hypergear Posted May 15, 2018 Author Share Posted May 15, 2018 Another result to share, this time from one of our high flowed R33 GTST 21U Turbochargers externally gated on a built Rb25det engine. Car made a super responsive of 330rwkws @20psi on E85. Full boost by 3500RPM with very wide power band. Forged R33 Rb25det engine, ported engine head. HyperGear High flowed R33 GTST turbocharger SpeedTek exhaust manifold Turbosmart 45mm external gate ID2200 Injectors + Twin Bosche 044 pump Programmable ecu 3 inches turbo back exhaust Tuned at Chequered Tuning Looking forward to see it perform at Vic drift Round 3. 1 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/605/#findComment-7875624 Share on other sites More sharing options...
Bond Posted May 17, 2018 Share Posted May 17, 2018 Great result. Do you have a thread like this for SR20's? I have jumped ship! Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/605/#findComment-7875743 Share on other sites More sharing options...
hypergear Posted May 17, 2018 Author Share Posted May 17, 2018 I did some SR stuff in 2014. if you go back to page 456 and read from there, that contain alots of SR20det's developments. On page 1, search SR20, and I have listed pages that contain SR20dets developments and results. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/605/#findComment-7875747 Share on other sites More sharing options...
Super Drager Posted May 26, 2018 Share Posted May 26, 2018 Just road tuned my R33 with an ATR45SS. Pulls pretty damn well at 16psi. Z32 MAF shows 4.77v at that boost and the 875cc injectors are at 60%. All on 98RON. I have a walbro 485 pump ready to go in for when i decide to go E85. 1 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/605/#findComment-7876517 Share on other sites More sharing options...
hypergear Posted May 27, 2018 Author Share Posted May 27, 2018 Some video footage from last weeks Calder park drifting even. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/605/#findComment-7876592 Share on other sites More sharing options...
hypergear Posted July 4, 2018 Author Share Posted July 4, 2018 Great videos to shared from VicDrift website. I've seen few of customers cars made to the final battles. That is Cam Martin's silver R33 GTST running our high flowed 21U factory turbocharger making 330rwkws, White R31 Wagon using one of our ATR43G3SAT CBB turbocharger making 310rwkws and Just Gurener's purple R33 running one of our ATR45SAT CBB turbocharger making 400rwkws. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/605/#findComment-7880088 Share on other sites More sharing options...
lexxi32 Posted July 5, 2018 Share Posted July 5, 2018 Are there any results for the ATR45SS on an RB? I'm tossing up between the ATR45 CBB and ATR45SS CBB. Tao what would be the expected difference in lag and power be between the two? Both external gate on a proper manifold on a 30DET. Hi Xr pilot. I recently installed one of hypergears atr45 .82 billets on my rb30det. Stock block stock head stock cams etc. On bp98. Had a waste gate issue which lost alot of mid range power and torque but still managed 375kw. E85 would see a great improvement over 98 also. I have uploaded a graph from my run. Keep in mind this is with no vct so there is alot left in it. Also rev limiter was set to 7000rpm because of stock motor. Graph shows that extra revs more power is easily do able. Trent from chequred said it was hard to stop it making power at 7000rpm as it just wanted to keep climbing. Hope this helps. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/605/#findComment-7880134 Share on other sites More sharing options...
Dale FZ1 Posted July 6, 2018 Share Posted July 6, 2018 On 7/5/2018 at 10:28 AM, lexxi32 said: Had a waste gate issue which lost alot of mid range power and torque but still managed 375kw. Keep in mind this is with no vct so there is alot left in it. Also rev limiter was set to 7000rpm because of stock motor. Graph shows that extra revs more power is easily do able. Trent from chequred said it was hard to stop it making power at 7000rpm as it just wanted to keep climbing. Overall a decent result. Be interesting to see the boost curve with this one. I'd say that no VCT is a big cause of the relative torque deficit across the 2500-4500 range. Torque peaks at 5500 then starts dropping, so power has peaked before 7000. Not sure why the tuner says it will make more hp with more rpm. Hope he pointed to the saw-tooth shape of the graph over 5000. Might be worth investigating timing scatter, see if that needs to be addressed. Not uncommon to pick up 10-15kW by fixing those issues. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/605/#findComment-7880288 Share on other sites More sharing options...
lexxi32 Posted July 6, 2018 Share Posted July 6, 2018 Overall a decent result. Be interesting to see the boost curve with this one. I'd say that no VCT is a big cause of the relative torque deficit across the 2500-4500 range. Torque peaks at 5500 then starts dropping, so power has peaked before 7000. Not sure why the tuner says it will make more hp with more rpm. Hope he pointed to the saw-tooth shape of the graph over 5000. Might be worth investigating timing scatter, see if that needs to be addressed. Not uncommon to pick up 10-15kW by fixing those issues. Saw-tooth area is just topical hub dyno being sensitive to any reactions. Every hub dyno graph iv seen all have it from various tuners. There is next to no timing up top from what I was told as it was having an issue with creating boost when timing was added up top. As already having a huge boost creep issue already it was left at that. Cam duration is most likely also an issue on the torque side as there just stock cams from a r32 s0 rb25 so exhaust cam lift is actually smaller then stock rb20 which are tiny already. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/605/#findComment-7880296 Share on other sites More sharing options...
hypergear Posted July 13, 2018 Author Share Posted July 13, 2018 Some results to share. From an ATR46SS-1 turbocharger powered 2JZGTE Chaser with a 2 speed auto. Car has made 683rwkws @ 34psi 1 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/605/#findComment-7880926 Share on other sites More sharing options...
Super Drager Posted July 13, 2018 Share Posted July 13, 2018 Im assuming thats close to gtx4202 spec?? How much bigger is the ss2 version? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/605/#findComment-7880937 Share on other sites More sharing options...
GTSBoy Posted July 14, 2018 Share Posted July 14, 2018 Colour me befuddled. What use is a power curve that looks like that? 1 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/605/#findComment-7880956 Share on other sites More sharing options...
Ben C34 Posted July 14, 2018 Share Posted July 14, 2018 1 hour ago, GTSBoy said: Colour me befuddled. What use is a power curve that looks like that? That would be the result of the loose converter, so it’s not real. No way would that be of any use if the car was a manual. 1 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/605/#findComment-7880958 Share on other sites More sharing options...
hypergear Posted July 14, 2018 Author Share Posted July 14, 2018 As mentioned that's an result of high stall auto. this car run 9.9sec quarters on 578rwkws with similar power curve using an BW S400. It would be useless if that is an manual curve. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/605/#findComment-7880985 Share on other sites More sharing options...
hypergear Posted August 20, 2018 Author Share Posted August 20, 2018 Great in car video footage to share from Cam's R33 drift car off Vic drift Round 4. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/605/#findComment-7883584 Share on other sites More sharing options...
hypergear Posted August 21, 2018 Author Share Posted August 21, 2018 This might be interesting. our TD06SL205 in 10CM running against a 2018 model Ebay (Not kando but a someone sales rather similar) Billet 25G TD06 10CM. Ebay turbo lasted few dyno runs before running into issues and the owner decided to do a core change so he can completes the dyno tune. I don't think ban and block buyers for warranty claim is a good business practice, having a pissed customer is at least, most importantly the data of why and where a product can be improved is lost. Green is our TD06SL205 and Red is Ebay Boost: When same amount of boost is given: 1 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/605/#findComment-7883670 Share on other sites More sharing options...
LaurelPWR Posted August 21, 2018 Share Posted August 21, 2018 This might be interesting. our TD06SL205 in 10CM running against a 2018 model Ebay (Not kando but a someone sales rather similar) Billet 25G TD06 10CM. Ebay turbo lasted few dyno runs before running into issues and the owner decided to do a core change so he can completes the dyno tune. I don't think ban and block buyers for warranty claim is a good business practice, having a pissed customer is at least, most importantly the data of why and where a product can be improved is lost. Green is our TD06SL205 and Red is Ebay Boost: When same amount of boost is given: This is fantastic data mate! Would be a much faster car with your turbo compared to the eBay setup. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/605/#findComment-7883675 Share on other sites More sharing options...
hypergear Posted October 29, 2018 Author Share Posted October 29, 2018 Keeping thread updated. Some video footages taken from one of our clients car at Hi-Tech drift round 8 taking the winner trophy. R33 GTST powered by one of our ATR43SS2 internally gated turbochargers making 289rwkws, tuned by DvsJez Hi-Tech drift official footage: Chase footage: 1 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/605/#findComment-7889440 Share on other sites More sharing options...
hypergear Posted October 30, 2018 Author Share Posted October 30, 2018 WTAC 2018 Sprint class R33 GTST driven by Mr Oversteer. Car powered by one of Hypergear High flowed R33 GTST turbocharger making 328rwkws on E85 fuel internally gated. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/605/#findComment-7889552 Share on other sites More sharing options...
hypergear Posted November 28, 2018 Author Share Posted November 28, 2018 (edited) More update with an Billet CBB high flow that can be applied to both OP6 and 21U turbochargers. I've currently using and its trailed on an R34 GTT that I have modified from scratch, parts and pricing ways Car has: 1. Injectorsonline ID 1000cc injectors + plugs : $750 2. Injectorsonline Walbro pump: $220 3. Korioautoparts Performance Radiator: $180 4. Z32 AFM with plug: $330 5. Nistune ECU plus tune from Chequered Tuning: $995 5. Split fire coil packs from Just Jap: $550 6. Spark plugs: $100 7: Exhaust flapper valve: $75 8: ATR43SS2 ball bearing turbocharger: $1850 9: Ebay intake pipe: $60 10: Trust front mount intercooler kit: $1650 Tuned at Chequrered tuning, Car's pulled 290rwkws at 20psi on pump 98 fuel. Edited November 28, 2018 by hypergear 1 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/605/#findComment-7892340 Share on other sites More sharing options...
