Test run on the Rb bolton internally gated ATR45SAT turbocharger, the external gate has made a huge difference in power gain.  Final result of 362rwkws @ 20psi Internally gated  and 427rwkws @ 25psi Externally gated
Rb25det NEO Stock Cams
Nitto Pistons and Rods. 9:1 CPR
HyperGear ATR45SAT internally gated Rb bolton version Run both internal and externally gated
ID 1500cc injectors
Twin Walbro 525L fuel pump
Adaptronic Plugin ECU
Greedy Profect B EBC
600x300x81mm PWR Cooler kit
3inches turbo back exhaust
4inches intake pipe with Pod
Split fire coil packs
  • Like 2
On 7/26/2020 at 12:27 AM, self_slaughter said:
Thanks all for all the help, I have most of the main pieces of the puzzle ready to go now. :D
ATR45SAT-BB (thanks Tao, she's a little cutie), 1000cc injectors, 460l pump, HPX-N1 maf, Nistunes off getting updated to feature pack 2.1 + having the flex fuel gear installed.
Only hard bit now is the intake piping, which I'm hoping I can just get fabricated by whoever installs it to make life nice and easy. Save me doing bits, towing it to a fabricator, then towing it to a tuner etc. if possible.
On that note, Any recommendations for an installer/tuner in QLD?
Where are you located? In Brisbane I recommend East Coast Customs & Townsville either myself or ShaneFraserMotorsport. A quick google of nistune tuners is a good place to start too
Rework on one of the earlier prototypes that did a fairly laggy 552rwkws, Now making a responsive 570rwkws.  As usual, mod list of the car is:
HyperGear ATR45SS-2 prototype Turbocharger
ID 1500cc injectors
Twin pulse manifold and twin 40mm gate.
Car made 570rwkws @ 40psi, E85 fuel. With 250rwkws @ 4000RPM
  • Like 2
  • 2 months later...
Hi all, after reading 615 pages I’m still confused on which turbo to buy 🤦‍♂️ I have a unopened rb25 neo, fmic, I have a link ecu and a 6 boost manifold waiting to go in, would I be better off with the ART43G3SAT or go for the g3 .82 bb version I have my eye on 750cc injectors to go with it.
cheers
cheers
Without telling us what your looking for no one can really make a recommendation. How about starting with how much power you want to make and what you'll be using the car for? Street/circuit/drift/drag/etc...
Also if your going e85 you'll run out of injectors with only 750cc.
  • Like 1
Hi,
I’m looking for anything around the 400-450 bhp mark.. I’m not looking to go forged yet ( maybe in the future) its a road car and the odd drift day. I won’t be going e85 as it’s hard to find in Ireland as it was phased out a few years ago, so it will be regular unleaded  for the c35 laurel ️,   On a side note I have a bio power 9-5 and it’s a shame I can’t get e85 for that too :(
Edited by Smokey_1507
For 400~450HP mark on P98 fuel I recommend our externally gated ATR43SS2 in .63 rear housing T3 Vband. I can supply external gate exhaust manifold and turbo smart gate assembly with screamer with the turbocharger if needed.
  • Like 2
  • 1 month later...
ID 1500cc injectors
Hi, is the engine in this test still on OEM stock valve springs? thank you.
  • 1 month later...
Pretty cool result to share. ATR43SS-2 BB on a Rb25de+T Neo cracking 390rwkws on E85 fuel on KeepRite drifting machine. Tuned at Dr.Drift.
  • 1 month later...
Hi Hypergear,
I am interested in a 600rwhp capable turbocharger for my built rb25 neo engine 9:1 compression ratio. Will be running a 6 boost manifold (would you suggest a t3/t4 or a v-band inlet?).
What would be the most responsive turbo you have in this range?
Thank you.
Hi Blakeo, That will be a similar engine build as my R34GTT. Recommended would be an ATR45SS-1 BB in .63 rear housing in T3 Vband out let. This turbo have managed to pull 520rwkws with stock cams on E85 fuel and making almost 300rwkws by 4000RPM.
Some more results to share, R34 GTR test and tune, I've had this cars in storage for awhile,  if you did spent 250K for a fully unmolested stock one today you will be horribly disappointed with its performance. Stock twins with upgraded cooler, exhaust, and intake managed to pull 238awkws at 15psi, with help of a PS2000 it managed 272awkws @ 17psi, Not fast at all. after getting chopped by a Supercharged TRD Camry, I've decided to do some work to it. And I still believe Rb25dets/Neo are way better engines.
Looking into further developments in T4 printed turbos. First up is a ball bearing ATR45SS-1 turbocharger in a custom T4 .86 Vband rear housing. Stock Rb26 engine is now fitted with:
APR head studs
HKS Cam gears +9" inlet, 0 exhaust.
R35 GTR coil packs
CAS Trigger kit
Haltec PS2000 ECU
ID 1650cc injectors
Twin 540 Walbro pumps+11m fuel line
Nismo Front mount cooler
T4 high mount exhaust manifold
HyperGear 50mm External gate
HyperGear ATR45SS1 T4 .86 rear
3 inches Trust turbo back exhaust
Final result so far 425kw on all 4 wheels @ 28psi E85 fuel
Tuned at Chequered tuning
Will be testing few different turbo combinations and spend more time with cam adjustments for better response.
Edited by hypergear
  • Like 3
Great result @hypergear I also think that Trust cat back is a restriction, probably has a restrictor hidden somewhere to make it JASMA approved
Thanks for the tip. Yes I though it might be the case, so I've added a cut out on the front pipe. Highly recommended for power hunting.
Edited by hypergear
  • Like 1
    • Getting Dangerously close to being ready to go back in the car. Rockers in with clearance castings now (and a quick check with the USA for the torque settings for the larger custom bolts) Covers and ported FAST Manifold sitting on there. Not fully tightened down as there's some clearancing required for the water pump with the earlier LS1 water pump styles. Example of the clearancing needing to be done: The body has to be ground a little but I'm struggling finding an actual piece of it. The later variant of water pump resolves the issue as the manifold was designed around it. It only came on the VZ LS1 in Australia, it got a different pulley for Gen4 motors. (it also costs $450... vs... $0).
    • https://files.fm/f/5atwkuvcjd
    • Doing some height adjustment on front suspension on a v35 and noticed this. The passenger side looks correct. So wondering what's happened to the drivers side?
    • Oh...I have the electric mirrors as well iirc ...they're in the same state as just about every other R31 door mirrors, with the 3 plastic screw towers broken/cracked in the plastic molding. All the interior is 'dry', so the mirror switches etc likely all work fine. Some pics below of the trimmer pieces ~ looks to me like previous owner, painted chrome finished trims with black paint ...ergo, the chrome underneath is likely a-ok... ...starts to look yukky posting stuff like this, how much did it cost in fuel on your last sortie up this way?...me just thinking aloud, borrow someone else's 4cyl to cut costs, come do your own pick'n'pull like before to save me some bother...hehe.. but whatever, I'll just earmark bits I know you want, because the way this is all panning out, I'll be able to retire the R31 from daily duty at long last, replacing it with a Subaru wagon I'm lining up in the wings...ergo, my attitude towards the donor pinny shell is starting to wane a bit, and I'm more than happy to help you out there... Like you say though, no rush...and I'll guarantee we won't be moving too far from this locale at any rate 😎
    • Cool, I’m just down Sydney today. Not much time to get online.
