  • 1 month later...
New result to share. This is an ATR45SAT ball bearing bolton turbo running of an external gate from factory exhaust manifold. Car is an R34 GTT with a freshed up Rb25det NEO engine. Car made 420rwkws @ 25psi of boost E85 fuel, 240rwkws @ 4000RPM, Nice and responsive.
  • Like 2
power.jpg&key=91cf0f95b9a5de09e3b2e49c223b7f9ad46c620075f2242c13768e6310ac984a
boost.jpg&key=14d9ac558f5b9d5cbe0f19f7ed5fb73d4d02474e4b18df3990160d2729303606
Is there a twin scroll housing that would fit this turbine?
I can supply a .84 rear housing in twin scroll. It won't be as responsive. If you have a twin pulse twin gate manifold, you can use the .63 single housing with an ATR45SS-1 to make 450rwkws+ while still have similar response as above.
Have you tested it with the .84 twin scroll rear on a true twin scroll twin gate manifold?
I would be genuinely surprised if it was less responsive [emoji848]
Same thought, a true twin scroll and proper divided setup would be more responsive than a single scroll.
  • Like 1
Interesting thing happened around here recently, a guy with a 2litre Subaru running a twin scroll manifold and a open housing .63 GTX3076R decided he was happy with the power he was making but wanted more spool so swapped to a .61a/r divided hotside - using the same exhaust manifold, but changing the up-pipe to suit the twin scroll housing.  The car improved spool by a couple hundred rpm and lost around 50kw @ wheels.
After going through a bunch of diagnostics and deciding there were no other issues or changes other than the housing/flange setup he tried changing to a .83a/r twin scroll housing and it got back within 20kw of the .63 housing, but was also no better spool than with the open housing option.
Again, after further head scratching and messing around he decided to swap back to the original up-pipe and .63a/r housing and boom!  Back to the same power and response he had before trying the divided path.   Definitely not what I would have expected, but it's a thing that happened - unfortunately I am not directly involved so I have no more detail than what I've shared here, I wouldn't count out the possibility there is some other variable at play but realistically the options are pretty minimal... especially when it came back to "full power and response".   The car is definitely performing overall better with the .63 hotside.
  • Like 2
3 minutes ago, Dose Pipe Sutututu said:
Only thing I can think of with the EJ, is the turbo manifold of equal header lengths or is it the usual unequal length business?
The twin scroll turbo manifolds are equal length, which is why a lot of the later Subarus don't sound like 5-cylinder RBs :)
  • Like 2
Interesting nevertheless, hopefully my selection of parts will work.
Car is coming out of fab work this week.
  • Like 1
Why should twin scroll exhaust manifold and housing make slightly better response. It very dependent on the design of the actual exhaust manifold and of course the firing sequence of the engine. Lets take Rb25det with firing sequence of:
1 5 3 6 2 4
Stock twin pulse log manifold consist bank 1 of: CYC 123, and bank 2 of: 456.
So the split plus ensures the combusted air shoots straight into turbine housing rather then towards the other side. I've seen customers drilling out the center divider of factory exhaust manifold result in lose of response and power. I'm currently using a merged pulse external gate on a factory exhaust manifold, and by doing that I have lose about 300RPM of response, I think it would partly contributed the this problem and the extra volume external gate plumbing has made up.
Same principle apply to a spaghetti manifolds, but I found its not as tangible as the runners are separated that ends up in a collector. So there will be a bit of a differences assume a properly made twin pulse, twin gated exhaust manifold used on the right size twin pulse turbine housing.
The advantage of twin gates giving extra flow would mean you can use a smaller housing on a turbo that makes the same top end as a big housing while avoiding the lag.
Edited by hypergear
The theory on split pulse is pretty well discussed these days, reduces the collisions between high pressure pulses and keeps them separate until they are meant to drive the turbine.  I suppose you could say that it should reduce turbulence and as such keep velocity up.
In regards to people removing the divider in the stock manifold, I think of that more like a turning vane than a split pulse - without it there is nothing to make the exhaust flow think that it should just head straight to the other cylinders due the shape angles required to head to the turbine.  I am not sure that has so much relevance in the twin scroll/split pulse discussion, aside from the fact that the only reason that is at all a workable design with a straight 6 is that you have alternating pulses on front and rear three so it makes it less likely to cause bizarre lean outs on certain cylinders.
In terms of the twin gate advantage meaning that a smaller housing can flow like a bigger one, I could be missing something or misinterpreting  - so how do you mean?
At face value it seems like you are saying that having more gate means you will reduce exhaust manifold pressure, but just having a second gate won't increase the turbine's ability to drive the compressor for a given amount of exhaust gas, so there is no reason for it to open more... the only reason the wastegate would flow more is if the turbine needs less exhaust energy to do it's job.   It's pretty easy to tell where more gate is an advantage, you get boost creep as you aren't relieving enough exhaust gas.   If you relieve more exhaust gas then you lose the energy you need to drive the turbine and you don't hit target boost.
Apologies if I've misunderstood what you said, keen to hear what you mean or where you are coming from with that one.
Edited by Lithium
  • Like 1
I was referring to stock rb25det manifold.
The twin gate setup, I found its dependent on  the types and shape of turbine wheel as well as size of housing used. I will conduct some experiments later in the year and upload results.
Edited by hypergear
  • 3 weeks later...
  • 4 weeks later...
Further development in R33 21U high flowed turbochargers. Latest model made 342rwkws fItted to an unopened R33 Rb25det engine as a bolton turbo with FMIC, 3 inches metal intake pipe, 3.5 inches turbo back exhaust, fuel system and programmable ecu.
front.jpg&key=caaeb2150ace5ab8b3b06e4e35294e2ad8ab539f439990224ac44dee9dfd5c88
342rwkw.jpg&key=0efdb1717652166f679d618c0fcb8f80aeb601c16903e7615b2e875fb27482d8
boost.jpg&key=55370b7ecdcc31a1415905d79e1348c58ce331d99f09daca69f585907f58ec6c
I’m guessing that’s on e85?
Have you done many test with 98ron?
Yes that is on E85. I don't have result of this version on 98 yet. it would be sitting pretty close to 300rwkws on that car.
by the looks of the graph did the boys at G7 Adelaide do the install in tuning ? if so It looks like ill be giving them a visit! Great stuff Tao!
    • Has equal chance of cleaning an AFM and f**king an AFM. I think you can work out what happened. When the Hitachi ECU sees the AFM die and goes into the associated limp mode, then it will start and run just fine, because it ignores the AFM and just runs on idle maps that will do what it needs to get it going. But there is no proper load signal, so that's about all it can do. My suggestion? If you don't want to go full aftermaket ECU, then get some R35 GTR AFM cards and some housings to put them in, in the stock location, and Nistune the ECU. Better to do a good upgrade than just replace shitty 40 year old tech with the same 40 year old tech.
    • So my car was recently having trouble starting on initial crank, I would need to feather the gas for it to start up but besides that it would start and run fine. So I clicked the idle air control valve (with throttle body cleaner) and cleaned the MAF sensors (with MAF cleaner). The start up issue was fixed and now the car turns over without the assist of the throttle, but the car is in limp mode and wont rev past 2.5k RPM. From what I understand the IACV would not put the car in limp mode, so I am to believe it is the MAF sensors, but it was running fine before and now I cant get it out of limp mode. I cleaned the MAF made sure the o rings were seated properly. Made sure the cables were plugged in properly, the cables also both read the same voltage. Does anybody know why this is or what could be causing this or how to get it out of limp mode?
    • Ooo I might actually come and bring the kids, however will leave the shit box home and take the daily
    • Thanks. Yeah I realised that there's no way I'd be able to cover the holes with the filler, it would just fall through. Thanks again @GTSBoy!
    • That was the reason I asked. If you were going to be fully bodge spec, then that type of filler is the extreme bodge way to fill a large gap. But seeing as you're going to use glass sheet, I would only use that fibre reinforced filler if there are places that need a "bit more" after you've finished laying in the sheet. Which, ideally, you wouldn't. You might use a blob of it underneath the sheet, if you need to provide some support from under to keep the level of your sheet repair up as high as it needs to be, to minimise the amount of filler you need on top. Even though you're going bodge spec here, using glass instead of metal, the same rules apply wrt not having half inch deep filler on the top of the repair. Thick filler always ends up shitting the bed earlier than thin filler.
