dyno run
  • Like 3
Here is one more result that are worth posting.
This is from one of my troubled customers whom like many others using stealth setups including a return flow cooler and a silent exhaust. Obviously it made a petty 260rwkws P98 using our ATR43SS2 turbocharger with a massive boost drop. The SS2 however have held a dead flat 20psi on my R33 peeking 302rwkws. Fixing that boost drop problem, he went all the troubles fitting up an External gate that made only a 5kws gain. His disappointment anger and frustration has been directed to the turbo and my self.
During that time, initial ATR45SAT was first made and tested by Havoc Fabrications at 420rwkws. An upgrade request was made by the customer so the same turbo was built and sent for the exchange of the ATR43SS2 which I'm yet to receive. With nothing else apart from the turbo change and E85, the car made an disappointing 354rwkws, that have sparked more heated conversations, to prove my product I have later managed to use the same turbo beating his E85 result running internal gate on less boost.
Red- My internally gated result vs Blue - under performing externally gated result
Finding out reasons and answers in solving those issues, I have bought my 2nd and 3rd R34, picked the exact same mods used, guess what I ended up with same crappy result. Investigation pointed to the Blitz return flow cooler, the 2.5 inches resonator inside Jap exhausts as well as the EPA approved compliance cat, test results of those are documented in my earlier updates of this thread.
A proper front mount cooler is finally fitted, with a good cold air induction system and a free flow exhaust installed. using the same turbocharger the car has now hit 400rwkws on E85 fuel:
Vs controlled result:
This is an perfect example of how important it is picking the right supporting and differences it makes to overall performance.
  • Like 7
What is that airbox for the 34?
Setup always matters for results. I actually just found myself how much restriction the airbox can be at 400+. Though, my blitz fmic is still going strong.
What was the difference Greg?
At my peasant power level the car only picked up another 10rwkw with the airbox lid and filter removed, same as a fluffy dice or a JDM sticker basically.
One of the bigger differences in my setup was going from an X-Force cat to Venom 100cpi, that was significant.
Also Tao in the photo above is that a boxed pod setup under that stealth lid?
For me it was 45kw lol. But my lid had no modifications and the difference was lid off/on back to back.
My VCT was also not working, so fixing that got power on 800rpm earlier.
So it pays to test all setups!
I have made a solution to get mine going that looks stocker than that box, but still curious to know what it was.
I was lucky that the seat of the pants feel was massively different (and so was boost) so it was very obvious for me to test my 'fix'
Also worth noting I am auto. So if you make about 400 on a manual the lid will work. I was making about 365kw with the lid on and 410 with it off and the car decided to just run 28psi instead of 21. The restriction was real.
That said it's still fine in my experience for any turbo on a 25 that wouldn't be too laggy to actually want.
  • Like 1
http://www.hypergearturbos.com/index.php?route=product/product&path=74&product_id=69
click on the G2 profile, and click on the ball bearing upgrade. Also when submitting the order, please add note state its for an Rb20det engine.
  • 3 weeks later...
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
