Hypergear Turbochargers and High flow Services Development thread
Looking to spend $500 to do that sleeve insert.
One more Tuning video to add. This is one of our ATR43G3SAT Rb bolton models. making 324rwkws on E85 fuel internally gated.
Car's an R33 GTST with:
Stock RB25DET
Stock intake manifold with FF throttle body conversion
FMIC
Hypergear ATR Series bolt on turbo with IWG
Stock exhaust manifold
3" TBE
Aeroflow top feed fuel rail conversion and Bosch 1000cc injectors
Walbro 460LPH fuel pump
EBC
Flex sensor
Haltech Platinum pro plug in ECU
Prepped by Hadie from Elite Motorsport
Edited by hypergear
  • Like 1
Stock RB25DET
FMIC
3" TBE
EBC
Flex sensor
Haltech Platinum pro plug in ECUPrepped by Hadie from Elite Motorsport
Can you please share some dyno data of the T51r anti surge slot showing?
Specifically after before and after the slot install ?
It acts as a normal anti surge slot. There is a lose in compressor efficiency. I did a comparison years ago result is in this thread. There was a lose of 300RPM and 11kws with that particular turbo used.
Tao, I have a genuine low KM Trust TD06SL2-20G (8cm) off my RB20.
Going forged RB25 and cannot seem to sell it for reasonable money to fund a larger Turbo.
Worth doing a 10cm 20.5G or similar whilst I save for a big banger 25G?
Let me know if I should PM you :)
The SL205 makes the same power as a 25G with better response. If your current turbo is not blown I can have that modified to the same specifications as the 20.5 with a 10cm with turbine housing supplied for less then half the cost of a new turbo.
Will PM you.
One more result to share:
Rb25det NEO Stock engine
HyperGear high flowed Turbocharger
ID 1000cc injectors
Walbro 460L fuel pump
Power FC + Z32 AFM
Greedy Profect B EBC
600x300x81mm PWR Cooler kit
3inches turbo back exhaust
4inches intake pipe with Pod
Split fire coil packs
Turbosmart 45mm external gate welded on exhaust manifold.
At higher boost level we've reached 340rwkws before experiencing ignition break down.
https://www.youtube.com/watch?v=Mgz8Wzyc6X0&t=6s
  • Like 1
further update with prototype ATR45ss turbocharger. Car made 364rwkws before running out fuel.
Looks like vct really helps these turbos come alive in mid range. Even though its a .63 the torque graph looks really good
Hey guys, just sharing a result.
Stock RB25DET, recent ( late last year) 21u highflow. 98 fuel. Vipec plug-in.
240rwkw on 14.5 psi.
264 on 17.5psi.
In the interest of stealthy looks, still running airbox, exhaust with functional cat and 2 mufflers. CES split dump, and a generic China cooler with custom return flow pipework.
Engine bay looks stock.
Putting more boost in gave more midrange, but tapered off to 17-18 up top, obviously either/ all due to airbox, cooler setup and exhaust. But happy with the stealthy looks for now.
Fairly happy with the result, car drives great.5330FC90-D845-4773-9198-8280FDCB46F9.jpg
  • Like 1
Nice result. The pressure drop would mainly be restriction on cold side. A FMIC with a better cooler, 4 inches metal intake and free flow exhaust should see another 10~15kws gain.
The biggest you can fit using air box would be 3 inches, I would prefer a short 4 inches metal pipe in between. that provides better throttle response over 3 or 2.5 inches. Actuators, something 14psi or one of our high pressure actuators will do fine.
On 4/10/2019 at 11:39 AM, Pattey21 said:
The stock look is my ideal setup.
What intake pipe between turbo and airbox?
And what actuator and boost control?
Ebay silicon one, as previously tried by Tao. Pretty much a drop in
14.5 psi actuator, boost control is a 3 port mac valve controlled by the vipec (ecu).
ATR45SS Rb25det NEO round 2 with fuel pump issue sorted. Now pulling 400rwkws at 24psi on E85 fuel. Car mods are listed in video below:
What would you expect out of this same setup on 98 octane?
    • I'm only going to hassle you for posting links to images. It's against my policy to click links that could be some nasty payload. Sadly, you need to make 9 more posts before you can just stick the images directly in a post, unless @PranK sees this and bends the rule for you.
    • Hello,new to the group, I bought a R32 from auction recently, wondering if anyone knows the cars history, seems to have the usual go fast bits on it, plan is to do an engine swap- add 2 extra cylinders and 1 extra turbo. https://www.dropbox.com/scl/fi/i4rjmlzubjbwjtguh6f4s/IMG20241011140744.jpg?rlkey=q0lumm251377vknbqktfwrycq&st=7scvwx4e&dl=0 https://www.dropbox.com/scl/fi/ro24qmwzlczzlfsr4y05x/Screenshot_2024-10-10-10-49-23-90_9a2f5bb2149dae94cd1e190effc09b33.jpg?rlkey=oyguh26ttshlf04ccp48odf4v&st=xloae97b&dl=0   New to forums and posting pics, if links don't work, take it easy on me, 42yrs old and I tune carburettors!!
    • As far as I know, Infiniti stopped importing vehicles before 2020, even though they were still selling their stock for at least a year or 2 after that, they were older build years, therefore, you can import a 2020 400R, because you couldn't buy an AuDM 2020 built Q50 RS. As for insurance, you might need to go through one of the enthusiast insurance companies, they tend to insure a lot more grey import models than the mainstream insurers as Duncan mentioned.
    • loved seeing the zenvo on the a1 just after the hatfield tunnel i was the guy in the white van trying to egg you on it sounded awesome and those exhausts glowing red inside insane cheers for the thumbs up tim and tom.
    • So.... when I'm finally getting around to having my power steering leak sorted, now it looks like I've got the same issue most A/T Skylines are having. My A/T light will randomly come on and I'm stuck in 3rd gear until I turn the car off and on again. Only 3 weeks ago I did a complete transmission service: Oil flush + new gasket + new filter. This came out of nowhere!! It wasn't like the car was driven hard. I drove about 3 mins down the road to get fuel and boom!!!  Anyway, I have a few questions and hope you fine people can help me out here. All questions are in red. 1. The solenoids: I was looking at the parts catalogue in Amayama and I could only find the Solenoids as an assembly. https://www.amayama.com/en/part/nissan/319404ax05 I read in another thread that Solenoid A = 31940-4AX02 & Solenoid B = 31940-4AX05 but the Amayama product has only the code of B. Is this the right part? Can anyone who has done the Solenoid changes or seen them confirm if this is the complete set of A & B?   2. Gasket and Filter: I'm not going to try change the solenoids myself because it seems difficult to do in a home garage with just 2 jack stands. I plan to take it to a shop and get it changed. I was also going to buy the transmission sump gasket at the same time so I don't reuse the same gasket. Should I just use the existing gasket as it has only been on the car since OCT 19th? (~3 weeks) Should I be buying a brand-new gasket and a filter? Does this job involve taking the filter out?   Thanks in advance to everyone. It's hard to find a video of someone doing a solenoid change on a R34 so any help you can give answering my remaining questions would make me less stressed.
