Looking to spend $500 to do that sleeve insert.
One more Tuning video to add. This is one of our ATR43G3SAT Rb bolton models. making 324rwkws on E85 fuel internally gated.
Car's an R33 GTST with:
Stock RB25DET
Stock intake manifold with FF throttle body conversion
FMIC
Hypergear ATR Series bolt on turbo with IWG
Stock exhaust manifold
3" TBE
Aeroflow top feed fuel rail conversion and Bosch 1000cc injectors
Walbro 460LPH fuel pump
EBC
Flex sensor
Haltech Platinum pro plug in ECU
Prepped by Hadie from Elite Motorsport
Edited by hypergear
  • Like 1
Stock RB25DET
FMIC
3" TBE
EBC
Flex sensor
Haltech Platinum pro plug in ECUPrepped by Hadie from Elite Motorsport
Can you please share some dyno data of the T51r anti surge slot showing?
Specifically after before and after the slot install ?
It acts as a normal anti surge slot. There is a lose in compressor efficiency. I did a comparison years ago result is in this thread. There was a lose of 300RPM and 11kws with that particular turbo used.
Tao, I have a genuine low KM Trust TD06SL2-20G (8cm) off my RB20.
Going forged RB25 and cannot seem to sell it for reasonable money to fund a larger Turbo.
Worth doing a 10cm 20.5G or similar whilst I save for a big banger 25G?
Let me know if I should PM you :)
The SL205 makes the same power as a 25G with better response. If your current turbo is not blown I can have that modified to the same specifications as the 20.5 with a 10cm with turbine housing supplied for less then half the cost of a new turbo.
Will PM you.
More video to share. This is an R33 GTST powered by one of our ATR45SS1 turbochargers at Hitec drift last weekend. Car's currently making 401rwkws on E85.
  • Like 2
One more result to share:
Rb25det NEO Stock engine
HyperGear high flowed Turbocharger
ID 1000cc injectors
Walbro 460L fuel pump
Power FC + Z32 AFM
Greedy Profect B EBC
600x300x81mm PWR Cooler kit
3inches turbo back exhaust
4inches intake pipe with Pod
Split fire coil packs
Turbosmart 45mm external gate welded on exhaust manifold.
At higher boost level we've reached 340rwkws before experiencing ignition break down.
https://www.youtube.com/watch?v=Mgz8Wzyc6X0&t=6s
  • Like 1
further update with prototype ATR45ss turbocharger. Car made 364rwkws before running out fuel.
Looks like vct really helps these turbos come alive in mid range. Even though its a .63 the torque graph looks really good
Hey guys, just sharing a result.
Stock RB25DET, recent ( late last year) 21u highflow. 98 fuel. Vipec plug-in.
240rwkw on 14.5 psi.
264 on 17.5psi.
In the interest of stealthy looks, still running airbox, exhaust with functional cat and 2 mufflers. CES split dump, and a generic China cooler with custom return flow pipework.
Engine bay looks stock.
Putting more boost in gave more midrange, but tapered off to 17-18 up top, obviously either/ all due to airbox, cooler setup and exhaust. But happy with the stealthy looks for now.
Fairly happy with the result, car drives great.5330FC90-D845-4773-9198-8280FDCB46F9.jpg
  • Like 1
Nice result. The pressure drop would mainly be restriction on cold side. A FMIC with a better cooler, 4 inches metal intake and free flow exhaust should see another 10~15kws gain.
The stock look is my ideal setup.
What intake pipe between turbo and airbox?
And what actuator and boost control?
Edited by Pattey21
More info
The biggest you can fit using air box would be 3 inches, I would prefer a short 4 inches metal pipe in between. that provides better throttle response over 3 or 2.5 inches. Actuators, something 14psi or one of our high pressure actuators will do fine.
Ebay silicon one, as previously tried by Tao. Pretty much a drop in
14.5 psi actuator, boost control is a 3 port mac valve controlled by the vipec (ecu).
ATR45SS Rb25det NEO round 2 with fuel pump issue sorted. Now pulling 400rwkws at 24psi on E85 fuel. Car mods are listed in video below:
https://www.youtube.com/watch?v=hrVjIMxIFrA
  • Like 3
What would you expect out of this same setup on 98 octane?
Is there much lost by plumbing in the wastegate with the 3 inch exhaust?
    • God I love shiny engine parts 🥰 Are you looking for more horsetorques in the mid range? (Smaller cam) Or just more horsetorques every where? (Big heads and bigger revs) Assumption: they were not bought late night shopping on the interwebs after drinking too many beers, which is typically how I pull pins on things......🤣 The evolution of your car is coming along nicely, I sometimes wish I didn't get bored with my cars and keep flipping them, maybe the MX5 will be different
    • I got the hazards working! Turned out it was disconnected! Indicator stock still isn’t working. I took the steering shroud off and there seems to be a third connection missing I see two small white connectors but they don’t fit the indicator switch unless they need a short lead to convert the connector type. Can someone point me in the direction of the wiring diagram for the indicator switch?   https://share.icloud.com/photos/0e8ReiFSLBVJsTPUKKfA_1IdQ
    • All of your suspension bushes/bolts etc, should also only ever be tightened when the car is sitting with full weight too.   IE, jack it back up, shove a heap of stuff down so you can lower the wheels onto so the car is "on the ground" but you have room to get under it.   It's why when properly done, you should be able to remove the shock and spring, but the arms won't go to 100% droop. If you don't do the above, you'll destroy your bushes.
    • We have some more genuine Japanese legally decommissioned car number plates in stock 🙂, as well as the plain white 40mm hole cover: Tama 400 No 12-41: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-no-1241 Morioka 300 Te 43-58: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-te-4358 Plain White 40mm Hole Cover: https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-40mm-hole-cover-white There's also a yellow plate for Kei cars with the corresponding yellow 40mm hole cover sold as a set: Tsukuba 581 Ii 64-66: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-single-number-plate-ii-6466 Also some Skyline 1/43 scale models: 1989 BNR32 Nissan Skyline GT-R (Silver): https://www.oemsoko.co.jp/products/rare-ebbro-oldies-2006-release-bnr32-nissan-skyline-gtr-silver 1989 HCR32 Nissan Skyline GTS-t Type M (Red): https://www.oemsoko.co.jp/products/kyosho-original-1-43-hcr32-nissan-skyline-gts-t-type-m-red
