9 hours ago, Super Drager said:
How tight of a fit is it? Doesn't foul on anything?
It's a pretty tight fit but not impossible - Only thing it does foul on is the aircon drain pipe which I just chopped shorter.
The only pain in the ass thing is the flange to manifold bolts are a bitch to get on and require some patience.
  • 1 month later...
Some video footage from Last weeks Victoria Time attack at Philip Island GrandPix.
ATR45SAT Turbocharger Powered Top Stage S14 SR20det (400rwkws @28psi, E85 fuel). Taking first in Modified class. Driven by John Richardson
  • Like 2
Posted in my own build thread, but relevant for this thread.
I got myself a Hypergear G3 high flow on a 21U turbo. I've had pretty good results, making 230rwkw @ 14psi on 98RON. This particular dyno graph shows boost dropping at the top end, this is because (due to my own request) Tao put on a 10psi OEM wastegate, and it just wasn't up to the task.
I've put on an aftermarket wastegate (pictured) and it now pulls 18psi happily all the way to redline.
I installed the turbo myself and it was very straightforward. Overall stoked with the results.
  • Like 2
Just repaired a blown Borgwarner EFR with no exhaust wheel. Luckily the compressor wheel is undamaged. It has been fitted onto one of our ATR CBB cores with a custom grind turbine wheel to suit the original turbine housing profile. Looking to match original power figure before turbo failure, hopefully with a bit more torque through mid range.
  • Like 1
Time for some e85 then
Post mortem review - what caused that failure?
First run with Brand new Ceramic ball bearing T4 print ATR44SS prototype hit the dyno this afternoon. Car made 406rwkws @ 22psi, Pump 98 fuel. full boost by 4000RPM. Stock 2JZGTE, sorry not an RB this time.
  • 3 months later...
Hello and greetings from Finland
I have had my skyline for 8 years now, and now its finally time to upgrade the turbo. I am looking for around 300rwkw with 98 fuel. With supporting mods of course. Since i have a limited budget i was thinkin of the ATR43G3SAT with thrust bearings. The price of that would be perfect, but i couldn`t find any dyno results or other info of that turbo with thrust bearings. I know that bb core is recomended with this, but i really like the price of the normal bearings and if it still would be good enough, it might be a choise. With bb core it seems to be really amazing. Or is there some other options i should consider? Maybe high flow or ss2? I am looking for the most cost effective way to get good end result.
For up to 300rwkws region a brand new ATR43G3SAT turbo is recommended.
ATR43G3SAT bush bearing, internally gated, P98 result based on a R33 Rb25det engine:
  • Like 1
Thanks for the dyno graph. It looks pretty good in bush bearings too, but there sure is noticeable difference between ball bearings and bush bearings. About 70 Nm and 20 Kw in 3500 Rpm, if i looked correctly. I have couple of weeks time to think which one to get, before i get some money. I will go with teh ball bearings if i can afford them. If i can`t i will go with bush bearings. Either way i go, i think i will have a good turbo.
Back to back on the dyno measuring 4th gear paddle to the metal, there isn't that much of a visual differences to the curves. Take everyday road driving with partial throttle acceleration the differences are very noticeable.
There has been quite a number of updates applied in terms of wheels, housings and bearings in recent years so we will be starting another R34 GTT modification project, it will used in the development of our SS Ceramic ball bearing series turbochargers.
Car is a 2000 model with 80,000KM on the clock, bought from an mature enthusiast whom spent quite few coins at it with:
 Split fire coil packs
700cc injectors (Bosch?)
PFC ECU + Z32 AFM
3 inches Xfroce Varax exhaust
Koyo radiator
High flowed OP6 turbo (appeared to be an old XTR model)
Walbro 255 fuel pump
NPC Heavy duty clutch
HKS return flow cooler kit.
Setup on the dyno for the first time, after few power pulls the turbo started to make some funny noises and we stopped it at 226rwkws at 11psi, Peeked 14psi at 4000RPM.
Other issue worth mentioning is VCT. Using factory ECU/many aftermarket plugins, VCT solenoid produces a very distinctive "click" activation sound on throttle opening. PFC activates it in gear, so you should hear it clutched in 1st and a tap on the throttle. Mine is not clicking, later diagnostics have revealed signal output problems from the ECU. If VCT is not activated, there will be a lose in boost response by roughly 500RPM, and I found VCT problems frequently occurring with customers using old PFC plugins.
 I have re-high flowed the OP6 turbocharger using one of our ATR43SS2 ceramic ball bearing cores:
Further dyno shown an improvement in response of 600RPM while a 27kws increase in power. 253rwkws @ 15psi
we had some boost taper issues on the dyno, and MAP comparison have once again shown a flow restriction caused by a return flow cooler. Boost pressure before cooler: 22psi, after: 15psi, pressure drop: 7PSI
The plan before my next dyno run is to trail PWR's vertical flow cooler as they do make one that bolt on to an R34 GTT and will be replacing the PFC with the latest Adaptronic Modular R34 plugin ECU.
  • Like 1
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
